Where can i purchase a Timer switch for this model? Whirlpool TOP-LOADING Washer LSB6400LWD
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 29 Answers
Http://www.partselect.com/Models/LSB6400LW0/Parts/?pSearchTerm=Timer&start=1
Posted on Dec 21, 2016
Spins on one cycle, but not the other
sounds like timer is loosing contacts and time to replace.
Jul 21, 2010 | Whirlpool LSR7333 Top Load Washer
Our older top loading Whirlpool washer skips FILL
It sounds like you have a timer going bad.
Mar 06, 2010 | Washing Machines
I have a Kenmore top loading washer model #110 and won't agitate
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23912100
Also see the Whirlpool (Kenmore) Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The first thing I'd try is using a different cycle. If the washer works as it should, the problem points to the timer.
I'd also check to make sure that when replacing the switch, the connections to the timer haven't come loose.
Since you've replaced the Lid Switch, the motor has power for the drain and spin cycles.
These washers use a reversing motor. The motor turns one way for agitating and reverses for the drain and spin.
Since you cannot hear anything when it is supposed to be agitating, the problem does point to the timer or motor.
Nov 14, 2009 | Kenmore 22422 Top Load Washer
I hae a Whirlpool LSR8233EQ1 Top loading washer.
If you can catch it running while in the spin cycle but not spinning ( put a butter knife or screwdriver in the lid switch hole ) and wiggle the timer knob . If it starts spinning during this process , the timer needs replaced . Sometimes though , when a washer does everything BUT spin and you hear the motor running , the transmission is the problem .
Aug 16, 2009 | Frigidaire ATF6000ES Front Load Washer
My top loading whirlpool washer stopped after filling. Cycle dial does not engage any agitating, spinning,rinsing, nor draining activity. The dial does not advance with time, neither. Checked the outlet...
You could have a bad lid switch or a bad water level switch or a bad timer. In that order.
Open the control panel to access the components listed.
Make a small wire jumper and jump out the lid switch. Turn the timer on and see if it works. If yes, replace the lid switch.
If no, check power from the water level switch to the timer.
Terminals V to T should read closed on a meter set for ohms.
If the water level switch is closed the timer is bad.
Apr 22, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Looking for model# 84870100 kenmore top loading washing machine parts list catalog
Add a 110. to the beginning of the model number. That's 110.84870100, which is a direct drive convertible from the early 90's. I have the same model.
Feb 21, 2009 | Kenmore 3362625 Ss Washer Timer Knob ...
LSQ 9520 LQO Top loading washer
See the solution I provided under your other post. I believe your problem is attributed to a faulty lid switch.
Jun 12, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
