Question about Dyson Vacuums
V6 intermitent run instead of steady run runs spurty not steafdy
    Master:
  • Dyson Master
  • 849 Answers
Hello, this is Ava with Think Crucial.
There are a number of reasons why your Dyson cleaner is acting that way. First, it can be due to a battery of the cleaner. Make sure that the power cable is properly plug to the power and seated properly from the unit while charging. If you find that the battery isn't charging at all, you may need to replace the battery. Second is to check the MAX button of your cleaner. If the button lights up and flashes when your Dyson keeps on pulsating, press and hold the power button and depress the MAX button to turn off the function. You may need to do it for a few times to get the hang of it. Third is to check for any blockages or clogs in the attachments. Look down through the tube and check to see if there are clogs on the sweeper end or if the roller is tangled up in fibers. Clean the roller brush are if it it's necessary. You may need to empty the dust bin of your unit as debris can build up in hard to reach places. Lastly, cleaning the filters may fix the pulsating of your cleaner. Remove the filter and rinse it with cold water and air dry it for 12 hours. Don't use detergent when washing your filters. If the pulsating doesn't go with the given quick fix, I suggest to contact Dyson for further assistance on this.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Posted on Dec 30, 2016
My Dyson V6 slim runs for 2 minutes then off. I plug it in, after a couple minutes it runs again for 2 minutes. unit is clear of debris, filter washed.
Sounds like a battery issue. If able test the battery to check it is reaching rated voltage after charging, otherwise contact Dyson support.
Sep 19, 2017 | Dyson Vacuums
The brushes on my Dyson V6 sweeper attachment won't turn although it is fully charged.
Your battery may indicate fully charged but if dead it will do that and not work for squat. If charged the motor should run and turn the sweeper with power. If motor runs but sweeper does not check for a stretched belt or one that may have fallen off the pulley.
Sep 06, 2017 | Dyson Vacuums
Mymy v6 motorhead shuts off intermitently on high and low power. can I fix this here
Most Dyson vacuums have a built in safety system that stops the machine if it begins to overheat. This usually happens because the filter needs washing or your machine is blocked. If your machine turns off on its own, unplug it and leave it for at least an hour to cool down. Remember to check the filter and look for blockages before re-starting.
Ava B.
Dec 17, 2016 | Dyson V6 Motorhead Bagless Cordless Stick...
Dyson V6 Animal cordless does not suck very well. No blockage of any kind, and all filters have been cleaned.
Battery not fully charged possibly needs replacing. If a battery is not fully charged it will run only half speed with no suction.
Dec 01, 2016 | Dyson V6 Animal Bagless Cordless Stick Vac
What is the main difference between the basic dyson v6 and v8 vacuum?
The main difference between the V6 and V8 Dyson models is the mprovements in power and run time of the unit. The Dyson V6 has the V6 motor that pumps out 24 air watts in normal mode. In max mode that number goes up to 100 air watts. While the Dyson V8 comes equipped with the latest V8 digital motor that produces almost 20% more power than the V6 motor. It has the same 2-tier radial cyclones that capture fine dust and allergens. A post-motor HEPA filter keeps those allergens inside the bin. There is also the Bin improvement as Dyson was able to increase the capacity to 0.14 gallons for Dyson V8. This is around 0.03 gallons bigger than the V6.
Ava B.
Oct 22, 2016 | Dyson Vacuums
My Dyson v6 animal vacuum won't charge
Hello. I have the same problem as Shelly. My Dyson will not charge. When removed form the charger the LED light flashes a few times and then stops. The motor does not run at all. When the machine is returned to the charger the same thing happens. LED light flashes , then stops! The power supply from the mains plug is live. Any ideas please? From Eleanor O'Neill.
Oct 04, 2016 | Dyson V6 Animal Bagless Cordless Stick Vac
With help from this site I replaced the fan on my Kirby Gen4. Now the motor starts slow then stalls. Is it ruined?
When the fan finally cracks and even before it spins out of balance so your motor brushes have poor and intermitent contact with the armature and could have broken the motor housing possibly damaged the field. But ruined NEVER. That machine will run 100 years :)
Oct 22, 2013 | Kirby G4 Bagged Upright Vacuum
IRobot 530 charges intermittently
Reset the Roomba: hold down "spot" and "dock/demo" for fifteen seconds, then release and listen for the tune. Then charge the Roomba overnight. The next time you run it, the unit should run longer. If not, call support and let them know you may have a battery problem. 1-877-855-8593 (I strongly encourage you to have the Roomba with you if you call.)
Aug 30, 2009 | iRobot Roomba 530 Robotic Vacuum
Westinghouse Unplugged Vacuum Turns off after 5 Seconds.
If both batteries are behaving the same way then this is probably a charger problem. When you insert the battery pack into the charger does the 'charging' light blink for 30 minutes (fast charge) then go steady? I noticed that one of my batteries was causing the light to come on steady immediately I inserted it into the charger. When I tried to use the battery pack I got the same problem everyone else is seeing, i.e. vacuum cleaner shuts off in less than a minute, so I conclude that when the charging light is on steady then the battery is not being charged.
If the charging light does not blink when you insert the battery (i.e. comes on steady or not at all), try removing the battery and re-inserting it into the charger.
Try a conditioning cycle on your battery packs. To do this:
* Insert the battery pack into the charger
* Before the charging light lights press the 'condition' button located just above the charging light.
* The 'conditioning' light should blink. This is a light which does not normally illuminate, and it is located below the condition button and above the charging light. The charger fan will run quieter in this mode.
* Leave the battery pack in the charger for 24 hours while this cycle is taking place.
I'm not a service technician so perhaps someone else might like to post other solutions or corrections to this one.
Mar 07, 2008 | Vacuums
Vacuums Logo
42 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
