Washer buzzes when filling - Washing Machines
    Top Expert:
  • Washing Mach... Master
  • 47,827 Answers
The noise is a frequence buzz caused by the solenoid that controls the water inlet valve
it indicates a failing if it has just started , but is not really serious at this point
it gives you time to consider a new unit or getting a technician out to properly diagnose the fault
Posted on Dec 21, 2016
Washer buzzes and won't agitate or spin. Only will fill with water.
Almost certainly with that sound, the motor start capacitor has failed. It will be located either behind the control panel, or underneath next to the motor.
Dec 17, 2013 | Maytag Parts Washing Machines
Roper washer model RAS8245EQ1 not working, buzzing noise
Her you'll find your answer..
http://www.appliancerepair.net/washing-machines-forward.html
Mar 08, 2013 | Roper Washing Machines
My washer buzzes when knob is pulled but it will spin just not fill or agitate
sounds to me like either the water faucet at the wall is shut off or their is some sort of restriction to the pipes not allowing the washer to fill
some on here may say that the buzzing will be the motor but since it spins i say bully to them the motor only knows to go to spin or agitate rotation based on on what the timer/control tells it to do if it will turn one direction it would turn the other direction as well. So definently check the water supply to the washer
Oh the buzzing is the solonoid on the valve opening the valve yet since no water coming in you hear the buzzing while you wouldnt hear it since it would be drowned out by the sound of the water coming in
Jul 19, 2011 | Washing Machines
Water can't fill up
Check and clean out filter inside the connector to the washer
If that is clean
Switch the water off and then start the machine cycle , you should hear a buzzing sound from the area where the inlet hose connects to the washer
If there is no buzzing and the inlet filter is clean you need a new fill valve
Apr 01, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Fills with waters starts making a buzzing sound
Check to see if there is something(sock) in the pump. If not, try spin washer with pump hanging down, but not with hoses off.
Jan 12, 2010 | Whirlpool Washing Machines
Kenmore series 70 washer doesn't fill
check your incoming water supply, the buzzing sound is coming fromthe waterinlet valve , soundslikke its trying to fill. possible that the valve is no good as well,
Nov 23, 2008 | Kenmore 22422 Top Load Washer
Washer fills, but won't start wash cycle....makes buzzing sound
Try replacing the timer switch..I had the same problem on my Simpson 175..
Dec 26, 2007 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
