Question about Sony Televison & Video
Hi I have a Sony BD3000 Blu-ray dvd player it was working then went blank lights are on dvd door opens and closes but nothing comes up on the screen can it be fixed
SOURCE: problems using HDMI
I've had a problem with the HDMI connector, had it replaced twice while my VPL-HS60 was under warranty. This connector seems very fragile, the first time I was not getting any signal from HDMI, so the repair shop ordered a new connector and replaced it, a couple of days after the it was not working again and found that they had to solder it back on the board. If you're not getting a signal from HDMI anymore that could be your problem.
Posted on May 21, 2008
SOURCE: Blu-Ray player not reading Blu-Ray movie
I had the same problem - Fix - Go to the sharp web site and download the file HP21U_HP50U_PN902270. You will need to make sure your thumb drive is no bigger than 4gb and you do not have any other files on it. Once you download the file on the thumb drive, you will need to unzip the file on the same thumb drive. The zip file is one of the new ones, so you might need to go to the web and get a shareware program that will open it. After this - turn your player on and go to setting, next scroll down to update firmware, insert the drive and tell it OK, it will ask you if this is OK, tell it OK and it will upgrade the firmware in about 2 min. I have already done this with 3 other players with no problem. Good luck. The sharp web site is sometimes a little hard to find and to me was not the most user friendly. good luck Pruitt43@yahoo.com
Posted on Mar 31, 2009
  • 1121 Answers
SOURCE: My Sony Blu-ray DVD player isn't working with my LG HD TV
needs a HDMI™ (V1.3), tv set , or above. try to check the lg tv set is compatible to HDMI™ (V1.3).
Posted on Feb 19, 2010
Testimonial: "Thanks for the advice but I got it fixed myself, I had the Video Output set wrong."
  • 129 Answers
SOURCE: unlock sony blu-ray bdp-s370 player
Turn on the BD player. Press and hold the PLAY button and the STOP button until UNLOCKED appears on the front panel display.
Posted on Jul 26, 2010
MarkAmaranto
SOURCE: Program code for Sony Blu Ray BDP-S301
1516
Posted on Feb 04, 2011
What's wrong with my sony dvd player?
I would just replace it rather have repaired even if that's possible , they don't cost a fortune and are easy to fit.
Oct 20, 2014 | Sony Televison & Video
Sony Blu Ray DVD won't open, but disc inside is playing
hold on to open boton but it might take a while to open or the rubber that open and close the door is little bit slack that why its giving that type of prob, try and change it .
May 30, 2010 | Sony Blu-ray/dvd player BDP-S1
Cannot play 2012 movie on player , it loads and then nothing. The log shows 4 0000000. I push play and nothing
I also have the same problem. I just bought 2012 blu ray dvd, and tried to play on my sony blu ray player. The player kept on loading but nothing showed up. The log appears the same message 4 000000.
I thought that the disc is defective and tried to return it to the retailer. The retailer told me that Sony blu ray player needs to have the program updated. I never knew that a blu ray player needs to update its program. The retailer's sales took my disc and played on a PS3, and it worked.
I came home and went to Sony website to download a firmware update. Followed the instruction and did the update. After you update the player, it will be able to play 2012.
Mar 04, 2010 | Sony Televison & Video
My dvd playeer was playing fine until I pressed the setup button, from there I went into the screen with 480P, 780P, 1080P Etc.. I pressed 1080P and the screen went blank and I cant even get back into the...
Try pressing the HDMI button on the remote control to toggle the display output to something that your television will recognize. You can also try The progressive button and see if that helps. I am assuming you model is the XD-E500 model.
Jan 13, 2010 | Toshiba XD-E500 DVD Player
Disney princess dvd player will not play any dvd!
We had the same issue. Try clicking <play>1234<play> and it should unlockk the dvd in the machine. Seems to work on my daughters. It's a parental control of come sort. HTH.
Jan 17, 2009 | Disney Princess DVD Player
Only Power On light and Light on far Right come on
remove remote controll batteries and replace it , possibility get new ones
Apr 06, 2008 | Sony Blu-ray/dvd player BDP-S1
All I see is a blank blue screen on polaroid dvd player
try pressing the in/out button that should fix a blank blue screen
Jan 30, 2008 | Polaroid PDV-0701A Portable DVD Player
DVD not working
When I turn on the DVD player the light comes on buts thats it. Just blank screen, and no sound anything whatsoever.
Dec 12, 2006 | Philips MPD720 Portable DVD Player with...
Blank Screen
The screen in your dvd might not be getting the volts it needs to work,the ribbon cable that comes from the base gets broken sometimes because of the hinge action of open and closing constanly.You need to call RCA at 877-794-7977 and ask for an estimate or an idea of how could cost to repair.Good luck.
Oct 17, 2006 | RCA DRC16N Portable DVD Player with Screen
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
