Question about Exercise & Fitness
I have a exercise drive belt to replace on a Nordic Track NTEX3196.0 bike. The drive is different than the bikes on YouTube. The idler bracket is different. How do I route the belt?
SOURCE: edge 491 exercise bike monitor panel dead
http://www.academy.com/images/pdf/Fitness_Quest/Edge_Recumbent_Bike_491r.pdf
Mine went dead last Spring. I ordered a replacement part from Fitness Quest. I think the link is above. Actually, while I was waiting for the part, I reconnected all the wires on the whole bike and the panel worked. So I actually have an extra new working panel if Fitness Quest doesn't have the part for some reason and u want mine. Double check ALL the connections of the wires first. They come loose easily.
Nancy
Posted on Aug 10, 2009
SOURCE: Putting together new nordic track upright exercise
Customer service says that is for testing the console at the factory. I was hoping that it was for a cool add-on but it's not.
Posted on Dec 26, 2009
maxtreadmill
  • 832 Answers
SOURCE: nordic track commercial 1300 manual
It sounds like reed switch inside the side panel located on the frame by the large pulley either needs to be adjusted or replaced. Try adjusting the switch first the clearance between the switch and large pulley magnet will be 1/8" if you have the same result then replace the switch.
Posted on Jun 14, 2010
escapement
  • 2334 Answers
SOURCE: When can I get a
This is Schwinn phone number. Contact them and ask whatever you are interested into. (800) 868-5764
Posted on Feb 28, 2011
intower18
  • 957 Answers
SOURCE: I have a Yankee/Nordic track
Please try this link below this may help you:
http://forums.redflagdeals.com/archive/index.php/f-26-p-2.html
Posted on Aug 01, 2011
How to stop the bike from slipping
Hey
This may help you
https://www.youtube.com/watch?v=GWYERtOBFI0
Sep 25, 2016 | Nordic Track NordicTrack Commercial VR...
Tip
How to Remove and Replace the Bottom Bracket on an Indoor Cycling Bike
Following is a basic guideline of removing and replacing the bottom bracket on an indoor cycling bike. Due to the different brands of indoor cycling bikes and designs for bottom brackets, the following should only be used as a guideline. If any of the information is not exact to the bike being serviced, refer to the service manual or call Sportsmith for further help.
Common Tools Needed:
Phillips Screw Driver
Set of Allen Wrenches (standard and metric)
Bottom Bracket Tool
Cotterless Crank Puller Tool
9/16" Socket
Ratchet Wrench
Pedal Wrench
Crescent Wrench
You will begin by removing the outside belt/chain guard by using either or both the Phillips screw driver and Allen wrenches. It may be necessary to remove the drive side pedal (using the pedal wrench) in order to completely remove the outside belt/chain guard.
Once the belt/chain guard is removed, you will need to remove the belt/chain. If the unit is belt driven, you can simply "walk" the belt off the pulley by pushing the belt to the outside while turning the crank backwards. **CAUTION: PINCH POINT ** If the unit is chain driven, most use a continuous chain that can be "walked" off the sprocket just like the belt. **CAUTION: PINCH POINT ** Some chains may use a connecting link and can be separated at the connecting link to remove the chain. The connecting link is different in appearance from all other chain links.
Now it is time to remove the crank arms. How to Use a Cotterless Crank Puller Tool
It works best to place the bike upside down for best leverage to remove the bottom bracket. (If placing the bike upside down, ensure proper seat adjustment for best bike balance.) Begin removing the bottom bracket from the drive side of the bike. This side has a reverse thread. You will need to turn right to loosen and remove the bottom bracket. Place the teeth of the bottom bracket tool into the teeth of the bottom bracket cup. Using the ratchet wrench or crescent wrench to turn the bottom bracket tool, you will turn right to loosen and remove the bottom bracket. (If removal of the bottom bracket is difficult, it helps to use a crescent wrench in combination with a bolt threaded into the bottom bracket shaft to hold the tool in place while applying pressure to break the bottom bracket loose.) Remove the bottom bracket from the frame. Remove the bottom bracket cup and/or lock ring from the non-drive side of the bike. This is a standard thread. You will turn left to loosen and remove this bottom bracket cup and/or lock ring.
Install the new bottom bracket from the drive side and tighten flush to the frame. Install the bottom bracket cup and/or lock ring to the non-drive side and tighten.
Re-install the crank arms and pedals. Make sure the crank arm bolts are tightened to the proper torque. If unsure of proper torque specs, refer to the equipment service manual or call Sportsmith.
