Question about HP Scanjet 8350 Flatbed Scanner
Hp scanner 8350 error 05 PROBLEM - HP Scanjet 8350 Flatbed Scanner
Printer error 05
msybe in out..or ribbon stuck
Jan 29, 2014 | HP ScanJet 8270 Flatbed Scanner
I having hp scanjet 8350 scanner+adf its not scanning and automatic document function also not working but when i disconnect the adf /tma cable the flatbed scanner start working perfectly but again when i...
Thank you for writing a complete question that we are able to understand. It's nice to see a well worded question on here for a change.
To answer your question, this sounds like either a driver or firmware problem with the scanner. You can download the latest driver for your scanner from the HP support site here (click here) and download the available firmware upgrade for your scanner as well from the same location.
I would check to make sure that you have the latest driver first, and install that first if you do not. Then I would install the firmware upgrade immediately after, since it seems to fix the error that you are experiencing:
"Scanner hangs and does not respond when scanning many pages from the flatbed."
Good luck and thanks again for the well worded question!
Feb 13, 2012 | HP Scanjet 8350 Flatbed Scanner
Lost instalation CD without instalation what i do
Go to this site courtesy of HP:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=1118281&lang=en&cc=us&prodTypeId=15179&prodSeriesId=1118290&taskId=135
Choose your operating system and download the software. Go ahead and install it and then your printer should start working again.
May 19, 2010 | HP Scanjet 8350 Flatbed Scanner
I can get it work, I install new drivers and adobe 9 but it's not working at all
adobe 9 version as some conflict with HP softwares, install adobe reader 7 or below and I am sure that will work,
HP is under process if finding a patch.
Sep 29, 2009 | HP Scanjet 8350 Flatbed Scanner
2840 Hp Color laser jet displaying Scanner error 05
The book says to try the old power off and on. And then replace the scanner assembly and then the formatter.
Personally, I would try the formatter.
Sep 26, 2009 | HP LaserJet 2840 All-In-One Printer
HP Scanjet 8350 is only scaning in Black and White. It is supposed to be able to do color. Is there a setting that needs to be set?
Use the HP product assistant to adjust the settings. Look in your start menu>all programs> HP etc., or on your cd, or you can download the full feature software package from here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 17, 2009 | HP Scanjet 8350 Flatbed Scanner
Problem scanning multi page document
You do not say which software you are using but if you can afford PixEdit you can save to multipage tiff, Pdfs and so on. Also combine singlepage and mulitpage documents to one mulitpage and vice verca.
May 05, 2009 | HP Scanjet 8350 Flatbed Scanner
Hp scanjet 8300 error ROM CODE FAILURE DOWNLOAD FW
hp scanjet 8350 error ROM CODE FAILURE DOWNLOAD FW==== pl. help me
Nov 02, 2008 | Office Equipment & Supplies
HP Scanjet 8350 Flatbed Scanner Logo
160 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
