How to i set up closed caption on a pace 1056B04 remote suddenlink
circuitcity
  • 137 Answers
SOURCE: closed caption and black square
your TV do not disable close caption in composite mode. It may in component mode. Please make sure that the close caption in your TV menu is not set to "text"
Please be advice that CC :Text is the ONLY one that can give you a black box.
Best regards
Circuitcity
Posted on Dec 09, 2007
  • 3 Answers
SOURCE: can't get closed caption when i'm playing a DVD
I had the same problem. My DVD was connected to my HD TV via a HDMI cable as was recommended by the DVD Owners Manual. I removed the HDMI cable and connected the three video component cables to the TV and DVD player. Closed captioning crossed immediately. Either my HDMI cable was defective or CC doesn't cross very well with a HDMI cable.
Posted on May 04, 2008
Agent Jason
  • 78 Answers
SOURCE: close captioning
Hi ckay31,
If your remote is not allowing you to navigate through the menus, you may need to replace the batteries.
If this does not work, in the meantime you should be able to navigate the menus using the menu button on the TV. The Closed Captioning option should display under Channel Settings.
If you are still unable to get your remote to function properly, I recommend you contact Westinghouse Customer Service at (866) 287-5555. You may also view your product's manual at http://www.westinghousedigital.com/pdf/15_User_Manual.pdf
Thank you,
Jason,
Go Ahead. Use Us.
Posted on Jun 16, 2008
SOURCE: Sony 46" XBR2 Cannot turn off closed caption
With TV on, turn off DVR and hit menu on DVR remote - you can disable CC from there.  Worked for us - got the idea from another fixya post.
Posted on Aug 28, 2008
  • 32 Answers
SOURCE: How to activate "closed captioning" for a Proscan Full HD 1080P
Comcast's remote has nothing to do with closed captioning. It's on your tv remote. First, the tv has to be capable of handling closed captioning, and your's is- and second, the program must have closed captioning provided- current programs do, some older shows do not support closed captioning. Recheck your remote, and if necessary- look at the setup instructions that came with the TV- they should also be posted online at the Proscan support site.
Posted on Apr 02, 2009
How do I turn the closed caption off? I have a remote
      Immediately-within one second-push the MENU button on your remote. You should see a User Settings menu screen displayed. Use the arrows keys on the remote to highlight the Closed Caption option and press OK or SELECT on your remote to toggle Enable/Disable. Power on the Set-Top Box to return to watching TV.
      How do I turn Closed Captioning on or off? ' Time Warner ...
      www.timewarnercable.com/.../closedcapt/how-do-i-turn... Time Warner Cable
    Feedback
    How do I turn on/off closed captioning? - Comcast Help and Support ...
    forums.xfinity.com/t5/.../How-do-I-turn...off-closed-captioning/.../1325...
    Jun 25, 2012 - Turn STB off and leave TV on; Press Menu on STB or remote control; Using the ... If this does not activate Closed Captioning, try the following:.
Jan 24, 2016 | Televison & Video
How do I turn off closed caption
Sometimes it isn't the remote, it is the cable or satellite set up menu. Try Menu/Setup/Closed Captions and see what happens.
Feb 21, 2015 | Logitech Harmony 670 Advanced Universal...
Turn off close captioning on Suddenlink 1056b01
Hi Patsy - Ashley here with Suddenlink. For information on how to turn Closed Captioning on and off, please visit our help site at this link: http://help.suddenlink.com/television/Pages/ClosedCaptioning.aspx
If you have any other questions, please feel free to contact me directly at socialsupport-AT-suddenlink-DOT-com. Thank you.
Jul 19, 2014 | Televison & Video
I have no remote, how do I get off close caption on a TS2554C101
There is a Menu button on the TV for the TS2554 C101. Press this button to get the OSD menu. Then press the vol +/- buttons to highlight Set. Use the Ch +/- buttons to get Closed Caption. Then press Vol+ or Vol - to get the closed caption menu. Use the Ch+/- buttons to set the desired closed caption setting and then press Vol + or Vol - to confirm the selection. Press Menu again to exit.
