Question about Sylvania Cameras
Sylvania digital photo how do I copy more than one photo onto frame memory
SOURCE: 7 digital photo frame problems
Yeah, I just got one too and I have no USB thingy, and I kinda need my memory card.... hmmm.... maybe it should come with one. That's a bright idea huh! And how on Earth do you get music on it?!
Posted on Dec 26, 2007
early1234
  • 871 Answers
SOURCE: Digital photoframe
http://www.pandigital.net/downloads/Pandigital%20Digital%20Photo%20Frame%20User's%20Guide.pdf
Posted on Jan 29, 2008
SOURCE: Transferring photos from digital to photo frame- How to? Please
If you need to transfer to your computer just connect the USB cable from the camera to the computer, switch the camera on, turn the dial to View and Voila! A connect icon appears on the camera screen. Follow instructions on screen to download photos; develop if necessary. Presumably you will then be able to download the jpegs to your photo frame from your computer.
Posted on Jun 16, 2008
  • 136 Answers
SOURCE: Canon PowerShot S51S camera, trying to transfer
you have to use the data cable (which one come with your camera) to store pictures to your XP/Vista PC. Just connect the cable into your camera and PC, your PC detected your camera automatically as an drive, then you can transfer pictures.
Posted on Jan 04, 2010
  • 19 Answers
SOURCE: copying pictures from computer to memory card
i have seen this error and i dont know why it does that. you may want to try buying a micro disk setup that fits into a sd adapter that will fit in your camera.
then you can take out the micro disk when full and put it on a usb adapter and plug right into a usb port.
i know this sounds like more work but so far i havent had a lock up on that or error yet. go to tigerdirect.com if you want to see the different adapters for the sd disk and micro disk and usb etc....
maybe this might help
Posted on Apr 27, 2010
How do I get my sylvania 10 in. Photo frame video intensity increased
Image Settings; Calendar Settings - Sylvania SDPF751B ...
www.manualslib.com > ... > SDPF751B > User manual
Sylvania digital photo frame user manual. Hide thumbs. 1 · 2 · 3 · 4 · 5 · 6 · 7 · 8 · 9 ·10 ... You can decrease/increase the value by pressing. Time: Press to set Date, time. ... Digital Photo Frame Sylvania SDPF733 User Manual. Sylvania digital ...
Electronics - Sylvania
Dec 10, 2015 | Sylvania Cameras
How do I install photos on my Sylvania Digital Photo Frame Model SFPF785?
Relax, you have over six months until Christmas. Just follow the instructions in the manual, especially with regard to the picture size and dimensions.
May 28, 2017 | Sylvania SDPF752 7" Digital Photo Frame
How do i download pictures to tablet
Pandigital photo frames are an ideal way to display your collection of digital photos. You can view photos with or without a computer using just a memory card, but it's always a good idea to transfer the photos you'll want to view frequently to the internal memory of your frame. This is also a handy way to back up your favorite images.
  1. Transferring Photos from a Memory Card
    • Your digital photo frame's built-in software will recognize six types of memory card: CF I/II, SD, MS Pro, MMC and XD. Locate the slot on the back of the frame (to the left of the stand) that corresponds with your type of memory card. These are labeled as follows: SD/MMC/MSPro/XD, CF I/II, USB and mini USB. Insert your memory card into the appropriate slot, power on your digital frame, and it will automatically begin a slideshow using every available image on your memory card. Note that only JPEG formats under 16 megapixels are compatible.
    Transferring Photos from a PC
    • Use the USB cable that came with your frame. Connect the mini USB end to the mini USB port on the back of your frame; connect the large USB end to your computer's USB port. Double-click the "My Computer" icon on your desktop or in your Windows "Start" menu. You'll see that your computer has automatically assigned a drive to your digital frame---look for a device called "Removable Disk" followed by a letter (Removable Disk E:, for example). This is the folder that represents the internal memory of your digital photo frame; you will be dragging your photos into this folder.
      Next, open the folder in which you store your photos ("My Pictures," for example). Select the photos you want to transfer to your frame. Drag them to the drive associated with your digital photo frame---this is the "Removable Disk" drive you located within the "My Computer" folder. Every photo you selected will then be copied onto your digital frame.
      After the files are copied, disconnect your digital frame properly. If you don't, your frame's internal memory could be damaged. Look for the system tray in your desktop's lower right-hand corner. Left-click the icon that shows a gray box with a green arrow on top of it. Select "Safely Disconnect Hardware." A dialog box will appear, asking you to select the device to disconnect. Select the digital frame and click "OK." When the dialog box appears, click "Close." You'll see a message in the lower right hand portion of your desktop telling you it's safe to disconnect your frame.
