Need to connect to internet - Computers & Internet
I need diagram to connect t3624, I can't connect
A Diagram to connect to the internet? No Such Thing!!!
If you are having problems connecting to the internet tell us what is going on. What happens when you click on Internet Explorer? Do you have an Internet Service Provider? Did you pay the Bill?
Mar 25, 2012 | Gateway Computers & Internet
Router operation without Internet connection.
Yes i can help you with this
You dont need internet connection
Feb 12, 2008 | Linksys Wireless-G WRT54G Router
How to get internet work in samsunge250i
Hi Hello, you want to connect the internet, try this if you to connect the internet you need the GPRS setting on your cellphone, and if you that setting i think you are successfully connect to the internet.
but you need to load you sim before you connect the internet. i wish that i help you. :)
Sep 20, 2011 | Computers & Internet
404 error on samsung SGH E250 while connecting internet .......help me with a solution for this
Sep 05, 2011 | Computers & Internet
Internet connection setting is on wired and i need to change it to wifi
I believe this website can answer your problem.
Note: You need either an "Xbox 360 S" console with built-in WiFi or an "Xbox 360 Wireless Networking Adapter" to have a WiFi internet connection. If you can use a wired internet connection, you should use it because a wired internet connection connects faster than a wireless internet connection.
May 31, 2011 | Video Game Consoles & Games
Do we need wireless internet to be able to install our internet tablet mid 7015 4G?? If we can connect with regular internet how do we go about doing this?
If you need to connect to internet by wire then you need the following.
  • An internet connection
  • A Router that has RJ-45 port(s)
  • A straight network cable
  • Device with RJ-45 port with built in LAN card (In your case it is "internet tablet mid 7015 4G"
Connect the straight cable with the router and connect the other end with your device where you want the internet.
Mar 28, 2011 | Computers & Internet
Where i can connect internet line?
To connect to the Internet you need a few extra things aswell as a network card.
1. You need to sign up with an Internet service provider.
2. Connect a LAN cable from your computer to the DSL or cable modem
3. You need a DSL or cable modem and connect and configure the modem to inaccordance with your Internet service provider's instructions.
4. Install Internet Explorer if it has not been done.
5. If everything has been done correctly, when you open Internet Explorer youcan access the Internet.
Mar 08, 2011 | Compaq Armada 4220T Notebook
Modem
Assuming that Windows has recognized the modem, and has loaded the correct device-drivers, Windows can use the modem.
You'll need to find an Internet Service Provider that provides "dial-up" service.
You'll need to have a land-line telephone (not a cell-phone) with your local telephone-company.
Connect a 4-wire cable (not an 8-wire Ethernet cable) from the "line" port on the modem to the telephone wall-jack.
Then, follow the instructions given you by your Internet Service Provider to configure your modem to connect to their dial-up server. Or, telphone them, and their Technical Support staff will guide you through the necessary configuration steps.
Apr 09, 2010 | D-Link DFM 562IS (DFM-562IS) Modem
Internet
Start from ground zero
1. Is everything Powered up?
2. Check you internet connection
a. Can you directly connect to the internet by connecting a computer to the device providing the internet?
If this is good, then do this for later. ( it may not be needed but is good to have)
go to 'Start' -> 'Run' ->CMD[Enter]
Now you have a DOS box.
here
type CD \[Enter]
type IPCONFIG /all > ipdata.txt[Enter]
exit[Enter]
This copies the working IP Config that may be needed later.
Now connect in this order Internet connection to WAN Connection of router
Then connect one of the the LAN Connections of the router to
the working computer.
Turn off everything for 15 min.
No I am not kidding. Technical reason: Clear the ARP Table back at the ISP.
Restart the router then the computer.
Still no internet?
More details will be needed.
Router Make and Model
Internet Connection Type
Computer Make, Model OS and Version.
Good Luck
Jan 02, 2008 | Zyxel Prestige 660H Router
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
