Question about Android HD Wifi Smart IPTV Box - Watch Video on Your TV
MX4 ANDROID TV BOX-How to move past "no command" and dead android guy with exclamation in android recovery mode to see recovery menu options after reset done from AV hole toothpick method.
How do i unlock my nexus 7 when its on the screen with android robot laying on its back?
Android robot laying down with a red triangle having an ...
https://androidforums.com > Forums > Featured Forums > Android Lounge
Mar 24, 2013 - 14 posts - ‎7 authors
Whenever i try to turn my android tablet on it displays android robot laying ... an exclaimation mark in a red triangle and dont let me proceed to its desktop . ... and holding it until it turns off and then turn it back on can revive it, ... no command error ' Android Forums
19 Jun 2014
HELP-Tried Recovery Reboot, Red Triangle w ...
15 Jan 2012
More results from androidforums.com
SOLVED: android guy on his back - Nabi Jr - iFixit
https://www.ifixit.com/Answers/View/349279/android+guy+on+his+back Oct 31, 2016 - my android guy on the screen is laying on his back with the stomache door ... Android recovery mode" and a few seconds later an Android robot ...
How to Fix The Dead Android and Red Triangle Error Symbol - YouTube
? 1:44
https://www.youtube.com/watch?v=58EPvbwPbe0
Oct 5, 2016 - Uploaded by Gauging Gadgets
Meaning of Green Android laying down and a red triangle with an exclamation point inside it: •If there is ... All ...
How to Fix The Dead Android and Red Triangle Error Symbol Android Recovery...
Jul 07, 2017 | Tablets & eReaders
How do I bypadd screen lockbon a moto g
Do a factory reset. This will erase all internal data though.
Switch phone off. Press and hold volume up button and then switch on. Should get a menu which allows factory reset. Use volume and on buttons to navigate menu.
Mar 17, 2016 | Cell Phones
Phone is stuck in no command. I
Hi if u see the android guy with his internal circuits and an exclamation mark no stress. You are in recovery mode press the power key once you will see options reboot now will be highlighted press vol up and your phone will start up normally.
Or you can pull the battery and put it in back and turn on ur phone :) hopes this helps
Jan 19, 2016 | Blu Studio 5.0 Mobile Phone
How do I factory reset my Motorola Moto G xt1028?
Eliu-
Follow the reset instructions here for your Moto G. Reset my device
Mark
Motorola Support
Apr 05, 2015 | Motorola Mobility Moto G 8 GB Black...
Wheni push input, i get the options but no arrow i push will move down to option to play vhs
not enough info , if your trying to change the tv input , make sure you select tv on the universal remote first , you either need to keep pushing input til it moves down to your desired input , or use the arrow key to move it down to the input. some require you to hit enter or ok to select , others just wait a second , it should change. if your getting the options menu when your hitting input , then the remote is not compatible with your TV / VHS / DVD...
If you get the input to change and your successful , make sure you hit VHS in order to call a command , if its still in tv mode , your only going backwards , make sure whatever your trying to control , the remote is selected to that device ... Good Luck ..
The Cable Guy .... hope that helps !!!
Mar 12, 2015 | RCA RCR314WR Universal Remote Control For...
I've had several issues but the one now is that all my tablet will do is show a pic of an android laying down with a red triangle on it bearing an exclamation mark. At the bottom of the screen it says NO...
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Oct 29, 2014 | Tablets & eReaders
Nabi jr has a green android laying on it's back with red exclamation make, want do anything. How do I fix it?
Oct 27, 2014 | Tablets & eReaders
Locked out
Enter Recovery Mode on Locked Android devices
  1. In order to succeed with these steps, you will need access to a computer or notebook.
  2. Your handset and its USB cable should also be there.
  3. Your phone must have USB debugging option enabled.
  4. On your computer Android SKD must be installed -> learn how to install Android SDK on Windows or learn how to set up ADB on MAC OS X / Linux.
  5. Connect your device with the computer by using its USB cable.
  6. On your computer navigate through the Fastboot folder.
  7. There open a command prompt window.
  8. On the cmd window type: "adb reboot recovery".
  9. Good, now your handset will automatically enter in recovery mode menu.
Nov 17, 2013 | Kocaso Pink NB726A 4GB Android 4.0 1GB RAM...
Recovery 32 type mismatch message
Step 1:
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer also Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file. Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
Feb 03, 2013 | Acer Aspire 4720 Notebook
Android HD Wifi Smart IPTV Box - Watch Video on Your TV Logo
548 people viewed this question
Top Android HD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Android HD Audio Player and Recorder Expert? Answer questions, earn points and help others
