Question about Kitchen Ranges
Clock on my self.cleaning stove keeps buzzing or humming and won't stop. I've tried turning all the knows and nothing works
catriver
  • 878 Answers
SOURCE: Error msg F3
Nolka, F3 has to do with the oven temperature probe out of spec. You need to change it out. Part number 316217001. Easy fix. Catriver..post back.
Posted on Oct 19, 2006
  • 146 Answers
SOURCE: Oven not working -makes a buzzing sound when turned OFF!
You just need to adjust your door latch assm. Try putting a little oil on the latch and arm. The sound you hear is the solenoid trying to pull the latch arm all the way back to lock the door. Even though it is pulling the arm back and the door locks it may not be all the way back. A little lubrication will fix the problem.
Posted on Dec 21, 2007
  • 26 Answers
SOURCE: clock on Model F120 stove Serial 53031577
just set the clock as if to clean , just remember to turn oven off in 2- 3 hrs wait 30 min then before trying to open dr.
Posted on Jan 09, 2008
SOURCE: jenn air s136 stove won,t self clean
You've probably already read pages 34 through 37 of the owners manual for this oven. We had this stove in the house we bought and the owner wrote in his own directions, which seem to work fine:
1. Turn knob selector to clean.
2. Turn temp knob to clean.
3. Close and lock door.
4. Push enter button and turn dial clockwise to desired time.
5. Push enter button again.
You've probably already tried this, but just in case I figured I'd pass it along.
Posted on Mar 21, 2008
  • 184 Answers
SOURCE: frigidaire electric stove keeps beeping
IF IT HAS A MECHANICAL CLOCK, THE START AND STOP TIMES NEED TO BE SET, THE OVEN CONTROL SET TO CLEAN, AND THE SELECTOR SWITCH SET TO CLEAN.
TO CLEAN NOW SET START TIME TO THE TIME ON THE CLOCK AND THE STOP TIME TO 3 HOURS LATER.
LOCK THE DOOR. IT SHOULD START AND THE CLEAN LIGHT SHOULD ILLUMINATE, OR OVEN ON LAMP SHOULD LIGHT.
IF IT STILL DOESN'T WORK, THERE IS A PROBLEM WITH THE CLOCK OR THE CONTROLS OR THE LOCK ASSEMBLY.
A WIRING DIAGRAM WOULD BE BEST FOR DIAGNOSING THE PROBLEM.
Posted on Apr 04, 2008
What buttons do I turn on my 25 yr old Kenmore stove to use the cleaning feature
I think that range had a mechanical clock. On it, you have to set the start and stop time (and push or pull the knob(s) to activate it), close the lock lever, and set the temperature and function dial(s) to self-clean. Unfortunately, if your clock isn't working (which is a common failure on stoves this old), you won't be able to run the self-clean cycle.
Sep 14, 2014 | Kenmore Kitchen Ranges
Just self cleaned. Now the Clean light stays on and the stove buzz's when the door is closed. Can stop buzzing if turned to another setting. But light stays on. Thanks
Seems like you found out the hard way what I wrote about in this tip...
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Jan 19, 2011 | Ovens
I have a 16 year old GE XL44 which has a manual turn clock that keeps buzzing. My husband stopped it, but it is going off again. The manuals I am finding on-line have electric clocks which we don't have....
Greetings,
Remove the power from the stove to prevent shock..remove rear access panal and locate clock....there will be a small motor attached to the clock..cut the wire going to the clock motor and tape....there are other ways, but this is easiest to explain..the clock will not be working after this...or, you can have your clock rebuilt or replaced with a current digital clock
Bruce Denton
Jan 04, 2011 | GE Ovens
I have an older magic chef I am trying to use the self cleaning feature. what am I supposed to have the two timer knobs set on? Or should I say the stop and start knob and the clock?
Start time should be set to current time of day (according to the clock on the stove) and the stop time should be set for at least two hours later. This will allow the timed oven feature to work for the self clean option.
***Keep in mind that if the clock does not work you will have to shut the oven off yourself after the two hours is up!!***
Good Luck!
Jun 15, 2010 | Magic Chef 31000 Gas Kitchen Range
Oven door locked and stove wont work turned the oven on to self clean and it just blew cold air.It did not clean and now the door will not open Please help.
I woke up one morning recently with the oven door on "locked." The stove works, but the oven door will not open. As far as I know, nothing in the oven works. The "door" sign shows up on the window where the clock is.
Sep 19, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Self cleaning frigidare oven FEF368CCTD
If this stove has knobs, Make sure the clock keeps time. If it doesn't you will have to manually turn this off. (DON"T FORGET OR LEAVE WHILE CLEANING) Make sure there are no large puddles of oil or grease on the bottom of the oven.If the oven is really dirty it may stink a little. Nothing but the racks can be in the oven.Press the lock button and slide the lock lever to lock the door. Set the stop time for 3 hours and turn the knob by the clock to auto. Turn the oven knob to clean. (MAY have to push to turn all the way to clean) It should start heating up. Let it finish and then cool down. It will not let you unlock or open the door until it is completely cool. Wipe out any remaining ash with a wet rag. ALL CLEAN!
Jun 28, 2008 | Ovens
Buzzing noise
The buzzing you are experiencing is most likely the electric valve solenoid coil.
That is the valve that lets gas in when the stove is turned on.
Another source of buzzing/humming can be a mechanical clock, if hter is one.
If it is digital, then it woul not make noise.
May 20, 2008 | Whirlpool GS563LXSS - stainless Steel Gas...
Frigidaire electric stove keeps beeping
Feb 20, 2008 | Frigidaire FEF336BC Electric Kitchen Range
GE Profile JGB97 Self Cleaning Oven Controls won't work
You have a problem that may be solved with my solution to the Dreaded F7 Problem. Even though you don't have a F7 error on the display the symptoms are all the same. You can find my fix at the following links.
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared this with more than 1550 folks and most report success. This problem often develops after a self clean cycle.
I hope it works for you too. Please let me know at the following:
hutchipop@yahoo.com
Good Luck,
Charlie Popeck,P.E.
Consulting Engineer
Feb 06, 2008 | Ovens
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
