What channel on the hci tv can I view my dvd I hooked the red yellow and white jacks into the back of tv but cannot find a channel to view the dvd
  • Televison & ... Master
  • 5,300 Answers
You probably need to find a Source or Input button or menu item. Change the source from TV (if that is your current source) to A/V (or composite video). Depending on the model, there may be a source/input button on the TV. There will always be a sourc/input button on the original remote. If you are using a universal remote, you may need to try a different code to get the function to work.
On a few TVs, you can find this in one of the sub-menus. However not all TVs let you change the source in the Menu system.
I hope this helps. Please add a comment with the model of the HCI TV and whether you have the original remote or a universal remote to control the TV if you would like me to find the specific information for your TV.
(For example, the HCI RM22 III remote has the input button on the left side just below the power button.)
Posted on Dec 21, 2016
  • Jennifer Boucher
    Jennifer Boucher Aug 15, 2017
    Cindy can u help me setup my tv i just got universal but hci is not on list
I'm trying to hook up my DVD player to my TV but my TV doesn't have a yellow jack only red and black
If your TV doesn't have a Video IN jack (Yellow) then you would have to attach your dvd by antenna (Coaxial) cable. What does the DVD have on the back ? EG: Video Out is Yellow, Red is Right Audio, White is Left Audio. If your DVD has Ant in & Ant Out you can use a coaxial cable from Ant out to your tv's antenna In socket and put your antenna cable (from your wall socket) to Ant in on the dvd. Turn on the dvd and put your tv on a blank station and tune your tv till you see the dvd screen . lock it in and that becomes your DVD channel to watch your dvd's.
Hope this is some help.
Sep 07, 2015 | RCA Televison & Video
I need help getting a manual for my tv so i can hook my dvd vcr combo up My tv is a 37ld450 flat screen> If you dont have info on ownners manual can you help me hook up the red yellow white wire...
What is the name and model of your tv?
There are two ways to hook up a dvd/vcr to at tv.
1. Coaxil Cable - From VCR Cable Out To Tv - This goes to the tv cable jack. Tv should be on channel 3 or 4 to use it this way.
2. There are Yellow, Red, White Jacks on the vcr/dvd player. There should be a couple sets actually. One set should say OUTPUT on them. The colored jacks go from the vcr/dvd OUTPUT and goes to the same color jacks on the tv that say INPUT
TV must be on an A/V or Input channel for this to work
That is about all there is too it. If you need more info, just let me know. I am more than happy to help.
Mar 30, 2011 | Televison & Video
I no longer have the manual for the product and I want to hook it up to my TV via a cable box; we have Charter cable. The cable box is a Motorola and it says Dolby digital on the front of the cable box. ...
The white, yellow, and red RCA phono jacks on the back are called VGA inputs and outputs. The Red is
right channel audio, The white is for left channel audio. The yellow is the video. Look carefully on the back of the unit and the input jacks and output jacks should be clearly marked.
There are several other input/output ports. One is HDMI which is flat and wide. Another, not common, is composite video which uses the three above mentioned RCA jacks as indicated plus two more colored jacks. This combination gives a better picture.
A third option is a screwed on cable for input and output. This is called a "F" connector and is only used if the receiver equipment has a built in tuner. The output of a cable box is usually an "F" connector and the above described outputs
If you connect the cable box to the DVD player input and the DVD player output to the TV input, you often must have the DVD player turned on so the signal will feed to the TV.
If the TV has multiple inputs, it is best to connect the cable box to one of the TV inputs and the DVD player to another TV input. Using the TV remote you can chose which input you want to watch. The remote should have a button labeled "input"
Apr 29, 2017 | Cyberhome CH-DVD 402 DVD Player
I am trying to hook up the mvd2016 to a visio tv that is hooked to our cable converter box. I hooked it up, i have the tv but no sound.
your RCA jacks from the DVD player....should be connected to the Vizio a/v 1 in the back of TV (yellow to yellow, red & white to red & white)... now to view using the remote to TV switch to a/v (play a DVD, you should now have a picture and sound)
Dec 19, 2010 | Memorex MVD2016 DVD Player
How do I connect my Magnavox DVD/VHS player to my Element Flat screen TV?
