Question about Baby Lock Sewing Machines
Spring broke baby lock
A spring fell out of the machine while I was sewing. One of the hooks broke and now the thread bunches if I try to sew
forgot
  • 17 Answers
SOURCE: baby lock denim pro
try putting some bee's wax around your spool
Posted on Dec 09, 2007
SOURCE: threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Posted on Feb 26, 2008
Paul319581
  • 101 Answers
SOURCE: my grandmas's New Home (Janome now) 531 machine
i don't know much about this
but try changing the thread !
Posted on Mar 09, 2008
  • 19 Answers
SOURCE: Bernina Bernette 65 sewing machine
Presumably neither of you has or knows how to adjust your bobbin tension so, I'm going to presume it's your hook. Make sure you are threading the machine coorectly then you'll need to remove your needle plate by removing the two screws, pull out your hook (this is the part your bobbin sits in) but make sure you note which way it sits inside your machine. Have a look at the plastic hook for any sharp edges or burs, you may need to replace your hook or try and gently sand (400grit) the plastic if possible. The key part of the hook is the small blunted point as this is what catched the loop of thread behind the needle. Please make sure that when you put your hook back in, that it is on the left side of that little guard sticking out on the lower right of your machine.
Posted on Dec 10, 2008
bargainbox
  • 1388 Answers
SOURCE: New home sewing machine model HF106 have been
For a comprehensive 5 page illustrated tutorial...Check this solution link, just copy & paste:
http://www.fixya.com/marketplace/servicepage.aspx?srvid=17197&ctgid=164&brdid=1060&prdid=131120&smid=23884&mthid=1&mpsaugid=347d7805-9ce5-42d2-b812-b602b6cf7437
Posted on Oct 18, 2011
Needle thread does not pick up bobbin thread on my baby lock sewing machine
check needle thread tension is tight enough
you may have to check the needle / hook timing as if that is not correct , the hook will not be positioned to pick up the needle thread to make the loop
take it in to a sewing machine repair shop for a service
Feb 18, 2017 | Baby Lock Sewing Machines
When I sew it only sews about 4 stitches the top thread breaks & sometimes the threads are all tangled in the bobin area. I found a small spring next to a larger spring loose. Where does the little...
You may want to take it to be looked at by a professional if there is a part loose.
I have constant problems with thread breaking and being tangled in the bobbin area with this machine. It can usually be remedied by adjusting your tension. Also, class 15 bobbins stink for this machine (yes, it says they're compatable, but they seem to be 1/8 of an inch too shallow and constaly become unthreaded from the bobbin casing). Try SA 156 metal ones.
Aug 16, 2010 | Brother LS-2125 Mechanical Sewing Machine
Top thread - not bobbin thread - bunches up under fabric where feed dogs are when I'm embroidering.
this is a top thread tension problem . make shure thread is between tension plates and spring is contacting the plate if the tension number is high
Apr 12, 2010 | Baby Lock Ellure
It is stoping and says the thread is broke but it is not so I push the start and it sews a few more stitches and the same thing I can keep pushing start and it goes again. Barbie
I am not 100% sure on this machine but on most emb. machines they have a sensor connected to the take up spring. When the spring goes up and down the machine thinks things are ok. When the spring does not move it thinks the thread is broken. So...make sure the upper threading is correct. Make sure you have bobbin thread. If this all is ok then the spring may be broken. The spring is located where you make the "U" turn at the bottom of threading and go back up. Hope this helps.
Aug 05, 2009 | Singer CE-100 Futura Computerized Sewing...
Brother vx-950 sewing machine
Place thread spool on the spool pin at back right top of machine. From there, thread through 1) rear thread guide (little hook), 2) front thread guide (front hook), 3) down and up through the thread tension dial from right to left so that thread picks up the thread spring check (the little spring on the left of the tension dial). 4) Through the thread take-up-lever, from right to left (the little lever that goes up and down). 5) Through the thread guard and guides (one on the front, one on the needle arm). 6) Through the needle, front to back. Good luck johntrev800 (at) yahoo.com
Oct 21, 2008 | Brother LS-1217 Mechanical Sewing Machine
Sewing machine repaired but still bunches up
Either no tension on the top thread or damaged needle plate or possibly a broken hook driver spring
Aug 26, 2008 | Sewing Machines
Bobbin case is moving out of place
I was having the same problem with my machine and finally the spring broke. I couldn't find any parts for this so my husband made me a new spring out of a coke can! LOL!! Anyway, he messed with it for a while and it kept doing it. He figured out that it was not the spring but the other piece under the spring was not pushed up far enough to keep the bobbin case in place so he took a screw driver and pushed it forward toward the bobbin case and now my bobbin case does not move!! And the machine is sewing perfect! At least for now. Anyway, it's not the spring or the thread adjusting screw!
Jun 06, 2008 | Brother CS6000i Computerized Sewing...
Baby lock denim pro
Dec 09, 2007 | Brother LS-1217 Mechanical Sewing Machine
Needle doesnt hook bobbin thread while sewing
Our machine had the same problem, there was a piece of broken thread stuck in the upper tension spring keeping the tension spring open. removing the broken thread in the upper tension solved the problem for us
Feb 20, 2007 | Simplicity SE3 Computerized Sewing Machine
Sewing Machines Logo
27 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
