Question about Optics
Remington breakbarrel,does it pump more than once and how mfs will it shoot it was made in 2009
  • 2,189 Answers
It is a spring piston air rifle so only requires one stroke to lock the piston back
Posted on Dec 22, 2016
Sighting my rifle scope
Mount scope on rifle with the eye relief you are happy with
set up a target at 10 yards and fire 5 rounds of until you are grouping tightly ( no fliers ) you may want to use quite a few targets once you are happy with the grouping remove the adjustment covers on the scope
the top one is for moving the point of impact up or down
the side one is for left or right
depending on the point of impact you need to move it up or down to meet the cross hare once you get the point of impact on the same hight line as the aim point you can move the side adjuster to move the poi to meet the aim point
then move the target out to 20 yards and repeat the above again
then move the target out to a distance that you can put 90% of your shots inside 40mm or better and that is your max range for live animals
Dec 15, 2017 | Remington Optics
Rim or Centre fire
If it will be your first gun then rimfire as its cheap ammo so can get lots of practice . low recoil and great for learning the basics of shooting
Centerfire is more powerful and can shoot farther so can be used on larger game but ammo is that little bit more expensive depending on calibre used
So it comes down to what you want out of your shooting what rimfire does at short ranges centerfire does at longer ranges ballistically speaking
Mar 11, 2015 | Optics
Can't reassemble Remington model 31 shotgun
Dear George,
GO to this link. FirearmBlueprints net Firearm Blueprints Construction Guides More . Should you want to subscribe for a minimal fee.
Dictionary explanation Remington Model 31
Here you go sir. A you tube made for you. Remington Model 31 disassembly by D Tom
Stray offers his approach in this video for your comparison.
Remington 31 disassembly
Fare. Well.
Dec 02, 2011 | Remington Sports Remington 12 Ga...
Why is my remington 1911 r1 shooting low
What model, ammunition, sights, and distance are you shooting?
Apr 14, 2011 | Remington Sport & Outdoor - Others
Wipers only work on fast speed. The intermitten will not work. When you turn them off they stop at that position.
This is most likely a problem in the Wiper stalk control, although the wiper motor should complete the wipe cycle and Park the blades.
The wiper control is a part of the multifunction switch that it is mounted in. The switch is called an MFS and it is usually replaced as a unit. To replace the MFS switch you will need to remove the steering column cover and on some models, the Ignition switch. The Ignition switch may have a wide round flange on it which will prevent the plastic steering column cover from coming off when you want it to.
The problem can also be in the connectors which attach to the MFS, so I would recommend checking for a loose fitting connector and then trying the wipers again. Be careful not to break the tabs holding the connector to your part. Look for corrosion in the pin connections.
There are several female Torx bolts holding the MFS in position. They will have to be removed and replaced to change the MFS. It is not impossible that the wiper motor is also bad. You will know if the blades still refuse to Park. The intermittent feature and the speeds are part of the MFS switch and that part should work once the MFS is replaced.
If this does not sound like a job you want to perform, a Body shop or Independent mechanical shop can do the job; so can a Dealer. The MFS can run between $65-$95.
Nov 20, 2010 | 2000 Mercury Grand Marquis
Mosberg 12 ga pump. Once you load then shoot it drops shells.
Thewre is a U shaped silver piece that is supposed to lift the shell up to the chamber so it can be pushed in. Is it missing or damaged?
Apr 05, 2009 | Remington Sport & Outdoor - Others
Remington shaver ms 280 screen has a hole
How do you replace (change) the screens on a Reminton MS-280?
Dec 04, 2008 | Remington MS280
Optics Logo
32 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
