Question about Sony KP-61HS30 TV
My sony 61hs30 says No signal with no picture when on full screen,
But when dual screen with game the picture plays three second burst great color to b/w with sound fades to static with it
  • 192 Answers
SOURCE: SONY KP-61HS30
When one or all the colors are bending severly, then the convergence circuit is not functioning correctly and must be repaired. Only one color bending means just the convergence ICs and all colors bending means convergence ICs and voltage supplies. Convergence issues are the most common problem with rear projection (w/picture tubes) televisions. The cure is replacing the convergence IC's. Sometimes the pico fuses need replaced as well. If you have the experience to use a soldering iron and a basic understanding of electronics, then, you may be able to do this job. If not then call a servicer in your area. Go to the Sony website, Sony.com, and you can locate one in your area.
Posted on Jan 07, 2007
  • 135 Answers
SOURCE: sony tv kp-61hs30
Sounds like a convergence problem. Common in this set.
Posted on May 25, 2009
darjr
  • 378 Answers
SOURCE: my tv colors have started to fade.
Ya, I think your Tv has weak CRT problem. or the FBT need replacement. You consult the tech. of sony service center.
Posted on Jun 11, 2009
  • 8457 Answers
SOURCE: Sony Trinitron screen flashing
Resolders the FBT,the big black block u readjust.Turn it back the same position was before.Resolders the video board connections holes that connected to the long neck CRT(Tv tube).After this the tv should stablalize.
Posted on Dec 26, 2009
  • 51 Answers
SOURCE: My Sony kp-61hs30 has no power. no blinking
Check fuses on power/delection board. Besides normal looking fuses there are micro fuses that are small and are yellow or blue in colour
Posted on Jan 08, 2010
What are the part numbers of lamps for kp61hs30
It uses 3 picture tubes which are no longer sold.
What is set doing or not doing that makes you suspect them?
Apr 17, 2012 | Sony KP-61HS30 TV
Kp 61HS30 TV Had the tv since 2002. been a great tv. Just recently it started making a noise when you turn it on. Noise fades away after about 10 seconds. Noise kind of sounds like a dvd player trying...
If you locate the audio board, check for dried up electrolytic capacitors and dry joints around the output IC itself.
That should fix your fault.
Nov 27, 2010 | Sony KP-61HS30 TV
The picture has a green tint to it on all channels
The color signal consists of Red, Green and Blue. Those three colors, at various degrees, make all the other colors on your screen.
If you have a BRIGHT green screen it's best you don't operate your set.
If it's just tinted green then there is a problem on the CRT (Cathode Ray Tube) drive board. Do check your "tint" setting and see if someone misadjusted it. If that isn't it then you need to have your set on an electronics bench and get an estimate for repair.
Apr 17, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Look like the image is divide on three.red,blue,green .yesterday was normal.my son finish video game and turn off.Today I turn on and the image cannot show all colors together.
this is a normal problum pls. check remot cantrol on menu key press then selact convergen seting see on the screen canter three cross line arrow to set UP / DW/ LIFT/ RIGHT key maeching 3 line and see cross line is White then see the pictuer is ok
if not working convergen seting then spare STK replace in inside your tv set
Oct 29, 2009 | Sony KP-61HS30 TV
Sony projection tv with dual tuners; only one tuner appears to be working now.
To verify that the tuner is the problem, move the cable from the second to the first. If you don't get a signal, the tuner is bad. The main tuner is part number 859843000 and is available for $47.38 from tritronicsinc.com
Dan
Oct 07, 2008 | Sony KP-51HW40 51" Rear Projection...
Loss of colour
Hello judithprust
The IC (integrated circuit) that controls color might be bad or the filter for the color burst might be defective. In either case a qualified TV repair person should be enlisted to fix this problem. The color burst signal uses vector mathematics to control the color output of your device, it the color burst is removed the picture will display a monochromatic (black and white) picture.
Thank you,
Shuttle83
Jul 11, 2008 | Panasonic DMR-E55 DVD Recorder
No signal
Good day. Try to check the tuner section. You mention that it functions good in auxilliary functions. check tuner section and system IC.
chris
Mar 28, 2008 | Sony KP-61HS30 TV
Black screen
my sony kp-61hs30 displays that there is no siginal, also the red indicator light blinks when the power is turned on but goes out i have dirct cable pluged into the set and up until about a week ago it worked fine.All of the other tv's in my home work fine so i don't understand what the problem is . I have a dvd player connected to the set and it works great for viewing dvd's please assist with me with some trouble shooting points
Jan 24, 2008 | Sony KP-61HS30 TV
Problem
Hi three months ago my kp-61hs30 tv looks like 3d picture and technician man replaced the two convergence Ic's but last night my tv looks like 3d picture and it look like is the picture goes down
i don't know why happened again
Oct 30, 2007 | Sony KP-61HS30 TV
SONY KP-61HS30
Jan 07, 2007 | Sony KP-61HS30 TV
Sony KP-61HS30 TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
