E1 f9 code front load duet washer how do we fix it
    Habit-Forming:
  • 124 Answers
When your Whirlpool washing machine won't drain, or is displaying the E1 F9 error, there's a possibility that the drain filter is clogged. The drain filter is designed to catch lint, change, credit cards and all the other things that find their way into the washer. Whirlpool washer models that have a drain pump filter are easy to disassemble so that you can access and check it. Before you go to the minimal amount of trouble it takes to check the filter, however, take a look at the drain hose behind the washer to ensure it isn't kinked.
1 - Unplug the washing machine. Lift the front end and place two-by-four blocks under each foot to keep the front elevated. 2 - Unscrew the three screws at the bottom of the panel, using a Phillips screwdriver. Remove the panel. The drain pump assembly is directly in front of you, in the middle of the machine. 3 - Unscrew the knob on the drain pump by turning it counterclockwise. Hold a bucket in front of the pump while you remove the knob to catch the water. There may be as much as 2 or 3 gallons. 4 - Turn the knob over. The filter is on the back. Check the filter and remove any debris or lint. Replace the drain filter onto the pump. Screw on the access cover. Take the machine off the blocks and plug it in.
Posted on Dec 21, 2016
E1 F9 code front load washer whirlpool duet
Dec 21, 2016 | Whirlpool Washing Machines
I have error codes E1 and F9 on my whirlpool duet washer
Duet washers use F/XX codes. I couldn't find E1 but the F/09 code is set by an overflow. To eliminate the code:
- Check for clogged/kinked drain hose
- Check wire harness connectors for pump, pressure switch, and CCU
- Check/clean pump filter
- Check inlet valve for complete shut off
- Check for pump failure
- Check pressure switch operation
Dec 13, 2016 | Whirlpool Washing Machines
Duet. What does F8E1 code indicate needs to be done to restore operation?
Check out the Link and the info below.
Question: Front Load Washer - Error Code - F8 E1 or LO FL Answer Product Symptom:
F8 E1 or LO FL Code in display:
No water detected entering washer after 13 minutes, the pressure switch input has not been detected.
If the washer has an F8 E1 error or LO FL error, the door will be locked, and the control will be unresponsive. The washer will start a drain routine which takes approximately 8 to 10 minutes, during which time the pump will run continuously. The control will not accept any input during this time. Please wait 10 minutes before trying to perform any functions.
Check the water supply:
Turn on the water. Check the household water supply to see if the hot and cold water faucets are turned on. Make sure to open both faucets completely for proper fill.
NOTE: Both Hot and Cold water must be supplied to the washer.
Whirlpool recommends that appliances be direct connected to the water supply for optimum machine performance.
If a "flood saver" device is being considered:
  • Check with the manufacturer of the device to ensure it will not affect the performance of the appliance.
  • Whirlpool has experienced that "flood safety" devices can interfere with the performance of the appliance. Whirlpool typically does not recommend these devices.
Two types of "flood-saver" devices, hoses and valves are illustrated below. anti%20flood%20hose%202.jpeg floodsafe%203.jpeg Whirlpool Duet Washer F8 Code Appliance Repair Forum
Jan 19, 2016 | Whirlpool Washing Machines
How do I clear the fault codes ?
How To Fix Maytag Washer Error Code F9 E1 ...
www.appliancerepairlesson.com/2013/.../maytag-washer-error-code-f9-e...
Dec 10, 2013 - The error code F9 E1 will be displayed on most newer Maytag washers and ..... My whirlpool duet wfw94heaw0 gives the error code F09 E01.
KitchenAid f09 error code Dishwashers Questions ... - Fixya
Nov 29, 2015 | Dishwashers
I have a whirlpool duet model wfw70hebw. The washer stopped and I can't unlock the door. Have error code E1 F9
Try unplugging for 30 seconds and plug back in. See if you are able to reset the controls after that.
Jan 24, 2015 | Whirlpool Washing Machines
What does the Code E1 mean for a Whirlpool Duet washer?
There is a small access panel on the bottom of these newer Maytag and Whirlpool washers. Three small quarter inch screws hold the panel in place.
Once the screws are removed the panel will come off. The pump filter is directly in front of you at this point. The handle can be twisted counter clock wise and then pulled out. Most likely you will find some sort of debris inside. It can be an article of clothing, lint, backing from a rug, or change
Sep 13, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Why is My Kenmore he washer is throwing the codes f9 and e1... what do these mean?
I have the manual for the Kenwood HE3t. It says nothing about e1, but for F4 thru F16 it says to press PAUSE/CANCEL twice to cancel the cycle then start again. If the problem remains try asking at RepairClinic.com, press the "Repair Help" tab.
Apr 29, 2014 | Kenmore HE2 Plus Front Load Washer
Model number wfw9250ww error code e1 and f6
How to fix a error code of E2F3 on a whirlpool duet model # wfw9250ww00
May 28, 2012 | Whirlpool Duet GHW9150P Front Load Washer
I keep getting an E1 Error code on my Whirlpool Duet dryer. Technician came and didn't fix it. Any suggestions?
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
