Question about Ovens
How do i use my self cleaning oven with model number rf365pxyn
    Master:
  • 234 Answers
Merry Christmas! Here is a free user manual download for your Whirlpool model RF365PXYN stove including the self cleaning instructions.
https://www.manualslib.com/manual/192853/Whirlpool-Rf365pxy.html
Posted on Dec 21, 2016
How do I use the self cleaning option on my Kenmore stove model# 970C623331. Do I remove oven racks?
that model doesn't come up,that could be the serial number,do you know that when the dryer is in self clean it gets up to 1000 degrees,when it gets this hot it can do damage to the electronics in the oven,from what i've seen on other peoples ovens i will never use the self clean again,but to answer your question remove the racks and clean them in the sink or you can soak them in the tub,whatever is easier for you.i get in there with an sos and scrub,if any spills are big on the floor i wet it and let it sit for a minute or two and scrape it out with a putty knife or you can use a spatula,if it's really bad easy off is made safe for most self clean ovens now,don't put tin foil on the oven floor when you cook,it can damage the floor,so watch out for that.kenmore doesn't make anything so you need the model number to see who made the stove,if you open the drawer under the oven door,look on the left or right side of the frame and you'll see a tag with the model and serial numbers,go here,put your model number in and you can look up the manual for your stove.hope this helps you out.
https://www.searspartsdirect.com/model/search.html?q=970C623331
Feb 27, 2018 | Kenmore Ovens
Need manual for self cleaning, please?
Hello Mary;
You can get a user manual at the following website.
Locate your oven model number. It is located on a label either on the face of the oven when you open the door or on the side of the door. Put he model number into the website and you will get diagrams, component part numbers and manuals.
http://www.searspastsdirect.com/
I suspect the user manual is not going to help you. Tell me the model number and what is going on.
Manufacturers offer the self cleaning feature on ovens because customers like this feature and the ovens sell. Yet, the manufacturers engineers have not been able to provide a design that will protect all of the components from self cleaning temperature of 900-1,000 degree F.
When you go into the self cleaning model, the door will lock when you reach 500-550 Degree F. The oven temperature will raise to 900-1,000 degrees F. The oven door will not open until the oven temperature drops to 500 degree F after the self cleaning cycle is completed.
Now, You have a high temperature limit switch in your oven. If this switch fails, you will loose power to your control board and you will not be able to open the oven door.
If you have never used your self cleaning feature, the high temperature limit switch may have failed.
Do to the problems involved with the self cleaning feature, knocking out the control board from heat, additional heating element failure, and other components; It is in my professional recommendation as well as my fellow technicians not to use the self cleaning feature. If you do, do not run it for more than 1 hour instead for the manual 4 hours.
Mar 14, 2016 | Ovens
Need cleaning instructions for tappan self-cleaning oven model number TEF351EWE
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Jan 24, 2011 | Tappan 30IN ELEC IGNa Oven
I need to know how to get a manual for a kenmore ultra bake self cleaning super capacity oven can you help me
Many Kenmore manuals are available from the Manage My Life site: http://www.managemylife.com/mmh/owner_manuals?intcmpMMHxG_HomexServices_Menu .
You will need the model number - there are over 9,000 ovens that come up when you search Kenmore Ultra bake self-cleaning super capacity oven. Most of the Kenmore ovens have the model and serial numbers on the front frame. (Left front of the frame on the lower oven on a dual oven model - just open the door and the panel should be visible.)
I hope this helps.
Jan 04, 2011 | Ovens
My kenmore self cleaning oven , F06 error
first try to turn the breaker off and then back on and see what happens.let me know if this helps and what is the model number?
May 10, 2010 | Ovens
Need directions for self cleaning oven
Hi Debi
Unfortunately I was unable to find the manual in my database. But still found the solution you can click on these links and refer to the instructions :
How to self clean Gas Single Oven
Directions for cleaning Fridgidaire
Please do rate the solution as FixYa if found useful and revert for further assistance.
Thanks Rylee
Apr 08, 2009 | Frigidare FGB24S5DC Gas Single Oven
Self-Cleaning Whirlpool Oven
Hello, I am cleaning my oven today. I went to the whirlpool.com website and clicked on customer support and typed in my model number which is located on the front inside panel of my oven. They will provide you the manual with the self cleaning instructions. I hope this helps.
Jul 04, 2008 | Ovens
Self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
44 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
