Question about Reddy Heating & Cooling
I need a electromagnet for a Reddy Model 28725 propane heater
Buffalo12980
  • 625 Answers
SOURCE: reddy heater model 28725
propane heater uses a hot surface ignitor. this operates off 120 volts and glows red/orange when actuated. it stays lit throughout the heater on operation.  on the backplate of the combustion chamber is a high limit with two wires coming off it.  these two wires connect to the spade connectors on the flame detector cappillary.  Once you establish a fire, the flame detector generates a 750 millivolt signal which is applied to the pilot/main valve assembly.  My diagram will show this. 1fa8284.jpg
Posted on Oct 15, 2007
Accurate Joe
  • 61 Answers
SOURCE: Reddy propane heater RLP100
Try a little longer, sometimes it takes a full minute to heat the thermocouple. Check and make sure thermocouple is in flame. If all this is ok. then your going to have to change the valve.
Posted on Nov 30, 2008
tbugger
  • 232 Answers
SOURCE: reddy heater will not keep running
Test the thermocouple: Normal 0 Heater will run as long as the control valve is pressed.
According to DESA test these parts. NOTE: Not all heaters are equipped with
A relay.
Thermocouple
Turn off gas supply. Remove thermocouple
from gas valve. Using a digital
multi-meter set to the lowest DC millivolt
setting (meter needs to have alligator clips
on ends of leads), clip black lead to the
very tip of thermocouple (end removed
from valve). Clip red lead to the outer casing
of thermocouple for ground. Relight
unit output should be between 18 and 28
millivolts.
Relay
Turn off gas supply. Remove bottom of
base (if equipped). Relay is a normally
open circuit between terminals 4 and 6
which closes when current is supplied.
Using a digital multi-meter measure the
resistance. With no power to unit, resistance
between terminals 4 and 6 is open
circuit or no resistance. Apply power to
relay. Resistance between terminals 4 and
6 should be less than 100 mili ohms.
Posted on Nov 04, 2009
baugh55grfmj
  • 225 Answers
SOURCE: Propane Tank Size needed for Reddy Heater TB101
Yes it will work but it will heat more efficiently with the 100 lb tank
Posted on Jan 05, 2010
  • 188 Answers
SOURCE: 150,000 BTU propane Reddy Heater shuts off after ignition
Is there a frost line on your LP tank, if so you may need to replace the tank with a larger tank or refill your tank. This can happen if the tank your using is too low or too small (use 100 lb tank or greater). If there is no frost line it may be an issue with the thermocouple. The manufacturer offers a service manual and owner's manuals on there site. This should assist you... www.desatech.com Thank you
Posted on Jan 28, 2010
Need regulator and hose assembly, for Reddy propane heater 76=125 btu
Here's a link where you can find what you need. But, you will need to have the Model Number, handy.
http://www.reddyheaters.net/
Don't forget to rate my response. Thanks!
Mar 27, 2011 | Reddy Heater- Variable 75,000-125,000 BTU
30000 btu reddy heater is throwing flame way out of the heater
The gas pressure is way to high... you need to adjust the regulator to a low pressure or replace the regulator...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Dec 10, 2010 | Reddy Heater-30,000 BTU Propane Forced-Air...
Jan 28, 2010 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Won't stay lit..
I contacted ReddyParts.com and talked with their support department (866-883-9312). They instantly stated "your thermal coupler is bad". They had 1 in stock for 19.99 + shipping. I ordered it and plan to have it installed and tested by next weekend. The model I have is Reddy Heater Propane 35k to 55k (RLP55V).
Dec 12, 2008 | Reddy Heater-30-55,000 BTU Variable
Nov 29, 2008 | Reddy Heater RLP100 Portable Forced Air...
Wont run
two things come to mind here. the high limit shutoff and the millivolt generator. the hi limit cutoff is a thing that looks like a metal pill with two wires coming off it. those two wires connect to the two tabs on the millivolt generator cappillary. its purpose is to keep the millivolt circuit closed. The millivolt generator produces a very small (750 ma) voltage which is in turn connected internally in the gas valve to a small electromagnet. with a flame on the voltage is generated and keeps the pilot valve open. replace either or both devices.
Jan 14, 2008 | Reddy Heater-30-55,000 BTU Variable
Reddy heater model 28725
Oct 12, 2007 | Reddy Heater-30,000 BTU Propane Forced-Air...
Heating & Cooling Logo
32 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
