Question about Whirlpool LER5636P Electric Dryer
Dryer was working and stopped
I was drying a load of clothes and my laundry room filled with smoke and it smells like burning rubber. I am assuming that it must be the belt but I have no idea how to get to it. I removed the back of the dryer but I can't seem to find it. Can someone help?
  • 5,911 Answers
Your assumptions are probably correct. If the model number is correct, the belt tends to wrap around the motor shaft when it breaks on this model dryer. That may be the source of the burning rubber smell and the smoke.
In order to access the belt follow these steps:
1. UNPLUG the dryer.
2. Lift the top panel by removing the two screws under the lint screen door on the top panel. With the screws removed, the panel will lift up.
3. Disconnect the door switch connector. This should be a white plastic connector plug with two to three wires on it.
4. Remove the front panel by removing the panel screw that is located on each side inside the cabinet. With each screw removed, the front panel will lift up and out of the way.
You should now have full access to the drum interior.
If the belt broke, the idler pulley will come loose and will usually be found lying on the cabinet bottom. This is normal with no tension on the pulley to hold it in place. To re-install, follow these steps:
1. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and refer to diagram H. When reinstalling the front cabinet, make sure you insert the small cleats that are on the front edge of each side panel into the slots on the front panel. Hold the panel in place with your knee as you reinsert the screws that hold it in place on each side. Don't forget to reconnect the door switch! If you still have questions, please let me know. I hope this helps you.
Posted on Jul 21, 2009
Maytag washer MAV6650aww burning smell
OK, this model has a known issue with a bad pump design. The bearing on the pump goes bad and will lock up. The burning smell is the belt trying to turn the pump. Look under the unit and see if you see rubber residue at the pump. Here is the pump to order. To replace the pump, tilt the unit back and remove the belt. Remove the back lower left side access panel. Remove the 2 hoses, then the 3 bolts that hold the pump down. Replace in reverse order. The pump is a new design it looks completely different but will last you the life of the unit.
Dec 09, 2012 | Washing Machines
Ge front loading washer drum fills with smoke at end of last rinse cycle and smells of burning rubber
THE INNER DRUM IS BAD WITCH LETS IT RUB THE FRONT SEAL OF THE WASHER YOU NEED TO SEE IF YOU CAN MOVE THE DRUM UP ARE DOWN ARE SIDE TO SIDE IF SO ONE OF THE SUPPORTS ON THE BACK BROKE AND THE GET THE SMELL OUT WASH THEM IN WHITE VINAGER
Oct 31, 2012 | Kenmore Front-Load Washing Machine 3.5...
Maytag Neptune Dryer with strong "burned electrical wiring" smell
Sounds like the motor went out. Before trying to start it it needs to be inspected. If you are not comfortable opening up the cabinet then I would would recommend calling a service tech. If you need further assistance please let me know.
Ken
Mar 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Dryer smells like burning rubber or plastic...
The drum belt could be rubbing on something inside. Does the dryer make a squeeking noise? Se if there are small rubber particles on the bottom, this will indicate a deteriating belt.
May 08, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Laundry stinks
I find that the dryer does not dry the clothes enough. The washer can take a lot of laundry at one time but the dryer is not able to handle the load. The stink usually comes from a bit of moisture left in the the clothes, especially the towels. Break down your dryer loads or dry them on a timed cycle for a longer time.
Jan 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Winding sound, with a smell of burning
I recommend to stop the use of the dryer immediately and call an expert repairman to your home. The smell of burning can only mean bad things, so better safe than sorry.
Dec 29, 2008 | Indesit WA 125 Front Load Washer
LG Gas dryer doesn't dry clothes in one cycle
Have you checked your outside vent while it was running to see if the dryer was venting 100%. If your clothes are hot and humid I would say clean your vent pipe has a blockage and needs to be cleaned out. Also as far as the burning smell you could take the front off (unplug first) the dryer of by removing 4 screws one above and one below the latch and two at the bottom and there are two clips one at the top left and right push in with a puddy knife and lift the top up a couple inches and lift the front up off the bottom holders. Then you will have access to vacuuming the lint that is floating around the burner.
Dec 01, 2008 | LG DLG5932W Gas Dryer
Burning Smell - smoking coming out of it
I believe we tracked it down to the pressure switch mounted on the drain pump. The device had a strong electrical burn smell and is positioned where it could easily have smoked the basket. We're putting the washer back into service and if I have a recurrence I will post the information. BTW ... Replacement was simple and the part was $26 including shipping.
Jul 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Dryer not drying
try taking a flashlight and look over the back of the drier see if the vent got mashed or is all coled up and stuff let me know also you can remove the vent from the back of the drier and run 1 load to see if it works normal if so then you know the vents the culprit.
Jan 16, 2008 | Amana NDE2335AY Electric Dryer
Smell Gas.
you need to clean out you venting ...it is most likely clogged or filling up
Jan 02, 2008 | Maytag MDG2706A Gas Dryer
Whirlpool LER5636P Electric Dryer Logo
177 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
