Will my dvd player work on thie hci tv.I hooked the dvd to the outlets in back of tv but I cannopt get the screen to see dvd
SOURCE: Orion TV1926A: Problem hooking up dvd player/Input screen won't come up
try to switch to aux1 or aux2.
Posted on Sep 26, 2008
  • 34 Answers
SOURCE: Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
Posted on Nov 16, 2008
  • 17 Answers
SOURCE: HDMI out to Olevia 527 TV = Blue Screen
Hi beelzyboob.. try checking these.. since you are using the RCA (composite cables) and I assume you have them on the "DVD in" at the back, go to setup, go to input assignment and go to hdmi input. here, make sure dvd is set to" ----". Next, hit return and go down to component input and also check if dvd is set to "-----". With these settings, you should get video. This is because you are not using either an HDMI or component cable. hope this helps.. ^_^
Posted on Nov 28, 2008
CRTN
  • 716 Answers
SOURCE: DVD Hook up-Olevia 266-T11
From Cable Or Rca Out Of Your Dvd Player To Your T.v. Make Sure You Push The Tv/Video Button To View The Dvd If Its Hooked Into The Rca Jacks.
Posted on Jan 14, 2009
SOURCE: DVD Hook up to Proscan TV
if using RCA connector cables, connect the left and right audio cables to D and D1, then connect the Video cable to the video connector right above the S Video port.
Posted on Aug 12, 2009
What channel on the hci tv can I view my dvd I hooked the red yellow and white jacks into the back of tv but cannot find a channel to view the dvd
You probably need to find a Source or Input button or menu item. Change the source from TV (if that is your current source) to A/V (or composite video). Depending on the model, there may be a source/input button on the TV. There will always be a sourc/input button on the original remote. If you are using a universal remote, you may need to try a different code to get the function to work.
On a few TVs, you can find this in one of the sub-menus. However not all TVs let you change the source in the Menu system.
I hope this helps. Please add a comment with the model of the HCI TV and whether you have the original remote or a universal remote to control the TV if you would like me to find the specific information for your TV.
(For example, the HCI RM22 III remote has the input button on the left side just below the power button.)
Dec 21, 2016 | Televison & Video
How do I get it to hook up to my tv and get it to play dvds
There will be a HDMI or Scart outlet on the back of the player. Plug this into the same on the TV, turn on and find the relevant channel on the TV and it should be working.
If you don't have the same inlet on the TV as the outlet on the player (i.e.only HDMI on player and no HDMI on TV) then you will need to use some kind of adaptor.
Sep 26, 2015 | Televison & Video
Craig dvd player, model CVD327, won't play
no, s video is not required to work. if you hooked up 3 colors to the tv 3 colors. make sure it's on video 1 or aux channel. and as long the dvd player is on and that channel is on, if that does not work, try on another tv that has same connection. if that doesn't work, then we know that dvd player doesn't work.
Oct 17, 2009 | Televison & Video
Do not know how to get regular T.V. hooked up to this system
try using the red White cables from back of tv to back of dvd player/receiver. Do the same with DTV/dvr or cable box. not sure if cable box has red and white cable outlets, however the DTV-DVR does, The quick patch is from TV to back of dvd (input audio)side,....that should work
Sep 26, 2009 | Coby DVD-937 5.1 Channel DVD...
Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Feb 01, 2009 | RCA DRC277 DVD Player
Trying to Install
Do you have the red, white and yellow hookups on the back of your TV????? If you don't then you need to get an RF Modulator. You can buy one at Walmart. Older TVs don't have the red, white and yellow hookups. You hook up the RF modulator with a short cable to the cable outlet on your TV. Then you plug in your DVD player to the RF modulator. You also plug your cable for the TV into the RF modulator. It really is very simple. Directions are included with the RF modulator. You will need a short piece of cable also.
Feb 04, 2008 | Panasonic DVD-RV41 DVD Player
RCA works fine when watching dvd but when cable is hooked up...
Similiar problem on this Chassis,( Popping + Sreeen Collapse)
Found Leaky 470 uf cap. near vertical output ic .( B+ Filter)
TechServices @Gmail.com
Sep 05, 2006 | RCA F20TF10 20" TV
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
