Question about Photography
I have a sungale digital frame and i am using an usb and it only is showing 4 pictures out of 23. the rest have ? this is the first time i use it. what's wrong?
5 Suggested Answers
Junoon007
  • 1011 Answers
SOURCE: Program drivers for Sungale mini digital photo frame
Dear Sir/madam,
try this link for more information
http://www.driverfiles.net/Cameras/Precision-images/
mini-digital-camera/download/page,show,12139,676,17,.html
Don't forget to rate the solution
Thanks
Posted on Apr 01, 2008
Junoon007
  • 1011 Answers
SOURCE: Sungale 7" Digital Photo Frame CA700
Hello sir,
U should install usb driver 1.0 at the location of ur drive. or connect the camera with usb drive and install the driver version of 1.1. it will solved.
Thanks
Posted on May 11, 2008
SOURCE: i do i get pictures from my camera to my digital from with my usb
hi you can plug in your secure digital card into the digital frame,or if your camera does not use a secure digital card,you will need to buy a memory pen stick where you can store any picture you want on it,they are very cheap and they just plug into your usb port,hope this helps
Posted on Jan 04, 2009
label_chick
  • 407 Answers
SOURCE: how to delete a picture from a digital photo frame
Using the USB cable you can connect to your computer and change the photos or delete the ones you no longer want.
Plug the USB into your computer - If you don't see the pop up message letting you do this, Go to my computer and check the photo frame appears as a new device.
Posted on May 11, 2009
Pictures not showing.
make sure the cards' slide button is in the unlock position..then check to see which size cards the frame can work with..mb sizes like 2/4/6/8/12 etc..
Jan 11, 2014 | Audiovox DPF700 Digital Picture Frame
Need the software driver for the sungale TD350A digital photo frame
If you still have the manual for your Photo frame Chapter 2 page 14 explains the use of your frame for computer. It uses specific software already installed on the picture frame. It is a bit tricky to use if you are not computer savvy, hoever if you can get someone to help you they can explain it a little better. Here is the link to the manual http://www.myalphadigital.com/down/manual/TD350A-UM-EN.pdf
Apr 04, 2013 | Sungale 3.5-Inch Portable Digital Photo...
Can the Sungale ID800T 8" digital touch screen photo frame be used as a monitor?
does it have vga? otherwise you would need software for you pc to know what its meant for when plugged in
Jan 31, 2013 | Sungale 8" Digital Touch Screen Photo...
TRANSFERRING PICTURES TO DIGITAL PHOTO FRAME
There are many ways. The easiest being use a external hard drive or thumb drive and simply copy the data to the drive. Plug the drive in the other computer and reverse the process.
Is there something wrong with the laptop?
Dec 26, 2012 | Sungale Gpx 7" Digital Photo Frame
How do I transfer pictures from my camera to the digital frame by Sungsle CA705
this device only support JPG file, so insert your picture (JPG Format) into memory card SD,MMC or MC and plug it into the Sungale CA705 digital frame
Dec 16, 2009 | You Software You Control 1.01 (cme73002)
Cant copy any pictures from computer
You can start copying pictures to SV811 digital picture frame if you get the message “Use PC interface to copy files.” Here are the steps:
Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools:
1. Connect the USB cable from the frame to your computer
2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
Copying pictures from EasyShare software:
1. Install EasyShare software (free download at www.kodak.com/go/sw )
2. Connect the USB cable.
3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
5. Select the frame source to which you are copying.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
7. Click Copy. Pictures are copied to your frame.
8. Unplug the USB cable and press “Home” icon to navigate to your copied pictures.
Feb 03, 2009 | Kodak EasyShare SV811 (8858946) Digital...
I can't transfer pictures from my computer to my digital frame. When I connect my usb cable to my computer from my digital frame , the frame displays "Connected to computer. Use PC interface to copy files....
Dec 26, 2008 | Kodak EasyShare SV811 (8858946) Digital...
Hello sir,
Thanks
May 11, 2008 | You Software You Control 1.01 (cme73002)
Dear Sir/madam,
Thanks
Dec 19, 2007 | Computers & Internet
Photography Logo
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