Do you have a newer TV or a older one lets start with a newer models does your tv have 3 or more jacks on the back or front you should see a RED, YELLOW and WHITE if you have a HDTV you should see more. (LETS HOOK UP) Did your DVD/VCR come with a cables if not you will need to buy at least 2 they are called RCA cables Lets start with the dvd/vcr combo on the back you should see a (LINE OUT) this is where playback or your picture and sound come out. On the back of the TV you should see a (LINE IN) this is where you plug it in to. RED goes to RED, WHITE goes to WHITE and YELLOW goes to YELLOW. To Record you will need to hook up the line in on your combo and the line out to your tv. ( IF YOU HAVE AN OLDER T.V WITH NONE OF THOSE JACKS ) you will need to buy a RF- MODULATOR the are cheap it is a box that let you hook a cable wire to a little box and the RCA jacks to you combo and you will turn your tv to channel 3 or 4
Jul 15, 2009 | Philips Magnavox DVD/VCR Dual Player
Tv works great, dvd is new , cant figure out the right hook up , dvd has 3 cables white yellow red
Red = right sound channel, white = left sound channel and yellow = video (picture) channel. if you have the connections matching these on the tv, then there should be an AV channel on the remote/tv control panel. Select this channel to view, if more than one AV channel on the tv, there will be a number next to the sockets you plugged into. Select the AV number and away you go.
If your tv doesn't have the correct sockets you can buy a converter to use the ariel socket on the tv.
May 28, 2009 | Televison & Video
Coby DVD player set up
Here are some things to remember when messing with cables TO and FROM electronic audio/visual
devices. YELLOW connectors are for what you SEE on the screen of your TV or other viewing device.
The RED/WHITE connectors are for what your ears will hear, LEFT/RIGHT in stereo or mono.
Now all you need to do is connect the YELLOW output jack of your Coby to the YELLOW video
input jack on TV. You must remember forever and ever that the YELLOW jacks and plugs never
contain or transmit or move TV channels or CABLE channels or DISH channels. The YELLOW cable
which has plugs at both ends goes to jacks (output to input) and carries/transmits BASEBAND VIDEO signals only. Now all you need to do is make the TV stop listening to it's antenna in, and to
start listening to the YELLOW/RED/WHITE jacks on the back of the TV. You will need find out how
to put TV into MONITOR mode, or AUX mode, or VIDEO INPUT 1. Basically just match colors and
OUTPUTS to INPUTS. Hope this helps you out.
louie12fix @ fixya
Dec 17, 2008 | Coby DVD-224 DVD Player
I am hooking up a dvd player with the black and white wires
The most basic hook up you can do is use a composite AV cable(yello/red/white). This cable should have come with your player. Check your TV it has those available inputs. They are also color coded. On the back of your player, there is only one yellow colored jack so there should be no problem in identifying where to plug the composite video cable(yellow). Put the composite audio cables (red and white) to the DVD player Audio Out jacks (red and white). Then plug the other end of those cables on the back of your TV. Just make sure they are INPUTS on the TV and colored the same - yello/red/white.
Then find your TV's correct viewing channel. It is not channle 3 or 4. Depending on the TV brand, it may be called AV, INPUT, VIDEO, GAME, SOURCE, AUX, EXT., etc. To find that channel, you may need to check the instructions on your TV manual. Most of the time, there are buttons on the TV remote control or on the TV itself. Sometimes, you need to go into the TV Menu.
Mar 27, 2008 | Philips DVP5140 DVD Player
very simple , just made sure dvd output hooked to the input of your tvs and same color ,jack to jack,you know, yellow to yellow,red to red ,white to white.But I suggest you use a s-video jack(all black). instead of the yellow composite ,or RCA jack,which give you a better picture,and if you have a the component jacks (red, blue , green)on both machine , that will give you the best picture, but remember , you still have to connect the red(right channel,+))and white(left channel,-)cable to have sound coming out from your tv.You will need a s-video cable or component cables for those option I suggested.
Nov 17, 2007 | Sony DVP-NS55P DVD Player
DVD player hook-up problem
Using the composite video connection method is pretty straightforward. you will be dealing with one video cable (marked in Yellow), and two audio cables (marked in White and Red) Red is right channel and white is left channel if stereo, if mono use the white marked cable. Look at the back of your DVD player you will see the video out RCA jack (marked in yellow) plug one end of the video cable into this jack, the plug the other end of the cable into the TVs Video In jack (marked in yellow) Then plug the audio cables into the Audio Out RCA jacks of the DVD player Red marked cable to red jack White Marked cable to white jack. After this is done plug the ends of the sother side of the cable into the Audio input of the TV white to white, red to red. At this point you should have video and audio once you set the menu of your tv to accept input from the Composite input and the audio jacks. I hope this helps.
Sep 10, 2007 | Televison & Video
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
