Question about Ice Cream Makers
I purchased the volu-firm day and night sunscreen spectrum spf 30.The day one would not work, I primed it, worked and worked with it, so I tried cutting into the top as it was no use to me as is.
My question is can I send the Day Volu firm day cream back to you or have it replaced? Thanks.
    Top Expert:
  • 48,487 Answers
No you can not sorry
Posted on Dec 21, 2016
Poor Overrun on Taylor 162-12
You cannot change the overrun on a Taylor 162. Once you've properly primed the machine and installed the feed tubes, the viscosity or how firm the product is.
I do not know of any soft serve machine that will give you an 80% overrun. You can adjust the overrun on a Taylor pressurized machine like the 8756 or the C712, but I believe the limit is somewhere around 40%.
You can email me tex@softserveparts.com or call 1-800-879-7839 if I can answer anymore questions for you.
Soft Serve Parts Supplies
Jun 02, 2017 | Taylor Ice Cream Makers
Problem with my chocolate side. Will not remain as firm ice cream. Becomes liquid ice milk. I turn chocolate side off. After I turn back on it may still be liquid but not firm ice cream.what can I do?
Homemade Ice Cream Mistakes-and How to Avoid Them ...
www.bonappetit.com/test.../common-ice-cream-mistakes
Bon App?titJul 30, 2014 - Ice cream machines are easily found and affordable, so procuring the ...Once ice cream is properly chilled, it should be firm but not a solid, ...
5 Mistakes to Avoid When Making Ice Cream - Cooking ...
www.thekitchn.com/5-mistakes-to-avoi...
Apartment Therapy's The KitchnJul 20, 2015 - Not letting the ice cream maker bowl get cold enough. ... churning away in the machine, this process doesn't end with the firm, super scoopable ...
Will a new ice cream maker make my ice cream set firmer ...
www.chowhound.com/.../ice-cream-maker-ice-cream-set-firmer-964328
Feb 12, 2014 - I've been making ice cream at home for a few years now and tend to have pretty mixed results with how firm my ice cream gets. Even with all ...
Jan 10, 2016 | Ice Cream Makers
Which flavored ice cream is best to serve guest in day time?
Vanilla is a very common and still in used, every age people love this flavor. It can be served simply during daytime or with topping on night time. It is also not too heavy for eating and good for desert.
http://mental.net.in/
One can also add some fruits like strawberry, blueberry etc., to make it extra rich in flavor.
Dec 17, 2015 | Ice Cream Makers
Taylor ice cream machine
might have to adjust the cycle timers on the logic boards
Sep 08, 2014 | Taylor Temporarily Out Of Stock-339-27 Air...
I need to down load a manual for ge ice cream maker model 106765
  • 1
    Place the mixer bowl in the freezer. The amount of time required depends on the temperature of your freezer, but you should expect to leave it in the freezer for about one day prior to use. To check if the bowl is frozen, shake it gently. If you don't hear any liquid sloshing around inside, it's ready to use.
  • 2
    Place the mixer bowl onto the motor base when you're ready to make ice cream. Insert the mixing paddle into the bowl and place the cover over the bowl.
  • 3
    Turn on the ice cream maker and pour the ice cream mixture into the hole at the center of the appliance until it reaches the fill line. Do not exceed the fill line, as the ice cream will increase in volume as it freezes. Use the low setting if you want a firm ice cream and the High setting if you want a softer consistency. Do not add nuts, candy or chocolate chips at this stage as they can become hung up in the mixing paddle and stop the machine.
  • 4
    Cover the center hole with the cap and allow the ice cream maker to run for 30 to 45 minutes.
  • 5
    Add mix-in ingredients such as nuts and candies two minutes before shutting down the machine.
  • 6
    Turn off and unplug the machine prior to removing the ice cream from the bowl. GE recommends using plastic or rubber utensils to avoid scratching the inside of the mixer bowl.
  • Read more: GE Ice Cream Maker Instructions ' eHow.co.uk http://www.ehow.co.uk/how_7784888_ge-ice-cream-maker-instructions.html#ixzz1ahXwP2GR
    Sep 09, 2011 | Gel Canister 106765 1.5 Quart Ice Cream...
    8 yr old machine
    Check the mixer running time after you activate the handle may be to long easy to fix !
    Apr 06, 2009 | Taylor 632-33 Ice Cream Maker
    Salton hand crank big chill ice cream maker
    I bought one new, and it had a great recipe for Kiwi fruit ice cream, using kiwi fruit and oranges. I can't find the recipe book. You make just over 1 l of fluid ice cream mixture, the bowl must be pre=frozen for at least 15 hours, just put the liquid in the machine and crank the handle in quarter turns (the square outer box helps measure this!) every 5 min for the first 30 min, and then half turns every half hour or so.
    Jul 06, 2008 | Salton ICM15 BIG CHILL 1.5 Quart Ice Cream...
    Ice Cream Makers Logo
    424 people viewed this question
    Top Ice Cream Makers Experts
    Dennis Boxerman
    Are you an Ice Cream Maker Expert? Answer questions, earn points and help others
