Question about Dishwashers
So I got the dishwasher (Hobart ft900 dishwasher) to operate correctly for about 40 - 120 min then it will blow the 1A top fuse on the relay board (original problem). any suggestions
2 Suggested Answers
  • 68 Answers
SOURCE: Commercial Hobart dishwasher
I can't imagine a bad relay board would blow a fuse. The relay board would need to make a bad connection to ground to blow a fuse -- I don't see it.
If you could supply me with the ML#, I'll take a look at the wiring diagram and give you an educated answer.
Not that I recall clearly which fuse is for the drain solenoid, but the two sound related. If a drain valve is obstructed by debris, it will heat up the coil and short it out. I don't know the spec'd ohms, but I would suspect at least 50. I'd check it.
Posted on Jun 10, 2008
We have an ft900 with error code E516 can we reset to get unit going?
Operation and Care of FT900 SERIES DISHWASHERS SAVE THESE INSTRUCTIONS OPERATION MACHINE PREPARATION - Check before beginning operation. Open the machine doors and make sure all components are in their proper operating positions Pump Intake Screens must be put on holders at each pump intake (Fig.1). Fig. 1 Strainer Pans must be in place on top of each tank (Fig. 2). Fig. 2 End Caps must be correctly installed at ends of all Wash Arms (Fig. 4). Fig. 4 Wash Arms must be properly installed and latched in place (Fig. 5). Fig. 5 The Final Rinse Arm (and Dual Rinse Arm when present) must be properly installed (Fig. 7). Fig. 7 Curtains and drainback pans must be in their proper places, refer to pages 11 - 14. Strainer Baskets must be in place in Strainer Pans (Fig.3). ANK FILLING Assure proper water hardness. Recommended water hardness is 3 grains or less per gallon. Higher hardness may cause excessive formation of lime scale. Chlorides must not exceed 50 ppm. All water (and steam, if equipped) supply valves must be opened and the electric supply turned on before the machine will function. Close all drains and doors. The drain handles are located near the floor at the front of each tank. Rotate drain handles clockwise to the vertical position. The prewash tank,
Sep 29, 2016 | Dishwashers
Causes of low rinse water pressure on a Hobart ft900-d washer
For a machine without a break-tank (a.k.a. cistern) and booster pump: check the inline debris strainer on the rinse water pipework; check you're not missing any rinse jets; check the inlet valve is fully opening.
For a boosted machine, check the pump impeller isn't disintegrating; check that the flexible hoses to the booster pump aren't collapsing internally.
For both machines: descale if you're in a hard water area.
Mar 15, 2015 | Hobart Dishwashers
Have a hobart lx3011 and just quit working. where and how many fuses in it?
Not sure if you have an LXIC or an LX30.
Both have a pull out drawer at the top. Both have the main connection of power on the contactor in the front left corner. Both have control circuit fuses between the contactor and relay board.
Use caution with a digital meter to test.
Mar 15, 2014 | Hobart 24 in. LXIC-5 Built-in Dishwasher
E-2 Error on LX30 Hobart Dishwasher
E-2 error is a fill problem. Water did not reach the lower probe within the time out. (innitial fill only
1- Is the bottom probe clean?
2- No fill water (check valve, hose,fill screen in end of hose, and fill source.)
3- low water pressure, should be 20 PSI flow.
4- Fuse 1FU blown.
5- Check wiring to fill valve.
6- Check relay board function.
Feb 15, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Programming the 00-749825 Control Board on a Hobart AM14C
That board comes with directions. if not go to hobart and have them copy you one out of a new boards box
Aug 23, 2008 | Hobart AM14-253 Free-standing Dishwasher
Jun 07, 2008 | Hobart Dishwashers
Dishwashers Logo
Top Dishwashers Experts
