Question about Bose Audio Players & Recorders
My Bose 525 series iii home system continuously shows the following message You've made some connections to Input 5. Would you like to set up the new device now?. No new devices have been added.
  • 65 Answers
SOURCE: Bose stereo System
I would suggest checking the owner's manual on what the button does, but you could always buy an FM Transmitter hook it up to your Zune and play music from an empty station.
Posted on Apr 03, 2009
SOURCE: Apple TV and Bose Home Theater
I had the same problem.
I could not get HDMI to HDMI to work.
i fixed it (work around), by connecting ATV HDMI to DVD HDMI port on V30, i then connect L&R to AUX.  I set the Bose remote for controlling ATV to AUX.
so to use ATV with Bose remote i know press DVD, this gives me the correct display but not audio, i then press AUX and this gives me ATV control and audio.
interesting, when i first set this up (trial and error), it didn't work.  I was doing some cable management clean up, when i got a fright and the thing started working...but i have a ghost in my house so that is probably a more plausible reason why its working now.
it feels like this product is only 90% finished
Posted on May 26, 2009
  • 19 Answers
SOURCE: Can I connect my Bose Acoustimass 5 - Series II to Bravia unit?
Yes, there should be no issues using your Bose speakers with your Sony receiver. Sony has a "hookup guide" to help here -
Please rate my answer, thanks.
Posted on Jun 18, 2009
SOURCE: My Microsoft Bluetooth Mouse will not stay connected to my system
1. Go to Start->Run and type in "services.msc" and click OK
2. Find "Bluetooth Support Service" in the list of services and double click to open the properties window
3. Click on the "Log On" tab and select "Local System Account" for "Log on as:"
4. Click Apply and OK
5. Right click on "Bluetooth Support Service" and select stop then right click on "Bluetooth Support Service" again and select start
6. You may need to reconnect your bluetooth devices; everything should be working now.
Posted on Mar 09, 2010
  • 10 Answers
SOURCE: Bose audio input receiver cable 15 pin
You can buy it on ebay but it's cheaper just to make one. If you can solder, all you need is a female 15-pin d-type connector and a bunch of speaker wire. Here is a diagram of the connections.
Posted on Mar 22, 2010
Have a Bose 3-2-1 Series III. When I put in a DVD, I get sound through the Bose but no picture on my Pioneer TV. This is the second time it has happened. The first time it, we managed to get it going...
Here are 3 things to try and an if all else fails at the end.
1) Make sure the TV is set to the correct Video Input to see the video from DVDs on the Bose system.
• Make sure a DVD is in the disc tray.
• If the TV is connected to the media center using the HDMI cable:
Switch from one Video Input to another and then back to the original input.
2) Turn everything off, then:
Turn on the TV and set the TV Video Input for the Bose system video.
Turn on the Bose system and press DVD.
3) Turn off both the TV and the Bose system and then:
Unplug the HDMI cable from both ends.
Disconnect the power cables from both your TV and the Bose 321 system.
Re-connect power to the TV and to the Bose 321 system.
When the Bose 321 system startup message disappears from the display,
re-connect the HDMI cable to the TV then Bose 321 system.
Turn on the TV first, then turn on the Bose 321 system.
If all the above fail then disconnect the HDMI cable that connects the TV to the Bose 321 system and reconnect the two using a Component cable, an S-Video cable, or the Composite cable provided with the system.
Please leave feedback
Apr 28, 2011 | Bose 3·2·1 II System
Is there a current model receiver that I can puchase to drive my existing subwoofer and 5 speaker set? My Series 5 died.
How to connect Bose Acoustimass 25 series II subwoofer to Denon Receiver using factory provided 13pin cable
Oct 25, 2009 | Bose Lifestyle 25 System
Bose Lifestyle 38 connection to TV doesn't work.
Is your tv hooked up to your cable box or satellite with an HDMI cable? There are several ways to input to the TV.
Aug 30, 2009 | Bose Lifestyle 38 Series IV DVD Home...
Ive got bose lifestyle model 5 system and have just bought a samsung led tv, how to I connect up the bose to the tv??
There should be an AUDIO OUT left and right rca input/output plugs on the back of te TV; according to this, ( the inputs for the audio are right next to the FM antenna port/plug so, if you have one of these; ( just plug them in to the AUDIO OUT on your TV, and into the INPUT on your Bose system.
Aug 12, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Our Bose lifestyle 5 has no sound does the Bose CD disk restore the sound card. Mfg.1997 too old to do this must we buy a new one or does this cost a lot for repair ?
This can be repaired of it's later than a series 1. (not sure if the 1997 model was a series 1) Repair cost will be $225 plus tax (flat rate). Shipping is split between you and Bose. They give you a new 1 year warranty.
Otherwise, Bose can have you trade this in for about 25% off a new, current system.
-If this still powers up, make sure the small 1/8" portion of the input cable (plugged into "system control 1") is in good condition, because you may just need to replace that input cable for a no audio situation. If it's a different series, it will say "zone 1" I think.
In either case, you should call Bose tech support about this. (800-367-4008) Make sure you're with your system so they know what series of LS5 this is.
Jul 17, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Ipod nano connector for Bose 321 GS Series III
OK! The cheapeast and most simple way would for you is to get a 1/8th inch conector jack that adapts into red/white RCA jacks (it will have a couple feet of wire in between the jacks) plug the 1/8 inch adapter into the jack on I-POD and the RED/WHITE ends into the back of your systems aux inputs RED/WHITE! OR tape input ect! make sure I-POD is turned up! and you may have to adjust I pod eq to get the best sound out of system! (OH you can get this adatper at any radio shack or wall-mart!)
Please take a second and rate this response
Jan 19, 2009 | Bose 3 2 1 Series I DVD Home Entertainment...
Bose Acoustimass 8 pin Cable
Bose Lifestyle 3 or 5 not sure which. DIN 8 pin to 2 RCA's
Sep 11, 2007 | Bose Acoustimass 10 III System
42 people viewed this question
Top Bose Audio Players & Recorders Experts
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
