Question about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
Pool vaccuum when i hook up my vaccuum to the skimmer it sucks really good for the first minute then it stops. Do i need a new vaccuum?
  • superflyal17 Jul 21, 2009
    yes i am filling the line with water. I just got it working really good one time but it took over an hour. Do i need to fill the hose before i hook it up to the vaccuum end?
    President:
  • 2,559 Answers
Are you filling the vacuum line with water before hooking it to the skimmer?
Posted on Jul 21, 2009
How do you hook up vacuum to pool without skimmer?
Every Pool has to have some type of suction hook it to that
Jul 13, 2016 | Pool & Spa
Pool cleaner starts and then stops working
Check for water flow / water flow restrictions / and water flow blockages.
Many things create water flow reductions: Dirty filters, plugged impellers, packed with debris baskets - both skimmers and at pump, closed to partially closed valves, air suction leaks: worn shaft seal, worn orings at pump lid or pump volute body, low water level, stuck skimmer weir blade/gate in the up position & skimmer empties and air is sucked into the system which may cause the pump to lose prime. This a problem that goes un-noticed and is hard to detect even by some service technicians!
Jan 31, 2014 | Pool & Spa
I'm trying to drain a pool that's Ben sitting for years full of nasty water. Pump works and operates but the fill pot on the pump itself will not stay full
Sounds like you're trying to pull water from skimmer and main drain. Soon as the level goes down, it sucks air from skimmer. Turn off skimmer line. If that's not possible, then cut off input side of pump(front pipe) and run new line to pool. Just lay it on top of ground and keep it below top by a couple of feet. This will stop all the **** on the bottom from plugging up the pump.
Mar 08, 2011 | Pentair Pool & Spa
Moves slowly and the stops. looks like diapham doesn't open back up
This seems to indicate insufficient suction from skimmer. Confirm that all other skimmers are closed off properly. Suction can be checked by disconnecting suction hose from pool cleaner and placing your hand over the end of the hose. Suction hose may also have an obstruction which will inhibit proper operation.
Nov 28, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
How do I vaccum the pool? I dont know if I turn the Veriflow to out and then where do I hook in the hose?..Its my girlfriends pool and she just expects me to know. Thanks
Oh then you DO need help. To vacuum you don't need to change the valve setting on the filter, but if there is a valve on the intake selecting main drain/skimmer you can select skimmer only, but I usually only do this after I have the hose primed. . You attach the hose to the skimmer inlet. Usually there will be a round plate attched to the hose that fits into the skimmer ( you may have to remove the basket) If you don't have that round plate on the hose, then you can insert the hose driectly into the bottom of the skimmer. Before you attach the hose, connect it to the skimmer head on the pole. Submerge the head and hose. Allow to settle to bottom. Put all the hose into the pool. Take the other end and hold over the discharge back into the pool to fill the hose with water (prime) until air bubbles stop coming from vacuum head. Then hold your hand over the hose (to keep from loosing prime) and quickly attach to skimmer. You may hear some air, and the pump may stop pumping fully mommentairly untill it is pumping full water again. Now you can select the valve to divert all the flow from the skimmer
Aug 13, 2010 | Hayward SAND FILTER, PRO SERIES
All DE is NOT getting sucked into the skimmer...why? Some went in and the rest is flowing out of the skimmer into the pool
You should always mix DE with water and make a slurry mixture. When you put dry de in the skimmer it will collect in the pump basket and slow or stop the flow of water being sucked through the pump. When that happens the de will just flow away from the throat of the skimmer just like you describe.
Apr 05, 2010 | Hayward Pool & Spa
Zodiac Barracuda stops moving
Depending how you hook it up to the pool you need to be sure it is getting enough suction. If this is a dedicated line be sure that the valve is going all to the cleaner and back off till the pump quiets down. If you have it running through the skimmer be sure the dirveter valve is set to the proper suction and if you have a skimmer plate be sure your main drain is plugged off. Also check in the cleaner again. Things can hide in the diaprahm so be sure to use something that will let you go all the way beyond it or take apart to check if you have to. Good luck.
Dec 17, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Vaccuuming
Do you have a 'Earth' dirt filter system?
If yes - these system clog up very quickly when 'vac'ing - if can - when pool is v-dirty - 'vac' on waste setting (will loose lots of water but)
Also - get yourself some filter socks for the skimmer box filter - this will help heaps!
When can / if can - repalce filter system with a sand filter system - much easyer to use - easyer to vac pool - easyer to add chemicals - just easyer.
Jun 29, 2009 | Hayward SAND FILTER, PRO SERIES
I have the 15' X 42'intex metal frame. Pool and
YOU CAN DO THIS 2 WAYS IF YOU WANT TO USE SKIMMER THERE IS A PIECE THAT GOES INSIDE SKIMMER TO ATTACH YOR VAC HOSE TO HEAD O VAC FITS ON END OF POLE TWO PUSH PIN ATTACH HOSE TO VAC HEAD AND INTO SKIMMER IF YOU WOULD LIKE TO BYPASS HOOK VAC SAME WAY BUT DONT USE SKIMMER PUT HOSE OVER POOL AND DRAW WATER JUST ENOUGH TO CREATE A FLOW BY PUTTING THE END OF HOSE OUTSIDE POOL TO A WET VAC JUST LONG ENOUGH TO GET WATER FLOWING DONT KEEP IT CONECCTED LONGER THAN 20 TO 30 SECONDS GOOD LUCK
Jun 27, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
379 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
