How to repair may RIZO CZ100 duplicator machine? it indicate number 6 at the screen so represent number 6 please help me
2 Suggested Answers
  • 81 Answers
SOURCE: error code d-17 in rizo rz 200ep
remove master from the drum and reset the master in the master making unit
Posted on May 26, 2010
How to repair Riso cz100/180 error code P15-218
this problem not solve paper not goin to scane
Jun 02, 2014 | Riso RZ220 Duplicator
Machine says paper jam in # 6....where is that
For a more detailed error msg press the star ( # ) key. It will represent which sensor is detecting the error.
May 06, 2013 | Riso RZ220 Duplicator
Rizo ez200E p12-309
Error type P12: System ErrorError point 309: Master-compression-motor encoder sensor count did not change as the master compression motor activated in the compress direction and moved out from the home position.
Try this: Press reset-key. If recovery fails you machine needs service.
Sep 19, 2012 | Riso RZ220 Duplicator
Error code P - 98 - 934 on RISO CZ100
You need to replace motherboard (P-98 error) of your printer the cost of it is to high, then I suggest value this repair or replace your printer.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 07, 2011 | Riso RZ220 Duplicator
Power Light does not come on when plugged in. I have tried many different outlets. Is there a fuse some where?
• If problems with projection do occur, but the indicators do not show any abnormal conditions, please refer to the section "When the indicators provide no help" on the next page.
• If a condition occurs which is not listed in this table, please consult your dealer or see Where to Get Help to contact EPSON.
• If you follow the above steps and are still unable to correct the problem, please cease using the projector, unplug the projector from the electrical outlet and request repairs from your dealer or see Where to Get Help to contact EPSON.
Where to Get Help
EPSON provides technical assistance through electronic support services 24 hours a day, as listed in the following table.
Telephone Support Services
To use the EPSON PrivateLine Support service, call (800) 637-7661 and enter the PIN on the included EPSON PrivateLine Support card. This is the fastest way of speaking to a live representative, and it's free. This service is
available 6 AM to 6 PM, Pacific Time, Monday through Friday, for the duration of your warranty period.
You may also speak with a projector support specialist by dialing one of these numbers:
? U.S.: (562) 276-4394, 6 AM to 6 PM, Pacific Time, Monday through
Friday
? Canada: (905) 709-3839, 6 AM to 6 PM, Pacific Time, Monday through
Friday
Toll or long distance charges may apply.
Dec 08, 2010 | Epson - PowerLite S1+ Multimedia Projector
We have a Rizo 220 ui with an error message
The rear cover may be off. Or you may have a bad cover switch.There are two switches at the top of the back coverone on the left and one on the right. Hope this helps.
Jul 14, 2010 | Riso RZ220 Duplicator
Error code d-17 in rizo rz 200ep
Nov 30, 2009 | Riso RZ220 Duplicator
My rizo 220 wich cannot pull a muaster roll
Normally when this model does not feed the master,there is a drive band jump off it place n the master drive unit.To correct this open the front panel of the master making unit and check that all the drive bands is in place.I am working 10 years with Riso and this machines is the best I ever worked with.
Nov 26, 2009 | Riso RZ220 Duplicator
Rizo RZ220UI drum will not go completely back into machine
the drum fits into a drive cog on the back side
pull the drum out look at the way it is inset and push back in with pressure and rotate until it goes in a little farther then you should be able to close the door
ther should be some type of latch or knob to turn when you get the drum in positon
Good luck
Jan 07, 2009 | Riso RZ220 Duplicator
27 people viewed this question
k24674
jasbo
jasbo
