Question about Canon PIXMA iP90 InkJet Printer
Printhead part number for canon pixma ip90 - Canon PIXMA iP90 InkJet Printer
Mike258
  • 1498 Answers
SOURCE: canon pixma ip90 green light
Hi there SWCopiers,
Four flashes indicates 'Ink tanks installed incorrectly' or 'Printer needs repair'.
Click here for iP90 ink tank install procedure.
Click here for reset procedure.
Click here for instruction on contacting Canon Support. They have been very helpful. If it turns out that one of your ink tanks is faulty, they have replaced them at no cost in the past.
Hope this helps.
Remember: Good things come to those who Rate!!
Mike
Posted on Aug 07, 2008
SOURCE: Canon Pixma ip90 printer
service error 5100
Posted on Jan 04, 2009
  • 5 Answers
SOURCE: Print head for Canon Pixma
take print head out of printer and put a couple of drops of inkjet cleaner on the gauzes, dab off, reassemble and run the deep clean a few times. Printer should then work.
Posted on Apr 15, 2009
  • 6 Answers
SOURCE: IP90 WONT PRINT BLACK
I had this problem recently with my IP90. Both the black and color heads were clogged. After running the "canned" routines several times to clean the heads and deep clean the heads...still didn't help...here's what I did:
1. open the top lid to have the cartridges that are inserted in the print head move to the middle of the printer.
2. remove both cartridges
3. What is left there is the print head holder. Slightly move it to the right and gently lift the print head lock.
4. Grasp the print head and lift it out of the tank.
5. Have several paper towels hand and know that you will have color and bw ink on your fingers
6. Put the print head on the paper towel
7. Pour rubbing alcohol on the blk and color heads and let them sit of about 10-15 minutes.
8. after that dry the heads and re-insert them in the printer
9. I put new cartridges in the printer and ran clean and deep clean a few times.
10. My color and black and white print came right back!
Hope this helps.
Posted on May 25, 2009
  • 71 Answers
SOURCE: Canon Pixma iP90 - Jagged text and lines
The printer has a plastic band that runs from one side to the other. The print head has a sensor that passes over it each time it moves. The band is a little transparent and appears to have vertical lines in it. That needs to be cleaned.
  1. Remove power from the printer,
  2. Wipe it clean,
  3. Move the head manually to other side to clean the other areas.
Hope this helps.
Posted on Jun 02, 2009
I can not get my printer to print. The yellow and green lights continue to flash. My printer is a canon ip90
hello, if you count the number of blinks green-orange=1, the amount of blinks will give the error, or where to look, normally 5 blinks will be printhead, 7 will be waste pak will need replacement, there are a few more, but these are the common ones, if you can find a printer repair place, they should be able to work on these, they are somewhat simple.
Oct 14, 2010 | Canon PIXMA iP90 InkJet Printer
I am getting an error message for my Pixma iP90 Printer and it is 5C00 can you help
5C00 is a purge unit error, the purge is the unit that cleans the printhead on the right hand side. If the printhead will come out of the right side, you will need to check for paper scraps caught in there, If stuck on the right you will need a shop to check it out for you so you don't break anything. You need to remove covers and printhead and check under the printhead in the purge unit.
Feb 22, 2010 | Canon PIXMA iP90 InkJet Printer
New canon ip90 printer prints blank pages
New it should have warranty, Canon suggests trying cartridge first, at least 3 deep cleanings, still blank you need either printhead or shop to service.
Jan 12, 2010 | Canon PIXMA iP90 Mobile Printer
Calibration of cannon ip90 printer
There is no calibration for that printer. You can align the printhead, clean the printhead, run nozzle checks all from printer properties in your control panel under maintenance.
Dec 23, 2009 | Canon PIXMA iP90 Mobile Printer
IP90- peformed all of the cleaning procedures
It may need a new printhead, QY6-0052-000, but there is also a firmware upgrade the shop has to do to help black cleaning.
Nov 25, 2009 | Canon PIXMA iP90 Mobile Printer
My new canon ip90 printer won't print anything goes through all the motions but no ink comes out. brand new cartridges in it?
Is the shipping cover still on the printhead? If it has been removed, wipe the printhead with a damp paper towel to see if the head is plugged. If ink is present on the towel, do a print head clean from the maintenance menu.
Oct 11, 2009 | Canon PIXMA iP90 Mobile Printer
IP90 won't print black. Replaced ink, deep cleaned heads, etc. Will print color, but not black.
You probably need a new printhead, but there is also a new update for that machine to help clean the black part of the printhead. QY6-0052-000 is the printhead #
Sep 24, 2009 | Canon PIXMA iP90 InkJet Printer
Canon iP90 error 5C00
5C00 is a purge unit error, thats the cleaning unit on the right where the printhead parks. Look inside with a flashlight, if nothing is blocking it's operation, you willl need a new print engine, qm2-2020-000 around $150.00
Jul 21, 2009 | Canon PIXMA iP90 InkJet Printer
Ip90 printer does not print blac on a test after
Sounds like the printhead is plugged on the black side. A new printhead is #qy6-0052-000 around $40.00. That model also needs a firmware update to help it clean the printhead better.
Jun 23, 2009 | Canon PIXMA iP90 Mobile Printer
Canon iP90 only prints blank pages
there are two possible problems for that, either there is a problem on the pump assy or the printhead is clogged. if you have a spare printhead, try replacing it first along with a new ink otherwise have an authorized service center to look at it coz maybe it has a problem on the cleaning mechanism
Feb 18, 2009 | Canon PIXMA iP90 InkJet Printer
Canon PIXMA iP90 InkJet Printer Logo
26 people viewed this question
old marine
old marine
