Question about Pool & Spa
Where is my pump filter - Pool & Spa
    Habit-Forming:
  • 124 Answers
Well, it could be many places, depending upon the model of pool/spa you have and the pump design. Normally, however, the filter is one or more large containers/cylinders in the fixed/solid pump line. The filter housing could be a large, chrome/nickel (think bright/shiny) enclosure or it could be a PVC (white or painted) enclosure.
It would likely be best to have a local pool or spa professional in your area show you where they are located and show you how to clean and replace them.
Posted on Dec 21, 2016
How do you backflow a pool pump?
I assume you mean backwash the filter. The pump will always pump in one direction.
I am also assuming that you have a sand filter with a filter control valve.
If your filter's waste discharge needs a hose attached to route the discharge to a ditch or other suitable location, be sure to attach the hose before beginning this process.
Turn the pump off. Set the filter control valve to the backwash position. Turn the pump on and run for 30 sec to 1 minute until the water being discharged looks clear. If your filter control valve has a Rinse setting, turn the pump off, set it to Rinse and run the pump for about 30 sec. Turn the pump off. Set the Set the filter control valve back to Filter and turn the pump back on.
Jul 23, 2014 | Pool & Spa
Where does the hose from the skimmer go in filter or pump
skimmer goes to intake of pump out of pump to filter in out of filter to pool return
May 30, 2014 | Intex 1500 Gph Swimming Pool Filter Pump...
My pump and filter work great for aa hour or more then the pump keeps running, but isn't pumping water through filter. We shut off the power and turn it back on and it works great for a while.
make sure filter grids where cleaned with TSP tri sodium phosphate to degrease them then recharge system filters are locked or try on recirculate if ok then clean filters if not pump seals getting hot and pump not working correctly
May 19, 2014 | Hayward EC-40 DE Pool Filter with pump
My intex 637r pump is not pulling the water through to the filter and letting it discharge back into pool could it be that the pump and hoses are sitting to high on the ground and not far enough under the...
Air release valve for air trapped inside filter chamber
Intex 1000 GPH Easy Set Pool Filter Pump Instructional Guide 637R
The link has a set-up video for the 637R pump. Make sure water flows out of the air valve on the top of the filter cover. This will purge air out of the filter and prime the pump. Hope this helps you....
May 13, 2014 | Intex Krystal Clear Model 635 Pool Filter...
Sticker wore off on the filter. which button backwashes? the pool is about to overflow.
b> VALVE SETTING FUNCTIONS OF VALVE POSITIONS FLOW DIRECTION THROUGH VALVE FILTER PUMP - TOP - THROUGH FILTER - BOTTOM - RETURN For normal filtration and vacuuming pool through filter. BACKWASH b> PUMP - BOTTOM - THROUGH FILTER - TOP - WASTE For reversing flow for cleaning filter. RINSE b> PUMP - TOP - THROUGH FILTER - BOTTOM - WASTE For initial start-up cleaning, plus resetting filter bed after backwashing. WASTE b> PUMP - WASTE For vacuuming directly to waste, lowering pool level/draining pool. CLOSED b> NO CIRCULATION PAST PUMP PORT For shutting off all flow to filter and pool. RECIRCULATE b> PUMP - RETURN For bypassing filter, but circulating pool water. May be plumbed for "off-system" pool water access. Ideal for Jet-Air® fittings. WINTER b> VALVE NOT IN USE
Ifthis answer does not fix your problem, please comment with additional detailsprior to rating the answer. Positive feedback is appreciated once your problemis solved! Thank you.
Aug 28, 2011 | Hayward SAND FILTER, PRO SERIES
How do i change the sand in the filter? I am getting sand in my pool.
You will simply remove the old sand from your pool filter and follow the instructions from your users manual like you are adding sand for the first time. In case you don't have it, I am going to paraphrase it for you below.
1. Be sure correct amount of filter sand media is in tank and
that all connections have been made and are secure.
IMPORTANT: To prevent unnecessary strain on piping system and valving, always shut off pump before switching Filter Control Valve positions.
The correct amout of sand can be determined with this link: http://www.backyardcitypools.com/pool-filters/Filter-Sand-Requirements.htm
2. Set your controls to the backwash position.
3. Prime and start pump according to pump instructions. (be sure all suction and return lines are open), allowing the filter tank to fill with water.
4. Once water flow is steady out the waste line, run the pump
for at least 2 minutes. This initial backwashing of the filter is recommended to remove any impurities or fine sand particles in the sand media.
5. Turn pump off and set valve to RINSE position. Start pump and operate until water in sight glass is clear—about 1/2 to 1 minute. Turn pump off, set valve to FILTER position and restart pump. Your filter is now operating in the normal filter mode, filtering particles from the pool water.
6. Adjust pool suction and return valves to achieve desired
flow. Check system and filter for water leaks and tighten connections, bolts, nuts, as required.
7. Set your filter to the "filter" position.
May 22, 2010 | Hayward SAND FILTER, PRO SERIES
Need to remove external oil pump on a 95 ford tauras 3.8 v6.what all is involved doing this??
Oil Pump
Removal
  1. If necessary, remove oil bypass filter (oil filter).
  2. Remove oil pump and filter body to engine front cover retaining bolts and remove oil pump and filter body from engine front cover.
  3. Inspect oil pump body seal (6C639), oil pump and filter body and engine front cover for distortion and wear. Replace components as necessary.
Installation
  1. Position oil pump and filter body on engine front cover and install retaining bolts.
  2. Tighten the small engine front cover retaining bolts to 8-11 Nm (71-97 lb-in) . Tighten the large retaining bolts to 23-32 Nm (17-23 lb-in) .
  3. If removed, reinstall oil bypass filter (oil filter).
Dec 04, 2009 | 1995 Ford Taurus
Will not pump when it has a filter in it
filters are too good for pump system.
These pool pumps seam to over heat fast, no quick fix.
* Try getting more air flow around pump.
* Only use pump when using pool or near by.
* Use a pool cover - will help stop dirt/rubbish getting into pool - less to filter.
Jun 02, 2009 | Intex Easy Set 1500 Gph Filter Swimming...
Fuel pump squeaking, filter resticted or pump failing?
Yes, it could be the fuel filter, but the pump may be on the way out also. Change the filter first. I have seen the pump get replaced and a noise still exists. It usually caused by the fuel filter.
Apr 20, 2009 | 2004 Audi S4
Pool & Spa Logo
46 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
