Ac unit blowing water with air on after a few minutes
We don't have any windows open, trailer is level, worked 72 hours ago. it's a duo therm ac unit
  • 6,674 Answers
2 things to check, one is remove filters on inside & look at front coils to make sure they aren't frosting/freezing up. The other, remove cover on upper unit & check that drain holes in base are not plugged. Be careful of wasp nests when removing cover. If neither one of those is problem, you may have a cracked drain pan, which you can also observe/inspect when cover off on roof unit.
Posted on Jul 21, 2009
I have a 2006 Gulfstream Cavalier 8'x 32' Fema Travel Trailer with a Dometic Duo Therm AC unit which I have recently replaced the fan motor on. Had the dealership bench test motor prior to lea
There is ice forming on the evaporator coils. This is either from a low freon charge or a leak in the seals or windows and doors. Could also be that the drains are not working and water is building up and freezing
Oct 10, 2012 | Dometic Heating & Cooling
Does not blow air through ducting
sounds like duct damage or restriction in duct work.
Sep 02, 2012 | Dometic 457915 Duo Therm Brisk Air...
My duo therm a/c unit is leaking water through my light fixture and not down the side of my trailer. its is blowing cool but not hard
You need to go up top, take the cover off and clean out the drain hole...then it will drain okay again.
heatman101
Aug 18, 2010 | Dometic Rooftop RV Air Conditioner
Duo Therm dripping water in camper when shut off. My Dometic Duo Therm Ducted AC drips quite a bit of water when shut off after running for several hours on hot humid days. The condensate lines are open....
Remove the filter at ceiling and run the AC on cool etc, and see if you can feel cool air leaking across to return air inlet where the divider between cold and return is. Check along all edges, etc for any cool air . Careful of wiring, but you should be able to get hand in there and feel especially around the edges where it should be sealed tight. Quite often a leak in that area causes cold air to enter return air and causes excessive condensation. Another thing to check is look way up inside opening for return air, with a flashlight and see if any dirt/dust on coils and fins of evaporator, and if so, needs to be cleaned off with a vacuum, and brush attachment. Let me know what you find.
Jul 10, 2010 | Dometic Rooftop RV Air Conditioner
Duo-therm brisk air AC unit leaks water into my RV when it rains
take the cover off and make sure the drain line is clear on top off RV.
Nov 15, 2009 | Ovens
I have a duo therm brisk air model 57915-001 leak
Could be the drain path is clogged.. Take the cover off & see if you can get it cleaned..
Jul 09, 2009 | Dometic Rooftop RV Air Conditioner
Duo Therm Quick Cool A/C fan motor cycles from low to high
sounds like the motor is either wired incoirrectly and getting 1/2 power all the time or it is going to ground. check out the woiring real good and duse your ohhm meter to check for gounds.
Dec 20, 2008 | Dometic Rooftop RV Air Conditioner
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
190 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
