Question about Winter Sports
I have a 2012 Ski doo 600 gsx etec. I has a miss when driving it but now when cold is running rough. I noticed the injector cap is leaking would this contribute to the problem?
2 Suggested Answers
  • 1162 Answers
SOURCE: 2004 600 sdi ski-doo missing at 4500 rpm
have you checked the plugs? they could be fouled or a build up of carbon. have you checked or rebuilt the carb, if so did you change the fuel lines they could be cracked and sucking air.
Posted on Jan 30, 2015
Testimonial: "new plugs. sdi so no carbs and throttle body was cleaned"
07 Doo 500ss doesn't charge, already tried stator and regulator
What is the resistance on your stator leads, when running what is your output from the start (before the regulator) it will be ac volts there will be 3 leads.
Feb 14, 2018 | Ski-Doo 2007 GSX Sport 500 SS
How do I remove the battery from a 2014 Ski Doo 900 ace snowmobile?
About 26,400 results (0.92 seconds) Search Results
    Brp Expert Tips For Summer Snowmobile Storage ' Ski-Doo ...
    xteam.ski-doo.com/en.../brp-expert-tips-for-summer-snowmobile-storag...
    Apr 4, 2013 - BRP Expert Tips for Summer Snowmobile Storage ... If you have a 1200 4-TEC or ACE 600, change the engine oil and filter. ... SnowTech's First Impressions of the ACE 900 Engine .... September 2014 (4); August 2014 (1); July 2014 (1); April 2014(2); March 2014 (6); February 2014 (14); January 2014 (5) ...
    First oil change opinions - 900 ACE 4-Stroke Models - DOOTalk ...
    www.dootalk.com/forums/topic/671977-first-oil-change-opinions/
    Dec 15, 2013 - Page 1 of 4 - First oil change opinions - posted in 900 ACE 4-Stroke ... suppose to be easier on the 2014 , different battery bracket ? or you can ... 900 Ace Summarization ??? - 900 ACE 4-Stroke Models
    Apr 1, 2014
    900 ACE no power at outlet - GPS Talk
    Jan 15, 2014
    2013 Skandic WT 600 ACE - Skandic / Expedition
    Dec 22, 2012
    Battery Removal - Skandic / Expedition
    Apr 12, 2012
    More results from www.dootalk.com
Jan 24, 2016 | Ski-Doo 2014 GSX LE 900 ACE
My motor want to go over 8000rpm and he cut
Check the drive clutch spring and weights. there is probably something broke or wore out.
Feb 27, 2015 | Ski-Doo 2004 GSX Limited 600 H.O. SDI
Jan 30, 2015 | Winter Sports
How to change clutch buttons?
Clutch must be pressed apart. See your dealer for the tool.
Oct 17, 2014 | Ski-Doo 2007 GSX Sport 600 H.O. SDI
How to winterize a 600 e-tec 2012 ski doo expedition
your manual under the seat should explain how...
Manual says press high/low beam switch rapidly but what they don't say is, which is very important, don't press it so much that it clicks.
As in don't let the hi/lo beam switch click like it normally does when switching from hi to low?
I just fogged both of my etecs for the first time half an hour ago. I clicked the hi/low beam switch all the way rapidly and the "PUSH S" message never showed up. So I went back and switched it VERY RAPIDLY while holding the "S" button and it worked. As soon as "PUSH S" showed up on the display, I pushed the "S" button down until the "OIL" message popped up and it fogged and shut downicon1.png on que.
I friend of mine said he could never get his etec to self-fog. I think he wasn't pushing the hi/lo beam switch fasticon1.png enough for it to engage.
Hope this infoicon1.png helps.
May 17, 2014 | Ski-Doo 2012 Expedition SE 600 H.O. E-TEC
Pull cord not grabbing
The Dogs inside the Recoil are worn or Dirty is my first idea. But it could also be a loose Recoil also (This happened to me and my Ski Doo XP.
I purchased a new Recoil just to find out that 3 of the bolts were missing. Got new bolts and tightened it up and returned the Recoil. Ski Doo's Recoil Rebuild Kits do not last very long.
Nov 12, 2013 | Polaris 2010 WideTrak 600 IQ
92 dodge 1500 pick up 360 v8 automatic Starts, runs but hesitates, low power code 37 on diagnostic readour
Code 37 is torque converter clutch solenoid failure. Transmission wont shift in and out of overdrive.
Nov 28, 2012 | Dodge Cars & Trucks
Winter Sports Logo
146 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
vtrktrmn
Are you a Winter Sport Expert? Answer questions, earn points and help others
