Question about Air Tools & Compressors
What is the HP rating for an LG compressor model number ns30lacg
2 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: can't find compressor
The compressor is LG part number 2521C-A7256 which they have in stock. I believe this unit has a 7 year warranty on the parts of the sealed system (which includes the compressor) but this is most definitely not a do it yourself repair. Only someone certified to handle refrigerants, has the proper refrigerant recovery equipment, and charging equipment (and knows how to use them) should ever attempt to replace a compressor. Compressor failures are rare, and the unit should be diagnosed by a professional service technician, as most often your problem will not be the compressor, but some other issue. Please do not rate this solution as anything but a FixYa lowers my score.
Posted on Nov 30, 2008
What is the width of Kenmore 253.57188600 refrigerator?
Hello Chris;
My name is Peter. I am a retired field service refrigeration technician.
First, The 253 model is an LG. Stay away from LG and Samsung refrigerators. 70% of my service calls were for either LG or Samsung. A common problem; LG would have compressor overload failures caused by the compressor. I would have to change both the overload and the compressor. This was a $650 - $900.00 repair. The Samsung has the best looking unit on the market, with the highest component failure rate. Their televisions are great, but appliances!
Ok, your dimensions.
1.) You need to take a tape measure and measure the space. You need 3/4" on the top and sides for proper air flow. You also require 2-1/2" in the back. Take this information to where you purchase a new unit.
2.) Consider going to a Sears Outlet Store (Scratch & Dent). You save a couple hundred dollars and have a one year warrantee.
3.) Consider a Habit Store for a used appliance.
Ok, What brand do I buy:
1.) If you can afford it: Kitchen Aid, Amanda or Hot Point (Fewest service calls).
2.) GE, Kenmore (Model number 110.---).
I hope I have helped;
Peter
Nov 30, 2015 | Kenmore Side by Side Refrigerator
LG french door no cooling
Pull away from the wall and remove the panel near floor to expose the compressor. Feel the top of the compressor to see if cool, warm or too hot to keep your hand there. Tell me your findings. Is compressor clicking? Is the model number LMX25984 above your post correct?
Appliance 911 Sea Breeze
Aug 10, 2015 | LG LMX25984
Testors Blue Mini Modelers Airbrush Compressor
Air compressors are rated for a maximum pressure and maximum output flow. Your description implies more air is going out of the compressor than it's designed flow rate. Check for a major leak at hose fittings or around the compressor. If this is an old unit, a compressor gasket could be cracked or broken.
May 31, 2014 | Ingersoll Rand - Rand Type - 30...
What is the HP rating if a 3 ton air conditioner?
Hi, this depends on the compressor that is installed in this unit. It may be a Copeland scroll, a Tecumseh, its hard to say. Most compressors are around 2 hp for a 3 ton unit. On the data plate it will tell you the h.p. of the blower and condenser fan motors such as 1/4 h.p., or 1/3. If you can get the name and model numbers from the top of your compressor, you can call a a/c, Refrigeration parts house, wholesale and they will have it in there manuals. The B.T.U. rating for your compressor is 36,000. There are 12,000 BTU's per ton of cooling, this is something that almost no one knows, but now you do. If it were a smaller unit such as a 2 and 1/2 ton, it would be 30,000 B.T.U.'s. You can look at the model number of a unit and you will see numbers like this, 024, 2-ton, 030, 21/2 ton, and 036 a 3 ton unit and so on. Your compressor alone will be in the range of a 2 horse unit, which ever the brand of compressor they installed in it. Please don't forget to rate me on this as I know you will be kind. I will be here if you ever need help on repairs or trouble-shooting your unit in the future, just use my user name below.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Sep 04, 2010 | Heating & Cooling
I am looking at buying one but how do i tell what the hp is if not stated and how to find out the BTU thanks Jenine
With air conditioning, you want to go by BTU ratings, not horsepower. If you can get number straight off the compressor, an a/c supplies could get you an approximate BTU rating.
In most cases, the "Tonage" is in the model number.
Remember, 1 ton of cooling is 12K BTU's per hour.
Hope this helps.
Nov 21, 2009 | Refrigerators
I have a Sanborn Black Max 22 gal. compressor Mod#B109BLR300-22SWC. The motor is a Magnetic/Century 3 H.P. 115v Model 8-165730-20 Ser# BF-532 15A-7.5 RPM 3450. It is missing the run and start capacitors....
Sanborn/Coleman was bought out by MAT Solutions. A website I found lists Sanborn/Coleman compressors and parts but it does not show your model number. It does say, however, to email them with your model number and they will be able to find your parts for you. I have included the link for you here: http://www.mastertoolrepair.com/colemansanborn-portable-parts-freedirect-drive-electric-c-271_35_172_178.html
Sep 10, 2009 | Air Tools & Compressors
Need owners manual for devilbiss pro 4000 air compressor
Craftsman compressors are model numbers starting with a 919.xxxxxx Find this number and look it up on searspartsdirect.com. Some manuals are available for viewing without purchase.
Eric
Jul 30, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Compressor
Just have a local refrigeration store to match the numbers on the top of the compressor. It will go by BTU more than HP. Standard refrigerator uses 800 BTU's while side by sides use 1000 to 1200 BTU's..Sea Breeze
Jun 22, 2009 | Frigidaire FRS-26DR7D Side by Side...
Vinotemp 24 - keep hearing ticking sound
It's the overload protector thats gone bad. Remove the plastic cover on the side of the compressor( LG model NS30LACG). The OLP is the one on top. If you open it up you will find that it may have some burn marks from electrical arcing. The part number is on the side (P6R8MC). Do a Google search for it. It costs about 12 bucks.
Jan 12, 2009 | VinoTemp VT24-G 24 Bottle Wine Cooler
Can't find compressor
Nov 30, 2008 | LG LRSC26920TT Side by Side Refrigerator
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
