Question about Saws
I bougt a brandnew table saw, i put it together and it doest work, what now?
  • 20 Answers
Check the receptacle for power. Also double check the voltage on the saw's nameplate. If it's supposed to run on 110 or 220 volts. Some saw motors are multi-tap and can be wired for both voltages. What kind of saw is it? Is it belt driven or direct drive?
Posted on Dec 21, 2016
Does not open Properly
doesnt sound right
what maker of table saw
all are designed to open safely and securely
May 10, 2016 | Saws
Centering saw blade
The most important thing is that the blade and riving knife are centered with each other. If not, you may have to shim the riving knife.
The bolts that hold the carriage under the table are intentionally sloppy so that you can loosen them and align the blade/knife with the miter gauge slots.
Lay a long metal straight edge against the side of a carbide blade teeth with the blade all the way up, and make sure the straight edge is parallel with the miter gauge slots in the table. Then tighten the bolts on the underside.
Sep 07, 2014 | Craftsman Contractor Series 10" Table Saw...
N eed a better manual or some help on putting my table together 36-681
http://www.ereplacementparts.com/delta-parts-c-3275.html
Apr 09, 2012 | Delta U30 30' Unifence
Looking for a manual for a Dewalt 788 scrol saw
I also have this saw and when I had a problem with it, I carefully just started to take it apart and found it to be a really simple item to work on. Don't be afraid to take it apart on your own, everything is very simple to take apart and to put back together. my saw would not respond at all when I turned it on after not using it for awhile and I got it working without having to put any money in it.I also was not able to get it to put tention on the blade and again no problem for me to fix at no cost...simple, easy machine.
Dec 23, 2010 | Dewalt DW788 Heavy Duty 20" Variable Speed...
While transporting the table saw, the vibrations caused some of the parts to come apart and I am not sure how they go back together and if I have all of the parts. Is there a diagram or manual I can get to...
If you go to www.ereplacementparts.com they have some excellent parts breakdowns that show exploded views of your tool. It will give you a good idea of what goes where and is also an excellent place to get any missing parts.
Dec 17, 2010 | Ridgid Heavy Duty 10" Portable Table Saw...
Want to replace under powered saw motor on sears 10"table saw
u can put a 2 and above if u want just need to have the correct rpms
Jan 26, 2010 | Craftsman 10" Table Saw
I have a Skil 10'' table saw that will not power on.
If your switch is in the base of the machine, like some portable table saws. The switch may be full of saw dust. I hade one that the reset switch couldn't be pushed to reset because the housing was packet with saw dust. I simply opened the cover and vacuumed it out. If you open your switch box up and it is clean inside, your switch is probably bad. You can check it by taking the two wires off your switch (with the saw unplugged of course) and taping them together, if the saw works when you plug it back in, get a new switch.DON'T use your saw wired this way.
Mar 26, 2009 | Saws
Saws Logo
50 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