Re-install the belt/chain onto the pulley/sprocket. If belt/chain was "walked" off the pulley for removal, it can be "walked" onto the pulley/sprocket by placing the belt or chain along the bottom of the pulley/sprocket. Carefully, turn the crank arm forward while lifting on the belt/chain. **CAUTION: PINCH POINT ** Continuing turning the crank forward until the belt/chain is in place.
Re-install the outside chain guard and test the unit. Ride the bike without tension and test with tension. Ensure functionality and feel of the ride. Make any adjustments if necessary
Removing and Replacing Bottom Bracket on Indoor Cycling Bike
on Mar 11, 2015 | Exercise & Fitness
Why my commercial vr resistance levels not working at all? Do i have to replace the resistance motor?
https://service.nordictrack.com/CustomerService/manuals.do?dr=NT
https://service.nordictrack.com/CustomerService/contactUs.do
Jun 16, 2014 | Nordic Track NordicTrack Commercial VR...
Can't remove right pedal shield
The shield will not come off unless you remove the entire crank, not just the pedal. to do this, you need to buy a CRANK ARM PULLER TOOL available for around $15.oo at any bicycle shop. Make sure to get one for a square tapered bottom bracket. Just used one, the crank came right off and the shield simply lifted away. here is a link to a YouTube Video showing the tool and explaining the process: https://www.youtube.com/watch?v=N63ofGcRCYQ
Jan 28, 2014 | Nordic Track NordicTrack GX 5.0 Pro...
RESISTANCE PROBLEM WITH FREEMOTION 350R
9 out of 10 times the issue is a worn out clutch bearing or "one way needle bearing". Freemotion and Nordic Track are both owned by ICON Fitness. This technology for fitness equipment comes from the original Nordic Track skier. In the skier, there is a flywheel with an axle through it in the middle with skis left and right. Under each ski just about center of the length is a rubber roller that fits over the flywheel axle. Inside this roller is a "one way needle bearing". That is, when you push to the rear with the ski, the bearings rollers will shift and lock against the axle and engage the flywheel. When you pull the ski back forward the rollers inside the bearing release the axle and allow free movent forward untill you again push to the rear. Many poor souls were sold new skis and tension straps in most cases to no avail. What needed to be replaced or rebuilt were the rubber rollers under the center of each ski with the "one way needle bearing clutch" inside. The same technology is used inside this exercise bike except that the "one way needle bearing" is pressed directly into the flywheel itself. So rather that replacing or rebuilding the "roller clutches", you need to replace or rebuild the "flywheel". The price for the flywheel from ICON is $600 plus. Thats right $100 more than you probably paid for the bike. There used to be businesses that rebuilt the roller clutches for the skiers. There is no rebuild service available for the flywheel on this bike. So if you don't buy the maintenance contract witch will cost you as much as the bike for 4 or 5 years you have a very heavy piece of junk to dispose of. This is planned obsolescence at it's best. If you are very handy. You can disassemble the bike and find a commercial machine shop that can replace the bearing for you. It is sandwiched between roller bearings on each end. You will need a press designed to remove and replace bearings for commercial machinery like conveyor belts and assembly line equipment and someone to order and replace the same or an equivalent bearing. This actually should be a relatively affordable service. At least in comparison the only other option.
Oct 30, 2013 | FreeMotion 350R Recumbent Bike
Nordictrack gx 5.0 pro will not turn on
Did you ever find a solution to the dashboard of your Nortictrack 5.0?
Jan 20, 2013 | Nordic Track NordicTrack GX 5.0 Pro...
What are the different resistances on exercise bikes?
There are three main types of resistances, the fan resistance used to provide resistance with air they push as you pedal. The second type is the belt resistance which uses a belt that runs through a brake providing resistance for the exercise bikes. The third type is the magnetic exercise bike which provides resistance which can easily be adjusted while riding the bike.
Aug 09, 2012 | Exercise & Fitness
How do I replace a Nordic Track C2255 drive belt?
The black shavings are normal on a treadmill. It may be that you need to tighten the walking belt. Try tightening the two bolts on the rear of the machine that hold the rear roller in place. You need to tighten each of them the exact same amount or you'll throw off the alignment. Tighten them three turns of the wrist and see if that helps. If not, try three more turns. If still nothing then replace the drive belt. That can be a real undertaking and you might want to consider contacting a professional.
Jul 14, 2017 | Exercise & Fitness
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
