Question about Saws
The powa force Table saw never swithed on after i bought it new
    Top Expert:
  • 46,437 Answers
Then contact the company or the seller with the problem . we can not suggest a fix as that should be warranty work
Posted on Dec 21, 2016
Table saw won't start
You can only tell by using a continuity tester or a multimeter and some troubleshooting techniques.
Nov 10, 2013 | Powermatic 1791227K Model 64 10" Artisan...
Motor burn out Rigid R4510 table saw
Rarely you can get a motor that burns up because of bad internal parts and sawdust can lead to problems but motors are designed to handle and placed on the saw in a position to avoid heavy sawdust buildup. In my experience at my repair shop, most table saws that come in for motor repairs are directly attirbutable to using dull blades and making up for that by forcing the work through the saw. If you have a good quality, sharp/new blade and feed the wood into it at a reasonable rate, even a weak motor can get the job done.
Dec 18, 2012 | Saws
I have a 10" Delta table saw. It was running rough
Check that the blade is not warped or binding. Don't use long extension cords. Check your home breakers. Also check if the table saw has a breaker. Don't force lumber into the blade too fast and don't jam the lumber between the guide and blade. Try a different outlet and check your wire for breaks. Good luck!
Oct 05, 2011 | Saws
While cutting a piece of scrap plywood on my Craftsman 10" table saw, I accidentally cut through a bolt and it caused my saw to shut off. I pushed the reset button several times, but it doesn't feel as...
First off the saw will have to cool down and then the reset button will take some major force to reset. You should hear a distinct click when it does...
heatman101
Sep 20, 2010 | Craftsman 10" Table Saw
Saw is not cutting true / will not cut a straight line ?
Check blade is on properly. Remove blade and clean area where mounts to shaft. Make sure proper washers are in place. If blade is bent or wobbles replace. If blade is dull replace. Be sure you're getting enough water to saw. Don't force the tile through, let the saw do the work. Nothing helps any kind of saw more than a nice new blade.
Jul 01, 2010 | Diamond Products Mk - 101 10" Tile Saw
Angle lever stuck
I am surprised at that amount of wear in so little use.
Apart from that the first thing to try is WD40 on any stuck item. But don't over force the thing as you might break something
Jun 01, 2010 | Makita 2704X1 Electric Table Saws
Craftsman 10in Table Saw Model No. 315.218060 Dust bag
all the manual says is to insert the elbow onto the tube coming from motor and then install bag onto the elbow and for maximum performance empty the bag before it gets half full. On most table saws that I work on there is no fan or anything like that to force the dust away from unit, the best way is to run a shop vac and connect to the elbow for mazimum dust removal.
Mar 13, 2010 | Craftsman 10" Table Saw
I need to wire my Sears table saw 113298051...how?
Have a look at the manuals available here. Perhaps there' s one for your saw or a similar model with a wiring diagram you can use.
Good luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 28, 2009 | Craftsman 10" Table Saw
On/off switch
The contacts in the switch are burnt, replace them.
Sep 21, 2008 | Jet 708715PK/JTAS - 10X50 - 1PK 3HP 1Ph...
Saws Logo
49 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
