Question about Garden
My head immediately starts to rotate on my em4251 makita power trimmer. I can not seem to be able to adjust the idle to slow it down
    Top Expert:
  • Garden Master
  • 49,327 Answers
If the start cord is on the shaft side of the motor , there is no centrifugal clutch to break the rotation of the head so the idle speed is not the problem
it is a design problem and you can move on to a better unit that does have a clutch
Posted on Dec 21, 2016
Weedeater starts but won't run for more than 30 seconds
A lot of times the line that in the tank deteriorate so you mean may need to replace the line in the fuel tank
Aug 12, 2014 | Makita Em4251 24.5cc Gas Powered String...
Weedeater starts but won't keep running
Grow a third arm or have someone follow you pumping while you trim :-).
The fuel pump is part of the carburetor body. You could disassemble it and see if something is stuck in one of the flappers that make up the pump or it may be broken and need a replacement. It's just a thin plastic piece in there that makes it pump using engine vacuum pulses to drive it.
What kind of oil do I put in my 4 stroke
10w30 is a base line oil for 4strokes. Hope that helps!
Sep 14, 2012 | Makita EM4251 16" 4 - stroke String...
Makita 4 stroke
not sure if there is a carburetor kit out there for that machine, but it sound like your having fuel issues, would suggest a rebuild kit or replacement..
Dec 14, 2011 | Makita EM4251 16" 4 - stroke String...
Tk carb ? sthil trimmer has 3 adj screws ,how do you adj?
One adjustment screw (probably Phillips-head) is the Idle speed adjustment screw. Turn it in, to increase idle speed (it moves the throttle plate)...turn it out to slow idle speed down. The other 2 screws are the Low mixture screw and the High mixture screw. The L screw is closest to the engine and is used to adjust the engine at IDLE. The H mixture screw is to be adjusted when the engine is at wide-open throttle to get the proper RPM's....not too little and not too much. Here is a tutorial by Zama carburetor reiterating what I have just told you and HOW to go about your adjustment.
http://www.zamacarb.com/tipspage.html
Sep 11, 2011 | Garden
I have a troy built string trimmer. will not start, no spark. have checked the kill switch and it's ok. Would the module be the next thing to check? Thanks
the pick up that runs beside the flywheel would be the next place to go, if there is a module you might just replace module and pickup together..
Jun 17, 2011 | Makita EM4251 16" 4 - stroke String...
My trimmer is about 8 years old. It has worked well with minimum servicing. I change the spark plug and air filter annually and it starts without much problem - other than it races with or whout my hand...
Try backing off on the Idle Speed Adjustment screw. Most all of them on these machines are Philips head and they press against the throttle plate on the carb so you can adjust idle speed once the carb is tuned correctly. The correct idle speed is set when the string head does NOT turn.
Apr 19, 2011 | Garden
Makita gas trimmer RBC221. engine runs fine but trimmer head does not turn.
would suggest that the cable that runs the head is broken or there is too much material wrapped around the head... remove the engine off the trimmer and check the cable that runs to the head....
Apr 07, 2011 | Makita EM4251 16" 4 - stroke String...
Can I re-string the trimmer head or do I have to buy a whole new one. I have aEM4251CA string trimmer
You can restring it. If you don't have the manual to show you how to do it bring the head with you to a tool hire shop that deals in garden machinery and they'll supply it and show you how to fit it.
Jan 09, 2011 | Makita EM4251 16" 4 - stroke String...
Cutting head on 29cc trimmer will not stop rotating at idle,cleaned filter,changed oil, cleaned spark arrester, tried adjusting idle speed, nothing seemed to help
You didn' t list the model number. Have you tried placing the head on the grass? does it stop then? It has a centrifugal clutch, if the idle speed is too fast, it will spin. There could be a broken spring or dirt in the clutch keeping it engaged.
Jul 26, 2010 | Craftsman Garden
Garden Logo
56 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
