Question about Cell Phones
Whats 4 numberpin 80893 Whats 4 number pin 80893
Login gmaili want too fiind pin code for my phone num 0879254546
Open a Web browser and go to Click "Gmail" at the top of the page.
Click the "Create an Account" button.
Enter the information requested in the text fields, including your "Desired Login Name." Click the "Check Availability" button. Select another name and try again if your first choice is not available.
Enter your primary email address in the "Recovery Email" field.
This is not mandatory, but it will allow you to reset your password should you forget it.
Read the Terms of Service, Program and Privacy Policies, then click "I Accept.
Create My Account."
Getting Google Phone Number
Go to and click "Try It Now" to install Google Voice to your Gmail account. Click the "Get a Google Number" button.
Enter an area code or ZIP code in the first text field to search for an available number in your area.
Alternatively, type a word or name in the second text field to search for a number that matches that word on a telephone dial pad.
Click "Search."
A list of available numbers is displayed with area codes and locations for that area code.
Click on the telephone number you want, then click "Continue."
Type a 4-digit personal identification numberPIN and confirm it by typing it again, then click the box beside "I Accept Google Voice's Terms and Privacy Policy" if you agree.
Type a phone number that you want to ring when you get a call using your Google phone number.
Click "Continue."
Verify the phone number by clicking "Call Me Now."
When the phone rings type the code you see on your screen into the telephone dial pad.
Click the "Done" button.
Dec 08, 2013 | Computers & Internet
How to unlock phone if forgot password nokia c5-03
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Sep 30, 2011 | Nokia C503 Cell Phone
Whats the pin for my phone lg pop gd510
Try the last 4 digits of your phone number or four 0's.
Mar 10, 2011 | LG GD510 Cell Phone
Whats my pin to verify my mobile number...? i'm from India- bangalore city
I need pin to verify mobile number
mobile number is 9637408200
Feb 05, 2011 | Cell Phones
I am trying to troubleshoot whether or not my ultra x2 connect 550 watt power supply is bad. When you press the power button on the computer, the light flashes and then noth9ing else happens. The light...
Well here is a way to check your power supply, on your hard drive connector using your volt meter and measuring from ground. this would be using one of two middle connectors it should measure +5 VDC on the red wire and + 12 VDC on the yellow wire. If these voltages are good then we got to see if the power supply is producing the -12VDC voltage. This voltage is ussed by the syustemboard on pin 14 of a 24 pin power supply. I would recommend not having your system board plugged in while measuring these votlages, but the power supply may need a load, I would plug in the cdrom.. Below are a couple of picture to explain this and a link to a website that has this documented.
dfish26_1.jpg The 24 pin main power connector was added in ATX12V 2.0 to provide extra power needed by PCI Express slots. The older 20 pin main power cable only has one 12 volt line. The new 24 pin connector added one line apiece for ground, 3.3, 5, and 12 volts. The extra pins made the auxiliary power cable unnecessary so most ATX12V 2.x power supplies don't have them. The 24 pin connector is polarized so it can only be plugged in pointing in the correct direction.
Pinout Pins 1 through 12 Pins 13 through 24 Description Wire color Pin number Pin number Wire color Description +3.3 volts orange 1 13 orange +3.3 volts +3.3 volts orange 2 14 blue -12 volts ground black 3 15 black ground +5 volts red 4 16 green PS_ON# ground black 5 17 black ground +5 volts red 6 18 black ground ground black 7 19 black ground PWR_OK gray 8 20 white -5 volts (optional) VSB +5 volts purple 9 21 red +5 volts +12 volts yellow 10 22 red +5 volts +12 volts yellow 11 23 red +5 volts +3.3 volts orange 12 24 black ground
Good Luck I hope this helps.
Nov 19, 2010 | PSA Ultra X2 Connect (ULT31851) 550-Watt...
Call T-Mobile Customer Support. Give them your phone number and the account holder's last 4 digits of the social security number and they will give you the PUK code to enter on your phone.
Sep 29, 2009 | Samsung SGH-E900 Cellular Phone
Whats da pin number 1 and pin number two?
it refers to the personal identification number of the user of the sim card, you better not to activate that to avoid any problems,,,,,
Aug 15, 2009 | LG Xenon GR500 Cell Phone
Lg dare keypad is locked
Is your keypad locked where it wants a 4 digit pin try 4 zeros or the last 4 digits of your phone i work for verizon so let me know whats going on will figure it out..
Jan 05, 2009 | Cell Phones
Cell Phones Logo
23 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
