Question about Sharp Office Equipment & Supplies
WHAT IS F2 SHARP AR 5620SL
PHOTOCOPING
marsrover
  • 682 Answers
SOURCE: request service manual for sharp AR-5316
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=7b292ec58f421b3b3b442c1437984770&q=Sharp+AR-5316
Posted on Apr 19, 2008
  • 148 Answers
SOURCE: F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
Posted on May 26, 2008
  • 87 Answers
SOURCE: F2 ERROR CODE
WHEN F2 FLASHES JUST PRESS START KEY U WILL RECEIVE A SUB CODE.IF SUB CODE IS 02 THIS IS TONER SUPPLY PROBLEM IF 04 THIS IS DATA PROBLEM LIKE AS IDENTIFICATION PROBLEM MODEL ERROR TYPE ERROR.BYMIAN AKHLAQ
Posted on Dec 18, 2008
  • 190 Answers
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Posted on Jan 27, 2009
SOURCE: I have a Sharp AR-507. Error F2-00. How to fix?
It could also be the sponge roller in the toner hopper. The old ones started to deteriorate after a while so sharp modified them.
Posted on Jun 17, 2009
Sharp ar-5620sl, how can i do when error code h4 displyed?
you need to reset the error its telling you that your fusing unit is not ok
Jun 01, 2016 | Sharp Office Equipment & Supplies
How do i attend to photocoping while red triangular light is blinking?
The triangular light means it needs toner or if there is a line under the triangle the waste toner needs to be emptied.
May 24, 2016 | Sharp Ar-5316 Advanced Digital Imager...
What type of developer is used in a Sharp Ar 5620sl?
Developer is changed by a technician. not customer replaceable.
Mar 31, 2015 | Sharp Office Equipment & Supplies
F2-64 on sharp AR-5318
sharp ar 5618 zerox machine in f2 64 error solution
Aug 04, 2012 | Office Equipment & Supplies
Sharp AR 5618S Error F2
Hope this help.
Hold down the copy start button
You will get F2 flash then 2 numbers will flash
http://www.manualslib.com/manual/902246/Sharp-Ar-5618.html?page=55#manual
Jul 06, 2012 | Sharp Office Equipment & Supplies
My Sharp Copier Model AR-M160 showing f2 error even I replace the new tonner.
Below are the F2 errors and causes for Sharp AR-M160
"F2-31" Image density sensor fault
"F2-32" Drum mark sensor fault
"F2-33" Grid voltage correction problem
"F2-35" Grid voltage correction problem
"F2-37" Drum mark sensor fault
Cause : CRUM chip defect OR Improper developing unit
Check and remedy : As you have already replaced the tonner, we can suggest Replace the CRUM chip,Replace the developing unit
Regards,
Shrey
Jun 01, 2011 | Sharp AR-M160 Laser Printer
AR 5516S SHARP COPIER IS SHOWING F2 4O FAULT CODE DURRING INSTALATION. WHAT COULD BE THE CAUSE. PLEASE.
During installation , use sharp ar205 developer and sharp ar021 toner cartridge. This shows you did not use developer or used the wrong ones, good luck.
Mar 12, 2010 | Sharp AR-5320 Black and White Copier
My Sharp AR-287 Copier is showing F2 error
there Should be 2 additional numbers. F2-??
Oct 29, 2008 | Sharp AR-235 Copier
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
