Furnace won't lite
My furnace wouldn't lite the other day so I pulled the cover and checked all connections the filter is new after all this it lit and has run for about 6 days . Now it won't lite again . The igniter won't glow . This is a Luxaire climate 8t When it defaults it blinks a red light 5 times .
    Master:
  • 946 Answers
Look at the code explanation either on the inside of the door or thru a peephole in the panel. It will tell you what 5 flashes means.
don-ohio (:^)
Posted on Dec 23, 2016
Furnace will not stay lite, flashes pressure valve closed
Too much or too little pressure. Check for air blockage or an ice blockage inside or outside the house. Were flames good color when lit?
Nov 12, 2014 | AO Smith Miller / LSI / Home / Nordyne...
Where is the furnace breaker
Is the pilot light lit? There should be a valve that turns the gas off at the furnace itself. This valve is for the pilot lite There is no breaker of sorts but rather a sparker that lights the furnace. If the furnace does not light there is a small 12 volt valve that shuts off the gas to the furnace but not to the pilot light. Also make sure your 12 volt system is connected and operating. It wont work without it as it operates off that system not 120V. The same goes for refrigerators, the will not function with the 12v system disconnected
Apr 13, 2014 | Keystone 2013 Hideout 32FLTS
Furnace won't stay lit
Are your air filters relatively new? Is a bird nesting in your units combustion air exhaust pipe? Does your draft inducer motor run before and after the gas has ignited? Check and confirm these 3 things first. Good Luck!
Mar 03, 2013 | Omega Trane Furnace Draft Inducer Blower...
I have a goodman high efficiency furnace, model gms9/gcs9. I've had several furnace techs look at it scratching thier heads. It won't fire up, the ignitor comes on but won't flame the unit. I...
check to see that your condensate line is not plugged. next check the p-trap where your line goes in. also check your flue abs flue pipe see as it comes out of roof is it open or does it have an elbow coming off of it i usually install with elbow preferably less water goes in the units resevoir hope that helps u
Apr 04, 2012 | Goodman Heating & Cooling
When I tried to light my furnace, the electrical wires from the thermostat don't spark all the time, therefore my furnace won't stay lighted. What can I do to fix this?
Is this an older furnace where you have a pilot light? Are you saying the pilot light will not stay lit? If thats the case then likely you need a new thermal couple. That is what the pilot light keeps hot while it stays lit. It is a safety device that is there so your furnace will not come on if there is no pilot light present. Very common. Hardware store item. Need Furnace's make and model #'s.
If this is an electronically controlled furnace, you will need a service call.
Jan 13, 2012 | Heating & Cooling
I have a a Ruud furnance, model UGAC 095c. The problem is the pilot light goes out once or twice a day or late night. The thermacouple was replaced, new filter also. I also observed the pilot light and lit...
check the thermocouple is tight in to the valve , condtion of thermocouple could need changing , is pilot stong blue flame could need cleaning .
Feb 06, 2011 | Heating & Cooling
Goodman GMP Furnace problem. Original problem is
Good one! Is the flame getting to the flame sensor within the few seconds? Maybe a good cleaning of the burners or flame tray would help. 1.3 ma is enough for the flame rod to tell the board to stay on. Re-do all the ground connections both at the board and furnace cabinet to be safe. Check the polarity of the power going to the furnace. What are the chances the second board is bad?
Jan 15, 2010 | Goodman Heating & Cooling
Furnace is not turning on
Sounds like you have a bad fan limit. they will sometimes kick on in the summer when the temp gets high enough. now it sounds like it is not working at all. it is usually mounted with a metal square cover over it removing the cover would expose the dial this it what turns as the furnace heats up and kicks on the fan . turning it by hand will check to see if fan will kick on(turn a lttle clockwise)
Jan 10, 2009 | Heating & Cooling
My Ruud Furnace wont stay lit
Hi Bmreid
The problem you describe sounds pretty much like your gas valve is going bad. There is a brand by Honeywell called a Smart Valve which is anything but smart, when the electronics in the valve start going bad the furnace will run great for a day or two and then the next day may not run at all and then an hour later my run and then an hour later may not run again. Very sporadic operating furnace is usually the Honeywell Smart gas valve going bad.
Nov 15, 2008 | Kitchen Appliances - Others
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
