Machine buzzes when filling - Washing Machines
My moms pipes froze to her washing machine. They thawed and the machine filled with water but they won't wash. She can hear a buzzing sound like the machine is trying to wash the clothes but nothi
Yes , I think the valves also must have jammed in the process and when the hot water filled up in due course it must have released.
It is best to switch off water supply to the machine in such times.
Jan 23, 2013 | Washing Machines
No water is going in but i can here the buzzing sound like it would start
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Jan 16, 2011 | Washing Machines
Turn washer on, only get a buzzing sound. No water fill, rotation of agitator, nothing
heatman101
Nov 26, 2010 | Whirlpool LSQ9600L Top Load Washer
Water can't fill up
Check and clean out filter inside the connector to the washer
If that is clean
Switch the water off and then start the machine cycle , you should hear a buzzing sound from the area where the inlet hose connects to the washer
If there is no buzzing and the inlet filter is clean you need a new fill valve
Apr 01, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Machine buzzes with no action
This sounds like it could be the motor.
Jan 28, 2010 | Kenmore Washing Machines
Me Estate washing machine, when started fills to specified water level then, it makes a buzzing noise then the buzz quits and nothing happens. Machine won't agitate or drain, just buzz then buzz quits.
sounds like you have a problem with your water supply to washer. the buzzing noise sounds like it's the valve opening to receive water but nothing going in. check supply hoses and water taps
Jul 14, 2009 | Washing Machines
Series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Jun 16, 2009 | Kenmore Washing Machines
Washing machine makes buzzing noise
Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
Nov 06, 2008 | Fisher Paykel EcoSmart GWL15
Washing machine buzzing
buy a new washing machine
Nov 03, 2007 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
