Question about Garmin GPS
My Garmin 410 just stopped being able to obtain a satellite signal for seemingly no reason
    Top Expert:
  • Garmin Master
  • 79,865 Answers
If you have tried multiple times in different locations then the GPS has failed.
Posted on Dec 21, 2016
My garmin nuvi 660 stopped receiving satellite signal. Reset has no effect. Everything else seem to work.
Power your unit on outside, make sure you have a clear view of the sky. If your unit is working properly, then it should pick up the satellites. If so, then you can put the unit back in your vehicle and make sure it is positioned to maintain a satellite lock. If you cannot acquire satellites outside, then the unit is defective.
Jan 01, 2017 | Garmin GPS
I have a new Garmin 410 and really struggle to get it do download via the ANT agent.
Once the USB ANT Stick is connected it should automatically start downloading.
Make sure the Garmin Communicator Plugin is up to date for Mac OS.
http://www8.garmin.com/support/download_details.jsp?id=3739
You may also want to contact Garmin Support for assistance.
1-800-800-1020
Nov 11, 2011 | Garmin Forerunner 410 with Heart Rate...
I don't have Satellite signal! I tried to acquiere satellite signal with my Garmin Nuvi 1350! The screen always says locating satellites but nothin happens! The satellite bars are not green!What can I do...
Try fully charging the unit and leaving it stationary for about 20-30 minutes if you still dont lock satellites try giving the unit a firmware updates using Garmins WebUpdater software here is a link.
http://www8.garmin.com/products/webupdater/howtoinstall.jsp.
Hope this helps!
Feb 24, 2011 | Garmin nuvi 350 GPS Receiver
My home base is Ohio. I am now in Texas and my Garmin Nuvi 265W seems unable to acquire a satellite signal for my current location. How can I get a satellite signal that I can use in Texas?
One problem, which I've experienced, are tinted windows (tinted with metal oxide). They block or distort the microwave signal to/from the satellite. Garmin has an optional external antenna which can be used, or you can try relocating the GPS in your car. Try it with all windows down and the unit near an open window. If that works you've confirmed the tinted glass problem.
Jan 18, 2011 | Garmin Nuvi 265W GPS Receiver
My garmin approach 3 will not acquire a gps signal. Why?
There are many reasons for a GPS to fail to acquire signals from the satellites. You should be outdoors with a clear sky the first time you attempt to get it to work. If it's worked before, but stopped working, it may be defective. Garmin recommends many thing to do at this link:
https://support.garmin.com/faqSearch/en-US/faq/content/YyCZrQHhuf6PO6qTKdvvr9
Jun 28, 2010 | Garmin Approach G3 Handheld GPS Receiver
I takes close over 3 minutes for my garmin 765T to locate a sattelite and I leave in a major east coast city. is something wrong with the system or is this normal
Holding the satellite signal strength indicator icon (upper left hand corner of screen) for a few seconds with your finger brings up a visual display showing signal strength of various satellites, accuracy, speed and elevation.
From a cold start - I too have experienced 2 to 3 minute wait times for satellite aquisition, so I would presume this is a normal. I own three different Garmin units apart from the 765T and satellite aquisition times vary on all three, most aquire satellites in under 4 minutes. Traffic on the other hand seems to take a while to load as this is dependent on availability in your area.
Nov 30, 2009 | Garmin nuvi 765T GPS Receiver
C330 Reboots when GPS signal obtained
My instructions for the C330 suggest resetting.
Unplug power and USB cables
Place thumbnail in groove located under Garmin logo on faceplate and gently pry off
Press RESET button for about 3 seconds
Connect to power source and turn back on
Hope this helps
Dec 17, 2017 | Garmin StreetPilot C330 GPS Receiver
Lost satellite reception
I have the same problem, and so far the only solution is patience. If you are in a cutting, or between tall buildings, and the satellites are low down on the horizon, then it seems reasonable that reception will be between poor and zero. But in wide open spaces mine too sometimes loses the signal. Hang in there, and contact is restored.
LocoTorque
Aug 11, 2008 | Garmin nuvi 200W GPS Receiver
GPS Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
