Hi, my AW-9760S washing machine programming is not working properly. It washes, rinse but dose not spin automatically when set to REGULAR.gives error 5 (E5) I have cleaned the outlet n inlet.
  • 183 Answers
SOURCE: washing machine not spiining
sump hose filter blocked, running out of draining time, when you put it on again it allows more time to drain, remove sump hose and clean out internal filter.
Posted on Dec 25, 2007
aborcass
  • 2651 Answers
SOURCE: washing machine won't rinse or spin
sounds as if you have a faulty lid switch, for safety reasons if the machine doesnt think the lid is closed it willnot spin/drain the waer out.
Posted on Feb 23, 2009
  • 1294 Answers
The filter on your pump is probably clogged with lint and other stuff. Lift washer up a bit. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. Drain off excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water or a wet vac. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in.
Posted on Apr 01, 2009
ghost4548
  • 776 Answers
SOURCE: nec nw-891 washing machine will not complete the programmed cycle
Apparent malfunction in the timer circuits. Specific Component replacement not available.
Posted on Jun 30, 2009
SOURCE: Heller awm600 washing machine e2 error on spin
BROKEN PIECE OF PLASTIC ON LID CAUSING MACHINE TO THINK LID IS OPEN ALL THE TIME. REMOVE LID, WEDGE BROKEN UP SATAY STICK INTO GAP, REPACE LID AND VOILA!! WASHING MACHINE SPINS AND ALL FOR LESS THAN 15 MINUTES WORK AND A STICK!
Posted on Jan 10, 2010
My washing machine toshiba aw-9760s Kept showing this "E2 -3" problem. Whenever i close the lid to start washing my cloths. Anyone here can help me? In need of answers A.S.A.P
I also have a Toshiba AW-9790S, and encountered similar problem. The E2-3 would occur sporadically and halt the washing programme. E2-3 error occurs when the washing machine detects that the lid is not properly seated and locked during the rinse or spin cycles. I took mine apart and resolved my problem by cleaning the contacts for the switches. There are 2 contact switches at the lower right side; 1 for sensing the lid is closed and 1 for sensing that the lid lock is engaged. Both the switches were slightly oxidized which prevented current flow and the sensors from working properly.
Nov 02, 2013 | Washing Machines
I have been getting the Sd code and then F21 code during regular wash. I followed directions cleaning out white filter on bottom of machine and it did not help. So I followed directions for resetting the...
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
need to replace the part but dont try it if you dont have idea how to do.
call the technician for your safety and not to waste money.
Oct 30, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Second wash/rinse cycle for heavy loads must be engaged manually. is there a way to set it to start automatically?
Possible fault in the program controller unit. If the menu can be set up manually then select the wash/rinse or drying seperately and press start.
In most machines this is possible to override the program just in case the auto mode does not work orr the said program has errors.
Apr 19, 2011 | Washing Machines
My AW-1170S toshiba washing machine was showing error code E9-5...what does it mean?
my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
Nov 13, 2010 | Washing Machines
Hitachi washing machine. Model:SF-P90DJ Fault code F9
my hitachi model SF-120 HJ is washing machine cleck c2 n c4 warning stop f9..........
Jul 29, 2010 | Washing Machines
Whirlpool washer won't rinse or spin w/o manually turning knob
It is most likely that you have a faulty water inlet valve. Some machines have a seperate valve for rinse to flush in a fabric softener I suspect that your detergent flushing valve is faulty.....Good luck Nomess
Apr 23, 2010 | Washing Machines
Hi I have a auarius wma37 extra washing machine, It washes fine but just stops when it gets to rinse and spin. the drum drains to safe and the door will open. if I wait and change program to just rinse and...
Hi confused...It could be that your cold water inlet valve is faulty. Many machines will only rinse with cold water...No cold water...No rinse! Check that the machine actually is filling on the rinse setting. An inlet valve in not a big job....Nomess
Apr 05, 2010 | Washing Machines
Washes but does not rinse or spin . I think the pump is not working, it is not draining the water out of the washer which is causing the rinse or the spin to work would it be a switch or the pump
After wash the water drains out of machine automatically but its not drainout means the drain motor is not working properly or proper power supply is not given to the drain motor
Dec 22, 2009 | Washing Machines
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
