How to set up cable on model number FW40D36F - Televison & Video
How do I change from a cable input signal to an antenna input signal on a slyvania TV
I believe that the new flat digital antennas have a coax/cable connection on them. In the menu of the tv. You should select TV or Antenna for an input. You may be lucky and connect the antenna to your cable connector and get some local channels.
You should give us the model number of your set. As each tv is just a bit different.
Jul 30, 2015 | Sylvania LC420SS8 LCD TV
Monitor on but getting no picture. The setting is DVI
Are you using a DVI cable to connect the monitor to the computer? Try changing the monitor setting to analog if not using a DVI cable.
Sep 07, 2014 | ASUS LCD Monitor
My mitchibishi wont pick up cable stations, how to program, and my remote wont change channels
A model number would be helpful here--if the set will not program any channels it may be a problem with the set or the source for signal.
With no model number and no info on what or how you are connected to the set my answer is limited.
Jun 03, 2012 | Televison & Video
How to hook up cable box to model tz55x71 manufactured 2000 diagram please
You can Google the model number of the Toshiba for a 'manual" or owner manual which will show your set.
Usually with a cable box in goes to box and out to cable fitting on rear of set and set to channel 3. Output of a box with audio/video cables is same except they connect not to the cable fitting but to the rear inputs on back of set.
FYI most cable companies will come out, connect it and hook it up for little or no charge.
May 20, 2012 | Toshiba 50 Inch Big Screen Flat Tv Theater...
Setting up my insignia tv to cable
If you need to set your TV up for a cable connection, please enter the on screen Menu, then select Channels, then (depending on your model of TV) Video or Signal source. You should have two or three options: Cable, Cable/Satellite box, or Antenna. Select Cable if you will not be using a set top box. More details on selecting the signal source and setting up your Insignia TV can be found in the User Manual. If you need a copy, please visit InsigniaProducts.com, search for your TV model number, then click on the Support/Downloads tab.
Oct 20, 2011 | Insignia NS-7PDVD
I am trying to connect an Insignia flat panel TV to my existing Dish satellite system. Dish satellite system is not HDMI. We have: cable from the wall (satellite) connected directly to the new TV (exactly...
I really need to know the model number of your Insignia TV and which connections you are using between the Dish box and the TV to give you the correct answer. If you are connecting both cable and satellite, I believe it should be set-up as follows:
1. Connect cable feed to TV
2. Run auto channel scan on "cable" setting
3. Connect Dish box to TV and then try changing the "input" selection.
With the Dish box switched on to a channel number you know, try pressing the "INPUT" or "SOURCE" button on your Insignia TV remote repeatedly until you find the satellite feed. Once you have done so, you should be able to change satellite channels using the Dish remote.
If you need further assistance, please post back with the model number of your TV and details of the connections you are using on the back of the TV.
Regards,
BElectric
Dec 29, 2010 | Televison & Video
Need help setting up
I can help you set it up, however I need to know some more specific information.
i.e. what Brand & Model of receiver? I also need to know what other equipment you are hooking up, i.e. the TV's Brand & Model #, Cable boxes brand & model # etc.
Also I need a list of the cable you have. i.e.
Component Cables: These are typically a group of 3 or 5 wires. the 3 wire set will be colored Green, Blue & Red, where as the 5 wire set will also have a 2nd Red and a White.
Composite Cables: These are either a 2 or 3 wire set where there is a Red & White wire, and the 3rd if there is one would be yellow.
HDMI: These are a single cable with a wide flat connector on the end.
Digital Coax: This looks like the Component or Composite cable however it is a single cable and the color is Orange.
S-Video: This is a single Cable with a round end that has a number of small pins in the connector.
If you can provide me with the above info that I can help you further.
Dec 27, 2010 | Audio Players & Recorders
TV won't turn on after cable outage
No your set would not be like the HD52W19 model ,your model number is on back of tv year,chassis & Model # being 10 yrs old ptk195 model------- older Rca ptk169 these sets are 16yrs old.My guess without hands on chassis Bad Flyback Transfomer.
Dec 02, 2008 | RCA D52W19 52" Rear Projection Television
BROKE PART OFF TV-RCA F32665
Hi, some of those units have whats called a "RF cable" running from the back of the set to the tuner, and some are directly spot welded to the tuner, you need to remove the back from your set and see if yours is a short cable to the tuner, otherwise you have to replace the whole tuner, check the back of your set and you`ll see on a sticker the complete model number, (few numbers or letters after F32665) this is referred to as the service model number and I can look up exactly what you need to change
Nov 28, 2007 | RCA F32665 32" TV
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
