Question about Viking Dishwashers
VDB301SS Viking dishwasher when I press any of the buttons it just beeps 3 times and then the start button flashes 5 times. It won't start.
  • 188 Answers
SOURCE: clean light flashes
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Posted on Feb 20, 2009
SOURCE: Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Posted on Apr 18, 2009
  • 72 Answers
SOURCE: Dishwasher won't run programme
First thing, check input and output. That is, make sure it gets water (in-line water filters may be clogged), and on the output side make sure the drain pump is working and that the drain tube is not clogged.
Best of luck!
Posted on May 21, 2009
rylee_smith
  • 8619 Answers
SOURCE: my dishwasher isn't working. The clean button
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, and then repeats this occurs when the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 12, 2010
  • 34 Answers
SOURCE: After selecting a program, the
Basically the dishwasher is telling you there is a fault - Not so useful I know! Plug out the machine and leave it for five minutes and see will it reset. If that does not work, you will need to reset it manually. To do this consult the manual. If you don't have a manual, go to http://www.hotpointservice.co.uk/hs/pages/manual/manualSearch.do and down load one. Good luck!
Posted on Aug 13, 2010
Is there a reset button on frigidaire dishwasher model fdb710lcb0
Mate im in Australia and don't know if the Frigidaite is the same as the Electrolux/Westinghouse but you can try this I posted a day ago:
On the Westinghouse and Electrolux dishwashers to reset a program that it defaults too you start the program and once initialised then press and hold the program button for about 3-5 secs. The panel will beep and all the lights will come on and not flash. From there on using the program button you select the wash cycle you want
May 28, 2016 | Frigidaire Dishwashers
We have a whirlpool ADG 7800 dishwasher ,getting a beeping sound and start button flashes 12 times? Any help
Hi
Ok try this and see what happens.
Hold the start button again till it beeps
Then select the first cycle on the left which should be the rinse cycle
Then turn the dishwasher off
Then press and hold the start button and with this held in turn the dishwasher on.
Once the start light is flashing let go
Now press the start button once and close the door.
Now it will run a 12 minute test cycle. If it goes wrong it will drain the water out and beep. So open the door and count the number of flashes from the start light inbetween the pause and let me know.
Regards
Oct 11, 2014 | Whirlpool Dishwashers
My viking 450E start button is not working - the cyle buttons light up blue and then the start button should start flashing so that you can press it to start but the start button never flashes - I have...
It's likely that the cheap POS start switch under the button has fallen off the cheesy plastic mounting and the button isn't contacting it. Put it back so the ears on switch are under the slots in the panel and dab a TINY bit of super glue where the tabs go into the panel.
www.appliancefixxa.com
Feb 02, 2012 | Viking VDB450 Dishwasher
I can't get the control panel to reset. The wash cycle light comes on but it just beeps and the dishwasher won't start. I press the start button and it stops beeping for a minute but it still...
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
Jun 24, 2011 | GE Nautilus 24" Built-in Dishwasher
Flashing start button, beeps, no other button functions
does it flash say 8 times then a little break then flash again 8 times or 9 or 10 . The flashes are giving the type of fault you have. Say 3 flashes then a tiny break then 3 flashes and a tiny break so on...
Mar 20, 2010 | Whirlpool Dishwashers
Viking Designer Series DFUD041 Built-in Dishwasher
Did you try the power on button all the way to the left?
Jan 27, 2009 | Viking Designer Series DFUD041 (Premium)...
Dishwasher will not start
you can hold the start atop button down for 5 seconds to re set it or you can turn off the circuit breaker to the dishwasher for 20 sec. That should help. If not, it probably is a bad celenoid which a repairman needs to replace
Nov 17, 2008 | Viking 24 in. Professional Series DFUD140...
Cannon BJC 80
5 times try this:
1: Unplug Power Cord
2: Hold POWER and RESUME buttons
3: Plug in Power Cord
4: Release buttons after the printers starts up
5: Hold CARTRIDGE and RESUME
6: Press POWER
7: Release all buttons after the beeps
8: Press CARTRIDGE 16 times
9: Press RESUME
10: Unplug the Power cord
3 times, probably something wrong with the cartridge.
Nov 21, 2007 | Canon BJC 80 InkJet Printer
Troubl
This is for when it beeps 8 times, but you might try this...
You should clean or replace the absorber pad at some point but most of the time you can get away with resetting the ink counter a few times before you need to clean or replace the pad.
6: Press POWER
9: Press RESUME
Aug 19, 2007 | Canon BJC 85 InkJet Printer
Dishwashers Logo
126 people viewed this question
Top Viking Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Lloyd Carter
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