    Copying Photos to Your Frame's Internal Memory
    • You can use your frame's remote control to copy photos from your memory card or computer to the photo frame's internal memory. Connect your photo source (computer or memory card) and have your frame's remote control handy. Access the "Home" screen on your frame using the "Home" button on your remote control or by pressing the "Home" button on top of the frame. Next, choose "Photos" and press "Enter." You'll see all your photos in thumbnail form. Scroll through them with the up and down arrows. Press the "+" key to mark photos you want to copy (use "-" to de-select a photo). When you've selected all the photos you want to copy, press "Set Up," then "Copy Photo," "Enter," "Selected" and "Enter." A dialog box will ask you to confirm your selection; with the cursor on "Yes," press "Enter." The photos you selected will be copied to the frame's internal memory.
Dec 04, 2011 | PANDIGITAL 7270FW Tablet
Hello, I have the following digital frame. Unfortunately, I don't have the instructions. Mustek Model # PF-A702BM. I uploaded the photos to my frame but unfortunately didn't copy them to my computer...
If the photos are on an external memory card you should be able to put that into your computer and retrieve your photos that way. If this is not an option because the photos are actualy saved to the digital photo frame then you should be able to connect the photo frame to your computer using a USB cable and then copy the photos to your computer. I am not particularly familiar withthe product but i hope this helps
Jan 09, 2011 | Cameras
HOW TO PUT MUSIC ON FRAME
I just received a gpx photo frame. I can not copy from my memory card to photo frame. Has built in 1 gig memory
Dec 24, 2008 | Nextar N7 - 7 Digital Photo Frame with...
Transferring photos from computer to picture frame
3 Doing more with your frame
Copying between your frame and computer Copy pictures, videos, and music via the included USB cable. For wireless copying (EX models only), see Picture transfer software—copying wirelessly.
Connecting to your computer autourg00722003id1479308.jpg Copying pictures to/from your computer Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools. See info.jpg for applicable file formats.
spacer.gif spacer.gif spacer.gif spacer.gif 1. Connect the USB cable from the frame to your computer (Connecting to your computer).
autourg00722003id1967406.jpg 2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
See your computer documentation for more information on copying files.
Copying pictures from EasyShare software It's easy to copy pictures/videos from My Collection to your frame.
  1. Install EasyShare software from the CD included with your frame (Installing the software).
  2. Connect the USB cable (Connecting to your computer).
  3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
  4. In the menu bar, select File ® Copy to.
  5. Select the frame source to which you are copying.
  6. Select Best For Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
  7. Click Copy. Pictures are copied to your frame.
  8. Unplug the USB cable and press autourg00722003id1974433.jpg to navigate to your copied pictures.
Dec 16, 2008 | Kodak EasyShare EX1011 Digital Picture...
I've got a LOGIK PF-A850WD 8.5" digital photo frame. I've copied photos onto an INTEGRAL 512 MB. When i try to view photos the frame says NO PLAYABLE FILE. How to I fix this/
Please make sure that the photo files are in the root directory of the memory photoframe (ie, not within a folder).  That they are in a readable file format (.jpg) Check to see that the frame is reading from the internal memory and not the card slot.
Dec 12, 2008 | Acer AG.MP3F2.512 MP3 Player
How do I convert music to mp3 files
Insert the cd into your computer and open it with media player, copy the music onto media player.
Once you have done this, go to 'My Music' folder and copy the songs you have just ripped from the cd onto your memory card. If you cannot find the songs in my music check in the unknown folder (in my music) and it will be in there with the date of copying so you know which folder it is.
I hope this helps
Nov 30, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Westinghouse 7" lcd picture frame internal memory not recognized
You can copy files from internal memory to sd card only. Its one way data transfer.
Sep 05, 2008 | Westinghouse 7" LCD Digital Photo Frame
Can I get pics from computer put on memory card for digital camera?
Put your SD card into a card reader / slot in your computer. Go to "My Computer" Identify the drive letter allocated to the card slot and drag and drop or copy and paste.
May 05, 2008 | Cameras
Cameras Logo
41 people viewed this question
Top Sylvania Cameras Experts
Steve
ray gallant
Tom Chichester
Are you a Sylvania Camera Expert? Answer questions, earn points and help others
