Question about Home
I have a seiko melodies in motion wall clock. How do I get it out of demo mode? there is only the black demo button.
  • 101 Answers
SOURCE: Aiwa CDC-X504Mp stuck in demo mode
This recently happened to my Sony, maybe it will help u
If this cd player has a removal fascia then try..
Carefully inspect the the electrical contacts on the fasica and the cd player. If it has got dirt on them then CAREFULLY CAREFULLY clean with cotton swab dabbed in cleaning Alcohol.
Posted on Jan 09, 2009
  • 9 Answers
SOURCE: micro wave cuts out after 20ish seconds
Try this...
Press: Function 0 2 to turn off demo mode. For future reference, Function 0 1 should turn demo mode back on.
Posted on Feb 01, 2009
  • 15935 Answers
SOURCE: The function DEMO MODE can´t be set off. I want to
CLICK HERE for a PDF version of your manual.
To turn OFF DEMO mode - go to page 50 of the manual.... and find the following-
1 Select the Demonstration mode
Push the Control knob to [FM] or [AM].
Select the "DEMO Mode" display.
2 Set the Demonstration mode
Press the Control knob for at least 2 seconds.
Each time the knob is pressed at least 2 seconds,
the Demonstration mode switches as shown
Demo Mode "ON"
Demo Mode "OFF"
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 10, 2009
SOURCE: how do i take unit out of demo mode and set clock?
hold your sel. buton you use to get to bas, mid, and treble, and hole it down for a while till a new menu pops up. scroll using up/ down buttons till you see demo and left right changes the setting for it
Posted on Jun 11, 2009
  • 1970 Answers
SOURCE: I have a seiko musical wall clock that no longer
mcdevito75 here, I'd bring the clock to a small watch repair shop in the area and have them look at it.
Posted on Jun 27, 2010
How do I change melodies?
The melodies should change each hour on it's own. You can change the melodies manually by pressing the demo button repeatedly. If the songs don't change each hour, you might try new batteries. I'd recommend Japanese batteries like Fuji, or Toshiba. I use Varta which is a German brand battery that's equivalent to either Duracell, or Energizer, and have no problems. If you've had the clock for a number of years, or have had it hanging in direct sunlight, or near a heat source it could be in need of professional assistance, and or repair. (if possible)
Mar 01, 2015 | Seiko Melodies in Motion Clock
Seiko wall clockNeed battery cover and repairs Model #QXM139SRH
I sent my clock off to Seiko for repair, useless, they said it was in the circuitry. I had them send my clock back. I ordered a new gear box $2.00, replaced that, it will work as long as it's flat. If you look you can see how the clock cycles I made sure it was "locked" in (you can hand force it) then I removed one of the gears so it doesn't cycle down but stays in the up position at all times. Music plays, lights go, just no motion now. Call Seiko for replacement battery cover.
Jun 22, 2014 | Seiko Melodies in Motion Clock
Seiko wall clock pendulum not working
When was the last time it was serviced? The movement probably needs a good cleaning and/or oiling.
Jan 09, 2013 | Seiko Melodies in Motion Clock
I need to know how to set a Seiko Melody in Motion clock that I just purchased at a resale shop. It is working but the time is wrong. It is oblong with 4 clowns at the bottom. Thank you.
i had that clock hre. and all the insides are special from seiko, i would send it to them. the movement is encased in plastic and some lever rods attached to them . may be worth sending
Jun 17, 2011 | Seiko Melodies in Motion Clock
My seiko musical wall clock doesn't play music anymore
To test your Seiko Melodies in Motion Clock:
1) Check the volume knob in the back of the Seiko clock to make sure the volume has not been adjusted all the way down.
2) Make sure the on / off switch is set to on.
3) If it is extremely dark in the room, the clock will not play, it has a light sensor. Make sure the room is well lit.
4) There are separate batteries usually that operate the clock and the music. Change the batteries paying special attention to any acid / corrosion caused by old batteries. Clean out any acid and it should play. Also, be careful not to touch the positive or negative contacts on the new batteries, as this could inhibit proper connection.
If you have done each step above and it is still not operating, your clock is defective. Contact Seiko Service Center directly at: 800-722-4452 extension 3.
If you have had the clock less than a year, and it was purchased from an authorized dealer, it is under warranty, and any repairs will be free. Otherwise, there may be a charge for the repair.
Feb 23, 2011 | Seiko Melodies in Motion Clock
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
