How to repair my machin riso cz100. IT INDICATES THAT P-13 AND THEN -234
3 Suggested Answers
  • 1751 Answers
SOURCE: how to solve erow code
Hi
You need to replace motherboard of your printer
the cost of it is to high
you better replace your printer
Pls vote me to keep me alive
Posted on Nov 25, 2010
ZJLimited
  • 17970 Answers
SOURCE: error code P - 98 - 934 on RISO CZ100
You need to replace motherboard (P-98 error) of your printer the cost of it is to high, then I suggest value this repair or replace your printer.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Posted on Nov 07, 2011
What are the Details in giving a Riso Ez590 a general service?
see page 214 of this service manual.
http://us.riso.com/wp-content/uploads/assets/manuals/a0LA0000001gAtiMAE.PDF
Maintenance Cleaning The print quality may suffer if parts such as Thermal Print Head of the Master Making Unit, Scanner Glass of the ADF unit (Option), White Roller, etc. are contaminated with dust, dirt, ink, white-out, etc.. Follow the steps below for periodic cleaning. AWARNING: • Before cleaning any part of the machine, turn off the power. • Do not remove any fixed covers. • Contact your service representative immediately if you suspect any dangerous situations or have questions or problems with the machine. • Contact your service representative before moving the machine. • Do not allow unauthorized persons to make adjustments or repairs. BCaution: • The machine has precision moving parts inside. Do not handle the machine in any other way than described in this manual. • Be careful of the edge of metal parts, otherwise it may cause an injury. • Do not make any modifications to the machine or remove any parts. • Neither RISO nor its dealer is responsible for maintenance service performed by non-RISO-authorized personnel. etc...
Jun 10, 2017 | The Office Equipment & Supplies
How to fix Riso CZ100 error code h 101
1. Double click on ur start key to go zero on display panel. Machine will Ready to printgood luck
2. You need to input the value on the machine for the ink color the value is 1-black or 2-color
you need to go into service mode the go to 890 and input what color of ink the drum is weather its black or color and that should get rid of your issue
3. The machine either has "knock off" ink (generic) or "knock off" masters (generic) installed in the machine.
Try installing Genuine Riso ink and masters and the problem should be solved.
Apr 05, 2017 | Office Equipment & Supplies
Where do i hook the brown wire to clarion cz100
The brown wire is probably phone mute. You don't really need to attach it to anything for the radio to work.
Dec 04, 2011 | Clarion CZ100 Car CD MP3 Player
Error code P - 98 - 934 on RISO CZ100
Nov 07, 2011 | Riso RZ220 Duplicator
Riso cr 1610 error code E-22
The E error code indicates that it is a logic or electronic failure and will requires a service person to service it. Sorry I couldn't locate anything more helpful.
Have a great day.
Jul 08, 2011 | Office Equipment & Supplies
How to solve erow code in riso machine model cz100 the error code show that P-947 98
Hi
Nov 25, 2010 | Office Equipment & Supplies
Installed cz100 radio sounds great, cd loads & reads but no sound???
are you using an amplifier? if so, it sounds like you are using the blue (antenna remote turn on) wire instead of the blue/white (amp remote turn on) to turn the amp on.
Nov 16, 2010 | Clarion CZ100 Car CD MP3 Player
Error E16 RISOGRAPH CR1610
E16 indicates a motor lock with the inking motor. Disassemble the ink pump unit and check for proper rotation of the inking motor itself. This error is caused by a current overload.
Also, remember to try powering on the machine while holding down the reset key to clear all error codes first.
Feb 13, 2010 | Sharp AL 1631 Copier
Riso GR3750
T2 indicates an elevator motor failure. Take off the back cover and check the lower limit sensor for the paper tray to make sure its not full of dust.
Reset can be done by holding the reset key down during power up.
Test mode is entered by holding down LINE/PHOTO and the M/P buttons during power up.
Test mode# 102 tests operation of the elevator motor.
Aug 27, 2009 | Eagle Signal Br1 30min Reset Timer
Riso RP 3700 indicates that the master is still on the drum halfway throught the master making process and shuts down. The master has been removed. shutting down the machine does not help. Rolling on a new...
Remove the roller on which the master has been created. That will force the machine to start a new cycle. Right now the machine has thinks its in between the cycle, so to synchronise both, its been told to remove the master. Switch it off & then begin again........sodeep
Aug 10, 2009 | Riso RZ220 Duplicator
21 people viewed this question
k24674
