Question about Watches
Model no. Classique CLO65W. - Watches
I cannot wind the watch, it will not wind up. What is the approx cost to repair.
Just the stem - is about a $40 repair.
If there is clockspring damage - you're looking at $75ish
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2010 | Jaeger-lecoultre Reverso Classique 2798120...
Dear Sirs! My new (1month) Longines automatic watch hastens each day (and night) four seconds.Model L4.721.2 Is it normal or I have to turn to the laboratoty to fix the problem?! Thanks a lot Iosif
An automatic watch that gains 4 seconds in a day is good.A new Rolex is rated at 5 seconds per day so 4 seconds is well within what you can expect for your watch.As a tip when the watch is off the wrist place on its side,gravity slows the operation of the watch just a fraction.This is called positional error and may help.
Regards
Aug 19, 2010 | Longines New La Grande Classique Presence...
My Ebel Sport Classique needs repair for the 181-1 movement Detent. What is the cost of repair and an overhaul for this 8 yr old watch?
Depending what all is involved with the overhaul and other repairs the low end for repair would cost around $375 and may cost as much as $600. Anytime I send a watch in for this kind of repair I expect a free estimate and you should too. If there is a cost for an estimate or if the estimate is around the $600 mark I realy feel you should get a 2nd detailed estimate from a different jewelry store/ repair center.
Oct 21, 2009 | Ebel 1087902 wristwatch
How do I change the quartz battery on a Longines La Grande Class
Just unscrew the screw at the back if your model have screw if not the other one snap to open.Use a pocket knife then open it look the number battery and replaced it with same number battery. Its you use Renata battery it is swiss 3years to last.
Hope it may helps;
Regards;
VOTIT
Jun 16, 2009 | Longines La Grande Classique L4.709.2.42.9...
Winder has broken off jaeger-lecoultre watch
Yes, but for an authentic Jaeger-lecoultre watch it will be very expensive.
Dec 30, 2008 | Jaeger-lecoultre Reverso Classique 2798120...
Small dial on the watch face that counts the minutes won't return to zero. It still functions but when the 'reset' button is pressed, all other dials but this one return to their zero setting. Watch is a...
Check in the instructions if there is a way to re-sync the hands. For some models of watches the hands are able to be calibrated.
It is also possible that the watch has a problem. Either the dial hand is not properly seated on to its axel, or the drive gear that is under the axel skipped a tooth. You will have to find someone who can service watches to fix this for you.
Jerry G.
Nov 21, 2008 | Jaeger-lecoultre Reverso Classique 2798170...
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
