SOURCE: Wurlitzer 1015 OMT 100CD
I asked a Wurlitzer engineer about this problem and he simply said, "Bend it a bit."
Sounds horrible but there is no genuine adjustment. But before doing that, try moving the carousel lock latch (at the 5 oclock position). This is what locks the carousel and determines its position when the correct CD number is reached. If you could ****** or advance it a little it might work.
Dave
SOURCE: Wurlitzer arm keeps running
check the white plastic actuator next to the gear box, it is probably broken and not actuating the microswitch underneath it, these often fail, it may look ok,, but it actually is loose and the set screw on top of it is not clamping it to the rod.
SOURCE: Wurlitzer 3600 series wont select a record ?
If the buttons don't latch in, the machine is not in credit. Put on free play or put some money in.
Dave F.
SOURCE: Wurlitzer Jukebox 1015 OMT won't play CDs
email me at [email protected] for the manual and service programme
Check the fuses behind the coverplate of the amp on the left. If it is a K99 it comes off by loosening the two nuts at the top then flexing it and popping the bottom edge off. If it is a Compact amp you can see the fuses.
