Question about Dell 1815dn All-In-One Laser Printer
Dell 1815 dn all in one
I have a problem scanning. I scan 5 pages and when I go to email the 5 pages, I have to attach each page separately. 5 attachments. Is there any way to send all 5 pages as one attachment. What I would like to do is be able to send 20-25 pages into one attachment. Can this be done by a dumb person, me?
    Scholar:
  • 122 Answers
When scanning a document it is common for the scanner to use a high resolution and color mode both of which increase the size of each scan. There is a limit on the size of an attachment which varies with your e-mail and or Internet provider. It is best to keep attachments as small as possible. You can change this in the settings menu going to black and white and setting the DPI (dots per inch) down from 300-600 to 150 or even 75 and the scan will be fine but a smaller file size. If you are sending color pictures you can make them smaller but the quality will suffer some and you will still need more then one e-mail but with adjustment of the settings you can reduce it to a minimum. I hope this is useful to you. Good Luck
Posted on Jul 21, 2009
On a Konica Bizhub c364e, how do you scan multiple pages and have them show up as separate files in your email or USB?
Go to Scan/Fax option.
choose your destination.
click on scan setting
on right hand side you will find option SINGLE or
SEPARATE/SEPARATION.
If separate or separation is selected/highlighted thats means all page will be scanned in single file.
if not selected then all single page will create separate file..
Dec 01, 2016 | Konica Minolta Bizhub C364 Color Copier /...
I have a Dell laser mfp 1815 dn. There is not an option to scan to a pdf. It will scan to a bitmap which is not what I need. How do I get it to scan to a pdf?
When you save the scan select pdf from the pull down menu "Select Type of Document" in the Save Dialog.
Hope that helps.
Jul 23, 2011 | Dell 1815dn All-In-One Laser Printer
I cannot scan a document to a single email
file type is probably set to single page. to set the file type to multi page do the following:
1.press the scan button on the op panel
2.select scan setting
3.select file type
4.select multi page multi page to have the entire scan job sent as a single file.
if you are scanning jpeg as file type they will only scan as single page docs only pdf and tiff can be sent as multi page files
Sep 18, 2009 | Konica Minolta bizhub C250 All-In-One...
Scan 5 pages. I go to email I have 5 seperate
you can do that by following steps 1.scanning all that pages and save them as different files in your computer. 2. open a word document and copy all the contents of the five different files and paste them in the word doc and save it 3. while mailing you can attach this word document to send all the files as a single attachment
Jul 21, 2009 | Dell Office Equipment & Supplies
Scanning several pages and saving as one document
Try this....
Scan your multiple pages to an image file, like .jpg, I know it's tedious, name them (optional) by page number, put them into an empty folder.
When you're done with all the scanning, open the folder, select all of them, open with: Preview.
Now, you should see one page, with a side bar containing all of the pages. (If they're not in order, you can drag and drop within the sidebar to reorder.) Select all of those (Or Command A)
Command P (Or Print)
In this window, you should see page one, and below that, make sure it says "Page 1 of XX"...this way you know you got 'em all, and it's your final opportunity to page through them all by clicking on the little arrows to make sure they're in the right order.
Click the PDF button
Save as PDF...
See if that helps
Jan 15, 2009 | Brother MFC 420CN All-In-One InkJet...
Dell 1815 dn prints lines in faxes going out
Dont think its your printer, try faxing to someone else and see if it happens there too.
Dec 11, 2008 | Dell 1815dn All-In-One Laser Printer
Dell 1815 dn printer scanner issue: single line appears in scans
Do you get the same line when you use the adf for other purposes?
If so, check the scanner glass just before the platen for something like white-out on it. Clean both the scanner glass and platen glass with Windex.
That is a common problem on all ADF scanners.
Good Luck
Nov 15, 2008 | Dell 1815dn All-In-One Laser Printer
Scanners
I bought a different printer.!!!
Aug 19, 2008 | Brother MultiFunction Center MFC-440CN...
That 1st solution looks like SPAM. You could google "Free pdf software" and find a program that would allow you to scan and convert the pages to a pdf file to email. But if you don't do it often enough to need this kind of program, here is the simplest method: Scan your pages to a folder. Begin to compose your email and click on "add attachment". Browse to that folder, open it, then use the "shift + click" method to select them all (first click on page #1, then while holding down "shift" click on the last page you want--this will select them all). Then click "Attach" and they will all be attached to the email as separate files.
Jun 20, 2008 | HP PSC 2210 All-In-One InkJet Printer
Single scan printers can be difficult in this manner.\
Consider using the OCR (optical character recognition) software that came with your scanner.
Basically the part of the software that asks you what you are scanning (picture, document, newspaper) and make sure to select document. This will enable the character recognition which will convert the scanned picture into a document that you can configure to go into Microsoft Word or Notepad or whatever. If you have multiple pages, it MIGHT give you the option to scan more than one page at a sitting. then again, it may not. In which case you might be kicking yourself for not purchasing the scanner with the auto feed attachment! Once you have made your scanned document in your word processor - READ THROUGH IT! may have converted characters incorrectly - like an "S" may be now a "$" it happens - and it will happen. When done, attach complete document to email and BOOM done.
Either this or use a fax machine :)
hope i helped!
Ryan
May 31, 2008 | HP PhotoSmart C4280 Laser Printer
Dell 1815dn All-In-One Laser Printer Logo
150 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
