SOURCE: My Optoma projector has the red light come on for
if it is a replacement lamp, was the lamp timer reset after replacement? if it's the original lamp and the projector only has 83 hours on it, there is either a bad lamp or a cooling problem.
SOURCE: I replaced the bulb in my projector and now it
You need to hold the help button on the remote control for ten seconds, that should reset the lamp hour. NEC decided to make it inoperable after 2100 hours on the bulb.
SOURCE: I replaced the lamp when and the red LED light
More likely a faulty ballast. Check connections.
SOURCE: the projector lamp does not turn on
I have done this on several of our PT-LB50U's with sucess every time.Remove lamp cover and lamp.Then remove top of case by removing 6 screws on bottom.Remove metal shroud that would cover lamp 2 screws and remove 2 screws that hold lamp plug and move it away.You will see a little blue lever for saftey switch move it back and forth from top and bottom put back together and should turn on.
I'm terribly sorry for the problem you've been experiencing. I'd like to help. Please contact me so I can assist you.
Sal
Sal Di Giacomo
Runco International
WW Service Manager
503-748-5735
