Question about LG Televison & Video
My LG CF-20D33KE TV is showing blank screen channels are changing but no pictures only sound is coming
  • LG Master
  • 6,694 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Posted on Dec 21, 2016
SOURCE: 37LC7D, screen blank, cannot power off manually or w/remote
Hi, I would buy your TV
Posted on Dec 14, 2008
  • 10594 Answers
SOURCE: 32LG3000 LCD TV shows no picture when resuming from standby
It seems just channel stored data issue.
Please perform Auto Preset / Auto Channel / Auto Tuning (mentioned menu items) and store all channels again.
Hope problem will resolve.
Posted on Dec 18, 2008
  • 21 Answers
SOURCE: lg lcd tv screen goes
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Posted on Sep 18, 2009
  • 458 Answers
SOURCE: 42" LG Plasma tv, no picture - black screen, but have sound.
Most a likely a problem with your Y-Sustain board which will then not drive the screen giving a black picture. The fuse on the board may be open circuit & need replaced but most likely you will need to have the sustain board replaced.
Posted on Oct 28, 2009
  • 10594 Answers
SOURCE: my LG HD tv screen suddenly went green. sound is
I disagree with info provided, if screen of your LG lcd tv becomes green that means inverter board is working and lcd tv does not have convergence ICs.
Please unplug tv from ac wall socket for minute to get it reset, replug back in and turn it On and check its picture.
If still showing green screen then change input source with remote, if tv shows same green screen on all inputs that means its either lcd panel problem or digital signal processor got bad loacted on main board. Local tv repairman is needed to confirm and fix it.
Posted on Jul 23, 2010
LG CRT TV MODEL NO. CF-20D33KE use ic TDA 9381PS/N2/3i774 folt plane raster sound ok tuch ic pin 50 than snow.
If you wish to get some details; check the site linked here. Pull up older posts. Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result will display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Dec 27, 2016 | LG Televison & Video
I have a 50inch LG TV that when switching between programmes the TV goes blank for a moment
Are you using cable and if so which company and box?
Dec 07, 2016 | LG Televison & Video
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
On my 7" wide screen model TL7001-TP-ASC with ATSC Tuner. When I change the channel it wont tell me what channel the tv is on and the tv guide wont show. The tv does not show no numbers or letters
LG LED TV won't show program information or channel name ...
Oct 18, 2011 - 17 posts - ‎7 authors
I will get the picture/sound (up to 1080i) but i can't get the TV to display the information (What I'm watching and the channel's name). It used to ...
ChanSort download ' > Browse > Multimedia
Rating: 4.5 - ‎23 votes - ‎Free - ‎Windows
Jun 5, 2015 - ChanSort Channel List Editor for Samsung, LG, Toshiba and Panasonic ... ChanSort allows you to organize your TV's channel lists on your PC.
Jan 13, 2016 | Televison & Video
LED screen comes on and goes black
? 5:29
Jan 25, 2013 - Uploaded by Tampatec
Common LG LCD TV REPAIR - NO PICTURE OR BLACK SCREEN FIX ... I have a LG 42PM4700-UB plasma tv that justwent black. The red ... I had to keep turning on and off the TVseveral times for the screen to come back.
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
Sep 15, 2014 - Uploaded by
LED & LCD TV How to Diagnose Symptom of No Image on theScreen CLICK ... Tv was working fine when left to go to store and came back to blank picture and ... my samsung tv it turns on but its completely black and no sound at all ... LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW - Duration: ...
LG LED TV has no picture (black screen) but still sound ...
Dec 09, 2015 | LG 47LS4500
My screen is green and does not show a picture or sound! You cannot change the channel or access the menu! Is it the picture tube or lamp?
Can you see menus if you press the menu button? You could be set to the wrong input that doesn't have a signal coming in. I have one TV that shows a blank blue screen when I'm on an input that has no signal. If there is not a signal on the input being used you will also not have sound.
Mar 21, 2011 | JVC Televison & Video
Samsung T.V. goes on for 30 seconds then no picture
If this is a flat panel LCD tv, this is a sure sign that the panel itself is bad. I have seen this before. Tv comes on works fine then within 5 minutes goes blank.
Aug 07, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Blank Blue Screen
If you go to menu do you get that on the screen?
Nov 21, 2017 | Samsung CXN2085TP 20 in. TV/VCR/DVD Combo
Dec 18, 2008 | LG 32LC7D Television
Televison & Video Logo
Computer Repairing
Computer Repairing
