Question about Radio Communications
I cannot connect my bluedio Bluetooth headphones to my iPad. Help! Linda
4 Suggested Answers
SOURCE: i have just bought my bluedio u9 headphones,
I am using bluedio AV890, for me it is not even detecting on my laptop and tried desktop with bluetooth dongle as well no luck. my pc and laptop could detect each other but not this AV890 handsfree.
Has anyone tried this with laptop ? and if it worked could you let me know how ?
Posted on Apr 24, 2010
SOURCE: how to reset bluedio av890
very simple...hold the call button and the play/pause button while startin the unit up...the led will blink blue thrice and will continuously stay on confirming the reset mode...u can now view the headset as AV890 on ur phone or pc....the code is 0000...confirm it and the connection is authenticated...done...q.e.d
Posted on May 31, 2010
  • 5 Answers
SOURCE: bluedio av890 is not detected............
It is very simple yaa. Instructions are given in the user manual itself.
Switch off the Head set first. Press and hold the On-Off/call/answer key for few long seconds. First the blue light on with blinking. Don't release the switch, hold it further. Then the blue light stops blinking and shows a steady/stable/permanent glow. Now try from your mobile phone with blue tooth set to on. Search for items. On getting the indication of AV890s presence press "connect" switch. Password or Code to connect is "0000" (four times zero).
Now AV890 IS CONNECTED TO YOUR CELL PHONE. O.K.
MUTHUPETCHI V- MADURAI (muthupetchi008@gmail.com)
Posted on Oct 08, 2010
Pairing my Bluedio headphones to my computer
To pair your Bluetooth headset to a Windows computer:
  1. Make sure your computer's Bluetooth chip supports the Headset or Handsfree Bluetooth profile (if your computer has a data-only Bluetooth profile, you cannot pair your headset to it).
  2. Place your headset into pairing mode.
  3. On your computer, click Start, and then click Devices and Printers. Note: Depending on your computer's configuration, you may first have to click Control Panel, then Devices and Printers.
  4. Click Add a Device. The Add a Device windows appears, and immediately starts searching for your headset.
  5. When your headset appears, select it, and then click Next. Windows connects to your headset.
  6. If prompted for a passkey, enter "0000" (four zeros), and then click Next.
  7. Click Close.
  8. If necessary, right-click the headset icon, and then click Connect.
Oct 16, 2017 | Bluedio Audio Players & Recorders
Can I pair my Bluetooth earphones to my iPad?
How to pair Bluetooth headphones to IPAD?
Most headsets have a power button or a switch to turn the device on. Press the "Pairing" button on your Bluetooth headset, if necessary. Select your headset from the Devices list on the iPad's Bluetooth window. Enter the passkey or PIN for your headset, if prompted.
Does the iPad Pair With Bluetooth Headphones? ' Chron.com
smallbusiness.chron.com/ipad-pair-bluetooth-headphones-62883.html Search for: How to pair Bluetooth headphones to IPAD?
Dec 05, 2016 | Radio Communications
How do I connect my wireless headphones to my ipad
You go to your IPad Settings, make sure Bluetooth is on.
then turn on your headphones. You should see the headphones appear in Bluetooth list. ( see my example , I have a wireless keyboard that I have turned off but is paired).
Your headphones may have a button you need to push but not likely.
Oct 04, 2016 | Audio Players & Recorders
Can not connect to a laptop
Could be the laptop needs a driver installing for it to work.
Conventional bluetooth and wireless needs a 2-way signal so the item you want to connect will appear in the laptop wireless and bluetooth menus and you can click on it and enter a password or pin number.
If the headphones don't appear in the menus you won;t be able to connect them. In that case you should refer to the headphone instruction manual.
Apr 16, 2016 | Bluedio Model R - Wireless & Bluetooth...
Can I pair Bluedio Q9 with Bluetooth transmeter?
all depends on the quallity and age of the transmitter, go to youtube ad type in the make and model of the transmitter and chances are someone there will have posted a video instruction for it...
thank goodness for egos ;-)
May 17, 2014 | MOBILESW Bluetooth Stereo Headset Bluedio...
Bluedio super mini
Go to the menu bar at the top of the screen and locate the Bluetooth utility. Link with the device and you can access it just like any other drive, Transfer your files. Itunes may be able to do this for you. Otherwise go to system preferences, locate bluetooth and follow the same procedure.
Jan 03, 2014 | Apple Computers & Internet
I can't figure out how to get music onto sd card for Bluedio R headset
  • The MicroSD Card format needs to be FAT32.
    32GB max for the H+ and 64gb max for the R
  • It works better to use your own card reader to do file transfers.
  • Documentation says that with the unit powered on, you hold down the wheel button to enter SD Card mode. (Light goes green)
  • Windows will install some generic SCSI drivers and a new removable drive should show up in Computer
    Then you can copy files over the USB connection.
Dec 31, 2013 | Bluedio Model R - Wireless & Bluetooth...
I have just bought my bluedio u9 headphones, connects perfectly to my phone but with my laptop it connects but i cant get any audio from music or movies. HELP PLEASE
Feb 13, 2010 | Radio Communications
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