This will only help if the captions are being interpreted by the TV. If there are open captions, they will not go away. If the closed captioning is on at a set top box, you will need to turn them off using the controls for the set top box. (I know satellite receivers have independent captions available.)
I hope this helps. If your TV doesn't have a menu button on the set, you will need a remote that has a matching Menu function. Some universal remotes should have this feature.
Apr 28, 2011 | Philips TS2554C 25" TV
I have enabled the closed captioned feature on the suddenlink dvr and now I cnn not turn it off, please help
Hi - My name is Tina and I am with Suddenlink. Please see the following link on our Support site for instructions on how to enable closed captioning... To disable, follow the same steps, except choose "Disable or Off" (depending on your DVR. http://help.suddenlink.com/Television/Pages/ClosedCaptioning.aspx
Oct 06, 2010 | Motorola Televison & Video
I have a panasonic TV. direct tv remote for a . while programming the timer, somehow closed captioning got turned on & i after hours of trying to get it turned off, NO LUCK. it's driving me insane!!...
I could do better with a picture of the remote. Closed captioning is usually a multi-press button, that is each press takes you through each of the four types of closed captioning and then off.
You can enable closed captioning on a DVD Recorder, it looks like the TV, but its only on the picture from the DVD Recorder.
If you have a PVR, you could have closed captioning on on that device.
Try tuning off everything else to make sure it IS the TV.
Turn on the menu and find the closed captioning settings and set to OFF.
Press the close captioning button on the remote (If there is one) and press CC repeatedly until it says OFF.
Try and control close captioning, timer and menus with the ORIGINAL remote and not a programmable one.
Programmable remotes are not always completely compatible.
Mar 20, 2010 | RCA Universal Remote Control
Need to know how to put the tv on close caption
Captioned programs are marked in TV listings by "CC". so press the cc button on the remote and the closed caption option will be applied.press that cc button again to turn off the closed caption option.
1) Check the size and manufactured year of your television. If it was made after 1993 and is larger than 13 inches, it has a closed captioning system built into it. Otherwise, you may need to purchase a separate closed caption system, which are available at a number of online outlets.
  1. 2)Turn on your TV and access the menu for closed captioning. The precise location of the menu varies by television set. Most are accessible by pressing the "Audio" or "Set Up" menu on your remote, then scrolling down to the "CC" or "Closed Captioning" option. Check your owner's manual for precise instructions.
  2. 3)Turn the closed captioning option to the "On" position. It will then run closed captions for every program that broadcasts them. Newer sets may allow you to adjust the size, font and colors of the closed captioning letters to fit your individual tastes.
  3. 4)Tune to a particular program for a few minutes to make sure the closed captions are working. Note that while many broadcasts run closed captioning, not all of them do. If the captions don't appear, check your TV listing to ensure the program includes them.
  4. 5)If you're watching a DVd on your TV, access the DVD's "Set Up" menu. It should have captioned options, which allow you to show captions in English and possibly other languages as well.
  5. thanks.
Nov 11, 2009 | Televison & Video
How do I get the closed captioned turned off my Phillips TV?
Check the menu or display set up - highlight Closed Captioning with remote and disable, if you are using cable box - and have no success, go to the settings on the cable remote and check the closed captioning there.
Aug 02, 2009 | Philips 32PT6441/37 32" TV
Closed caption for durabrand
if you have the menu button on the tv itsself then you can go from there to remove th closed caption
May 10, 2008 | Durabrand DWT1905 TV
Closed caption activiting on everytime tv is turned on
If you have the Suddenlink remote and the DVR box you can turn captions on or off by accessing a technical menu. To do this, press POWER and Menu buttons together (menu 2 times) to bring up a special menu. Select Closed Captions. On the popup menu select closed captions and using Select button change to OFF or ON as you wish. The trick is to get the menu to come up. Timing of pressing the two buttons is frustrating and it may take a few times befotre you get the special menu.
Oct 02, 2007 | Televison & Video
Televison & Video Logo
104 people viewed this question
Top Televison & Video Experts
